Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: IPBOX 9000 **ABCOM firmware**
    VIP PETER36's Avatar
    18 Jan 2009
    Default Re: IPBOX 9000 **ABCOM firmware**
    NEW- Firmware AB_9000HD_r9341 1. Added automatical services moving when PMT_PID is changed on channel.
    2. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
    3. Fixed the bugs that doen't display TTXT on the specific page.
    The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V
    4. Update trick speed in File play and live banner Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2)
    Advanced : X2, X4, X8, X16 and (X1/16), (X1/ , (X1/4), (X1/2)
    5. ADD Proportional jump function in File play If you press the numerical button in File play, it works as below.
    - Press “1” : Jump to 10% of the recorded file
    - Press “2” : Jump to 20% of the recorded file
    - Press “3” : Jump to 30% of the recorded file …………
    - Press “0” : Jump to beginning of the recorded file
    6. Updated Russian language.
    7. DB upgrade to version 9274. You can upload settings from older versions with PC Editor 1.2.50 and later.
    http://www.mediafire.com/?sharekey=d...9e3e240b8446b3
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default ABCOM r9580
    AB release r9580: ( 29/May/2009)
    1. Add function displaying time always on Front panel
    2. Add schedule recording title name on webif
    3. Fixed video player panic when spdif is off
    4. Fixed slow icon on TrickPlay and FilePlay
    5. Mapping blue key as check key for 91HD in filebrowser
    6. Change HDD clean process on hddinit script
    7. Syunchronized sleep Mode as power_control option
    8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
    9. Update TP information Thor0.8W and Astra 19.2E
    10. Fixed many small bugs
    Note.
    1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
    As you know, even if the Filename Extension is different each other,
    if the video codec is same each other, the two files work like same.
    If the video file's resolution is more than 720 X 576, it will works very well.
    So, we recommend below conditions.
    1) resolution : 720 X 576.
    2) FPS : 24, 25 and 30 fps.
    3) Following video and audio codec.
    Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
    Audio Codec : MP2, MP3, AC3
    When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
    If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
    2. ext3 file system is slower than ext2 normally.
    If you record two HD channels with ext3 at the same time, it may fail in record.
    we have checked the speed as below
    ext2 speed : approximately 7MB/s
    ext3 speed : approximately 3MB/s
    Known issues(on going).
    1. Artefact with Premiere HD channels from satellite or cable.
    Caution.
    1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
    2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
    http://www.upload-drive.com/file/67/...oboot-zip.html
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
