Dislikes:
IPBOX 9000 **SIFTEAM firmware**
Aica o sa gasiti toate sifteam firmware pt ipbox.
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Re: Ipbox 9000 **SIFTEAM firmware**
This is the new Firmware from the Sifteam.You can make upload like the others versions with flashtools.Now you can download all plug in,settings,cam from the special menu which can you find in menu plug in.
SifTeam-0.08-r7043
*From 0.08:
Upgraded WebIf (remove any options)
Added Sif_Install Plugin
Added Sif_Remove Plugin
Added Sif_Setcam Plugin
red.sh Star/Stop Default Cam
green.sh show ecm_info
yellow.sh Restart Default Cam
Other change not remember
usb_kernel_root_db.img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
From 0.09:
Change management skin.
Plugins report info.
Added Sif_Setskin Plugin.
BUG Fix, ..and add new?
red.sh Star/Stop Cam.
green.sh show ecm_info.
yellow.sh Restart Cam.
ftp://9000hd.sifteam.eu/9000HD/Firmw...am-0.09-r7043/
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1
*From 0.1:
More plugins change
More Options added
No password for root
..change yourself with "passwd"
..command from telnet
No password for webif
..add yourself in file
../var/etc/httpd.conf
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
SifTeam-0.1.1-r7473
*From 0.1.1:
Added jpeg support for background
Added jpeg to base plugin
Add option for umount usb (if
mounted from automount
ftp://9000hd.sifteam.eu/9000HD/Firmw...m-0.1.1-r7473/
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
*From 0.1.2:
From default use DGS webif
For use old webif ..connect to:
h**p://DECODER_IP/sifteam.html
New MP3 player use dir named "mp3"
Please change /hdd/MP3 to /hdd/mp3
Removed from addons-online:
Skin @Crash
Plugin Mp3-player
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
*From 0.1.3:
Modifyed Standby Hard Disk System
From default is 0
For change this value, ..create file:
/var/etc/SifTeam/conf/time_sleep_hd
And add your personel value
Possible value is 12*M (M=minutes)
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.4b
*From 0.1.4B:
Module for card reader is OK
Sorry for inconvenience.
http://www.upload-drive.com/1778/usb_kernel_root_db_img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.4c
*From 0.1.4C:
Other bug fix in file
/var/etc/rcS.d/S99user_start.sh
..is set 900hd server for net upgrade
http://www.upload-drive.com/1780/usb_kernel_root_db_img
http://ipbox.creare-forum.com
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.5
#################### SifTeam-0.1.5-r8022 ####################
versions.8793303423:SifTeam-0.1.5-r8022.app_db=SifTeam-0.1.5-r8022
[version.desc.SifTeam-0.1.5-r8022.app_db]
Based on "OFFICIAL" SVN revision r8022.
Your database will be reset, if download this version.
*** NO KEY-EMU INSIDE ***
*From 0.1.5:
Added panel whit red button
Download from here...
http://rapidshare.de/files/40308630/...ot_db.rar.html
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Re: Sifteam 0.1.5
Asta update puteti sa il luati prin sifteam plugin install
upgrade-31_08
Added:
All plugin is changed, now is visualized as window and use skin active.
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.6
*From 0.1.6:
Added kneubi script plugin, modified
for new SIF panel system
(Removed kneubi script from online)
Modified more script (for print in LCD)
Added "sdparm" (like hddparm, for USB_HD)
http://rapidshare.com/files/14395157....1.6-r8022.rar
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Sifteam 0.1.7
Sifteam 0.1.7 r8107
*From 0.1.7:
Added more change in any script.
Remove Sif_System plugin
..use kneubi script for default.
usb_al_noboot.img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
SifTeam 0.1.7-r8107 06.10.08
* From 0.1.7 06.10.08
lan bug fixed
usb_all_noboot.rar
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
SifTeam 0.1.8-r8314
*From 0.1.8:
Added more change in script.
Acuma are nou firmware r8314
NEW RELEASE r8314: Added or improved Function
1. Fixed Swaping PIP
2. Fixed Audio Language Preferences.
3. Fixed an combination of USALS and Diseqc
http://dreambox.sifteam.eu/index.php...all_noboot.img
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
