- 0
HOWTO Ignore Old cards & Inused IDs
Hi
On Gbox its easy to put one ignore.list on the box for all connected peers.
On CCcam you must Ignore bad Crads in every c line you have. But you can also Ignore some Providers only on special hops thats also very interest because you don't need 50 cards of a provider in hop3 when you have also 20 on hop2 and 5 on hop1 so your CCcam will be faster when you make a good configur of your cccam.
Exemple 1:
C: dyndns.org 12000 user pass no { 0:0:3, 1702:000000, 1722:000000 }
This will ignore Premiere on all hops from this peer. Very Important is the no
Without the no it dont work.
Exemple 2:
C: dyndns.org 12000 user pass no { 0:0:3, 1702:000000:2, 1722:000000:2 }
You get Premiere only on hop1 and hop2 from this peer.
Now I Ignore this Providers in every Cline:
{ 0:0:3, 0100:000002, 0100:000003, 0100:000004, 0100:000005, 0100:000009, 0100:00000A, 0100:00000C, 0100:00000D, 0100:00000E, 0100:00000F, 0100:000010, 0100:000011, 0100:000012, 0100:000013, 0100:000014, 0100:000019, 0100:00001A, 0100:00001B, 0100:00001C, 0100:00001D, 0100:000020, 0100:000021, 0100:000025, 0100:000026, 0100:000029, 0100:00002E, 0100:000031, 0100:000033, 0100:000034, 0100:000037, 0100:00003E, 0100:000066, 0100:000067, 0100:000068, 0100:00006B, 0100:00006F, 0100:000070, 0100:000071, 0100:000072, 0100:000073, 0100:00007B, 0100:000082, 0100:000083, 0100:00008C, 0100:00009D, 0100:00009E, 0100:0000A0, 0100:0000A1, 0100:0000A2, 0100:0000A3, 0100:0000AC, 0100:0000AD, 0100:0000AE, 0100:0000B0, 0100:0000B2, 0100:000140, 0100:000141, 0100:000142, 0100:000143, 0100:000144, 0100:00331B, 0100:00331D, 0100:004001, 0100:004002, 0100:004006, 0100:004102, 0100:004108, 0100:005001, 0100:005211, 0100:005225, 0100:00A829, 0500:001540, 0500:001570, 0500:002500, 0500:007000,0500:007010,0500:007C00, 0500:008000, 0500:008100, 0500:008C00, 0500:008C10, 0500:009400, 0500:00E470, 0500:00E800, 0500:012000, 0500:012010, 0500:015000, 0500:016800, 0500:016810, 0500:018810, 0500:018820, 0500:020A10, 0500:020A20, 0500:020A30, 0500:020C00, 0500:020C10, 0500:020C20, 0500:020C30, 0500:020C40, 0500:021120, 0500:021510, 0500:021570, 0500:021710, 0500:021B10, 0500:021C10, 0500:022210, 0500:022E10, 0500:022F10, 0500:023110, 0500:023120, 0500:023130, 0500:023140, 0500:023210, 0500:024410, 0500:024F10, 0500:025120, 0500:025910, 0500:030A10, 0500:030A20, 0500:030A30, 0500:030A40, 0618:000000, 0D00:006400, 0D00:006800, 0D00:00C400, 0D00:00C800, 0D00:00CC00, 0D02:008000, 0D02:008800, 0D02:008C00, 0D02:00A400, 0D02:00A800, 0D03:00C000, 0D03:00C400, 0D03:00C800, 0D06:000800, 0D06:000C00, 0D06:001000, 0D06:00C400, 0D06:00C800, 0D06:00CC00, 1800:004001, 1800:004101, 1800:007001, 1800:007101, 1801:000501, 1801:000503, 1801:000505, 1801:000511, 1801:002111, 1801:003101, 1801:004001, 1801:004002, 1801:004101, 1801:004102, 1801:004801, 1801:004901, 1801:007101, 1801:00C101, 1801:00C102, 1802:002111, 1802:004901, 1802:008C11, 1802:008D11, 1803:007101, 1803:008D11, 1804:008D11, 1810:004101, 1810:00B101, 1815:00B901, 1830:003501, 1830:003503, 4A63:000000, 4AA0:000000 }
This little copy and past on every c line in your cccam.cfg will help u and all other peers to make cccam faster and more stabieler.
This ignore more or less the most old cards, this cards dont work anymore.
You can post here your comments ; other unused prov .... to make this up2date
In the attachment you can find the latest CCcam.providers
You can also add unkown providers to CCcam.prio file (I line) to Ignore them ; this way you receive card but it stop traffics with ignored providers .It work like a filter.
I am working also on a CCcam.prio list ,I will post her In few days.
Download CCcam
Download Ignore List 19.06.2008
