Dislikes:
**PLUG IN** Ipbox 91&9xx&9000
pune pe files in var/script, attributes 755
Thanks to crash
scrplg-crash.rar
arata informatii pt sharing,citi carte iei,citi conectiunii ai.Ceva de gen cccam info.
**www.satgrekco.gr**
by sotiris 70
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Ipbox 9000&900 **PLUG IN**
Aica o sa gasiti plug in pt ipbox 9000 si 900.
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Re: Ipbox 9000&900 **PLUG IN**
cuberevo-ushare-1.1a
cuberevo-ushare-1.1a.tar.zip
This daemon exports the directories /media/mp3 and /media/photo to your home network via upnp and the files can be played with a upnp capable media player (vlc for example).
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
This release from script-plugin uses the new jpg to bmp function, which allows us to store the background images as jpg instead of bmp, which saves us almost 1.2MB of space in the /var directory for each plugin.
This function was added to the plugin SDK by Taehoon.Koo from DGSTATION on my request, thus i'd like to thank him one more time, for his help.
I recommend everybody who uses a r7473 based image, to switch to this release and replace /var/plug-in/bg-scrplg.bmp with /var/plug-in/bg-scrplug.jpg, because the space gain in /var is really *****stic.
Release-notes:
0.0.1:
- initial release
0.0.2:
- use new JPEG_convert_to_BMP_plugin function to convert background image from
from jpg to bmp on the fly (This function was added by Taehoon.Koo from
DGSTATION on my request).
Thanks to Taehoon.Koo for the quick implementation from this function
ip9000_script_plugin_0.0.2.tar.gz
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
hddtemp-plugin
This release from hddtemp-plugin uses the new jpg to bmp function, which allows us to store the background images as jpg instead of bmp, which saves us almost 1.2MB of space in the /var directory for each plugin.
I recommend everybody who uses a r7473 based image, to switch to this release and replace /var/plug-in/bg-hddtemp.bmp with /var/plug-in/bg-hddtemp.jpg, because the space gain in /var is really *****stic.
INSTALL:
copy the files to the following directories on your box:
binaries/hddtemp -> /var/bin/hddtemp
binaries/hddtemp.db -> /var/etc/hddtemp
hddtemp.plugin -> /var/plug-in
binaries/galaxy-man-bg-hddtemp.jpg -> /var/plug-in/bg-hddtemp.jpg
or
binaries/crash-bg-hddtemp.jpg -> /var/plug-in/bg-hddtemp.jpg
Release-notes:
0.0.6
- does not crash anymore, when bg image is missing
- changed parse method from hddtemp to strtok
ip9000_hddtemp_plugin_0.0.6.tar.gz
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
EPG9K.plugin version 0.0.8b of 10 July 2008
RELEASE NOTES and CHANGELOG
Version 0.0.8b "DGStation Rulez" 10 July 2008
Added JPG back gruond support
Aggiunto supporto a sfondi jpg
Experimental funcion: Import to Box Standard EPG ( PLAY KEY )
Funzione Sperimentale: Importa il DB neel'epg standard (TASTO PLAY)
epg9k-0.0.8b.tar.gz
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Dreamcamip for ipbox9000hd
Version 0.96 beta. First Release
* Keys
o 1..5
+ Set the number of cameras
o 8
+ Enable or disable viewing of motion detection
o Red
+ If there is only one camera enables or disables the reco***ng of the camera
+ Red. Cancel selecction of the reco***ng.
+ 1..5. Enable or disable reco***ng of a camera
+ 7. Activate reco***ngs of all cameras
+ 9. Disables reco***ngs of all cameras
o Green
+ Green. Cancel selecction of the view.
+ 1..5. Select a camera visible on screen.
o Blue
+ If there is only one camera enable or disables the alarm of the camera
+ Blue. Cancel selection of the alarm.
+ 1..5. Enable or disable alarm of a camara
+ 7. Active alarms of all cameras
+ 9. Deactivate alarms of all cameras
o yellow. unsupported : ( Now,It's not posible return to plug-in from command line
+ Hide or show the plugin. Only when the plugin is hidden alarms are executed active.
o Exit. Press exit key two times for exit.
* Reco***ng images.
o In the folder. / movie / <name of the camera> / <year> / <month> / <day> / are stored images. To make a movie you must use the power of a PC. Connect to Dreambox (Activating the NFS server, Samba Server, Ftp Server). ffmpeg is capable of creating animations from jpeg files
* Alarms.
o To use an alarm, we must take the following steps:
1) Set the alarm (blue button) and select number of camera
2) Hide the plug pressing key yellow. In the lower right corner appears an indicator of movement
3) When the cameras have got motion detectection the plugin is show
* Locations.
in different places. Now the application can be placed in /var/camip, /var/tuxbox/camip or /hdd/camip
* CONFIGURATION FILES
+ config.conf
+ cameras.cam
dreamcamip096b.sh4.tar.tar
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Pt dreamcamip am facut un files cu care putem sa vedem camere live din romania
cameras.zip
-Instalam pe dreamcamip
-Dezarhivam pe file cameras.zip
-Facem copy ce contine camera.zip pe plic hdd/camip
-Pornim pe dreamcamip
-apasam exit de 2 ori
-Apare o imagina roz din spate,asteptam putin si apare imagina de la live camera
-Dupa cu sageata jos schimbam camera.
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
EPG romanesc.
In curind o sa scot o versiuna cu EPG pt canale romaneste...
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Re: EPG romanesc.
1-Dezarhivam pe file care am dat.
2-cu un program ftp facem copy tot ce contine plic la var/bin
3-folosim pe program script plug in care a fost instalat inainte sa adaugam pe files.
4-alegem pe canal care dorim,asteptam putin si arata ce program are.
**multumesc pe sotiris70 pt ajutor**
*** informatii pt program sunt de la site www.raz-soft.com ***
Exista o problema cu anumite caractere romaneste care nu poate sa fie afisate normal,daca cineva vrea sa corecteze asta problema o sa fie super...
ROMANIAN_TV_GUIDE.rar
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
TV listings
Cine doreste TV listings si pt alte canale,ami jos e lista cu files.Fiti atenti trebuie sa aveti instalat pe script plug in.
Here are some scripts for TV listings for Ipbox 9000 HD
In the file there are the following scripts:
scrplg-Dutch.sh
scrplg-Ex-Yu.sh
scrplg-france.sh
scrplg-French_Movie_Channels.sh
scrplg-German.sh
scrplg-Nova.sh
scrplg-Orbit.sh
scrplg-Other_Channels.sh
scrplg-Portugal.sh
scrplg-PPV_Movies.sh
scrplg-Premiere.sh
scrplg-Scandinavia.sh
scrplg-Sky_Cinema.sh
scrplg-Sky_It.sh
scrplg-Sky_Movies_UK.sh
scrplg-Sky_Uk.sh
scrplg-Spain.sh
scrplg-Tv1000.sh
Put the files with a ftp programme to var/bin, attibutes 755.
Many thanks to Rocknroll for the source for these TV listings.
Enjoy it
http://rapidshare.com/files/132406682/TV_GUIDES.rar
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 71
@otheitis
Pune te rog aici pluginul pentru update automat keys.
Va fi de ajutor pentru toti.
Multumesc.
Rog stergere post dupa aceea.
HDTV to MPEG2
Este un program cu care puteti sa schimbati pe Ts la mpeg2.
Adica toate inregistrari care aveti la HDD lui ipbox.Puteti sa
il schimbati de la Ts in MPEG2.
http://www.upload-drive.com/1584/HDT...2_v1_11_94_zip
http://ipbox.creare-forum.com
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Usefull tools
I have compiled some useful tools for Sifteam image with hdd:
joe. Joe is world-famous Wordstar like text editor.
mc. Midnight Commander is a file manager.
curl.Without ssl. Curl is a command line tool for transferring files with URL syntax, supporting FTP, FTPS, HTTP, HTTPS, SCP, SFTP, TFTP, TELNET, DICT, LDAP, LDAPS and FILE. curl supports SSL certificates, HTTP POST, HTTP PUT, FTP uploading, HTTP form based upload, proxies, cookies, user+password authentication (Basic, Digest, NTLM, Negotiate, kerberos...), file transfer resume, proxy tunneling and a busload of other useful tricks.
dropbear. A small ssh2 server
Other libraries
Installation: Copy and paste in telnet connection
wget http://www.dreamcamip.com/files/serg...ack.sh4.tar.gz -O /var/tmp/powerpack.tar.gz
tar -zxvf /var/tmp/powerpack.tar.gz -C /hdd
/hdd/extras/install.sh
http://www.upload-drive.com/1783/ser...ck_sh4_tar_tar
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
