Results 16 to 30 of 44
Thread: DOLCE in CCcam
    Default Re: DOLCE in CCcam
    Quote Originally Posted by gobi2000 View Post
    2: in var/tuxbox/config/ vei avea fisierul "newcs"
    cam asta at fi!!!
    cam asta at fi!!!
    Nu este,vroiam varianta cu pusul in cfg CCcamului cum e specificat aici;
    Originally Posted by simplul
    la mine cardul de dolce functioneaza in cccam doar cu boxkey-ul in cccam.cfg si merge fara nici o problema. nimeni din partenri de share nu mi-au spus ca asa avea probleme
  3. #18
    cam asta at fi!!!
    Am reusit! am pus boxkeyul aici trec seria cardului?
    <newcamd_port>portul cardului</newcamd_port>
  4. #19
    Standard RSP member simplul's Avatar
    Timisoara
    Unde pui box-keyl in CCcam-cfg? ca mam uitat dar....nu gasesc unde sa il pun.
    scuze ca revin cu greu
    ### Config File Created by Cam-Editor ###
    ### Cam-Editor ©2006 Oermens ###
    #### Friends ####
    F: xxxxxxxxxxx
    #### Servers ####
    C: xxxxxx
    N: xxxxxxxx 4040xxxx xxxxxx 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    #### Config ####
    ALLOW WEBINFO: yes
    WEBINFO LISTEN PORT : 16001
    WEBINFO USERNAME :xxxxxx
    WEBINFO PASSWORD :xxxxxxx
    ALLOW TELNETINFO: no
    TELNETINFO USERNAME :
    TELNETINFO PASSWORD :
    TELNETINFO LISTEN PORT : 16000
    # SERVER LISTEN PORT : #
    SERVER LISTEN PORT : 12000
    # ZAP OSD TIME : #
    ZAP OSD TIME :0
    # OSD USERNAME : #
    OSD USERNAME :root
    # OSD PASSWORD : #
    OSD PASSWORD :voodoo
    # PHOENIX READER PATH : #
    # EMM Blocker #
    # SHOW TIMING : #
    SHOW TIMING : yes
    # DEBUG : #
    DEBUG : no
    # NEWCAMD CONF : #
    NEWCAMD CONF :no
    # DISABLE EMM : #
    DISABLE EMM : no
    # EXTRA EMM LEVEL : #
    EXTRA EMM LEVEL : yes
    BOXKEY : /dev/sci0 xx xx xx xx
    # BEEF ID : #
    # PINCODE :
    # SOFTKEY FILE : #
    # AUTOROLL FILE :
    # STATIC CW FILE :
    # CAID IGNORE FILE :
    CAID IGNORE FILE : /var/keys/CCcam.ignore
    # LOG WARNINGS : #
    LOG WARNINGS : /tmp/warnings.txt
    F: massi massi no
    ####### Enjoy #######
  5. #20
    Multumesc tuturor,pana aici am reusit,mai ramane sa configurez liniile.
  6. #21
    1: seria boxului ultimile 10 cifre le pui in calculatorul de la pc (mai putin ultima cifra deci vei avea 9 cifre apoi transformi in hexa vei optine "7" caractere la toate acestea mai adaogi un "zero" in fata celor 7 optinand 8 caractere
    2: in var/tuxbox/config/ vei avea fisierul "newcs" in care pui serialul optinut
    3: configuratia o vei face in felul urmator:
    <?xml version="1.0"?>
    For setup-issues, look in readme.txt!
    If there are other troubles, try different forums or irc channels around )
    <newCSconfig>
    <readers name="Card Readers">
    <device>
    <name>lower</name>
    <type>Sci</type>
    <node>/dev/sci0</node>
    <export>yes</export>
    <enabled>yes</enabled>
    <blocksa>Yes</blocksa>
    <blockua>Yes</blockua>
    <blockga>Yes</blockga>
    <mhz>600</mhz>
    <boxkey>seria boxului</boxkey>
    <rsa></rsa>
    <crypto-special>no</crypto-special>
    <carddetect>yes</carddetect>
    <autosid>no</autosid>
    <priority>round</priority>
    <sid>
    <allow>
    <!-- valid value for id are:
    4 numbers, if the service id is 3 numbers, add a 0 infront of it. -->
    <id></id>
    </allow>
    <deny>
    <id></id>
    </deny>
    </sid>
    </device>
    </readers>
    <radegastserver>
    <!-- valid value for enable are:
    0,1 - Enable or Disable radegast server. -->
    <enabled>no</enabled>
    <!-- valid value for port are:
    0,65535 - Which port to listen for incomming connections. -->
    <port>10001</port>
    <!-- valid value for allow are:
    ALL - Not active yet. -->
    <allow>
    <hostname>127.0.0.1</hostname>
    </allow>
    </radegastserver>
    <cache>
    <emm>20</emm>
    <ecm>-1</ecm>
    </cache>
    <debug>
    <!-- valid value for level are:
    normal, verbose, spam - How extensive debug should be. -->
    <level>normal</level>
    <!-- valid value for type are:
    Init, general, ecm, emm, net, all - Section of debug that should be displayed. -->
    <type>init,general</type>
    <!-- valid value for output are:
    Console, udp, tcp, file, all - Where to show debug. -->
    <output>tcp,all</output>
    <!-- console_options are so you can set own loglevel/type for console-logger:
    Should hold level and type-tags like above. -->
    <console_options>normal,init</console_options>
    <!-- valid value for logfile are:
    Path and filename - Where to write debug logs if file or all is chosed in output. -->
    <logfile></logfile>
    <!-- file_options are so you can set own loglevel/type for file-logger:
    <file_options></file_options>
    <!-- valid value for udp_host are:
    IP-address or DNS-name - Where to send debug if udp or all is chosed in output. -->
    <udp_host>127.0.0.1</udp_host>
    <!-- valid value for udp_port are:
    0,65535 - Which port to send the udp packets. -->
    <udp_port>1000</udp_port>
    <!-- udp_options are so you can set own loglevel/type for udp-logger:
    <udp_options>normal,init</udp_options>
    <!-- valid value for tcp_port are:
    0,65535 - Which port to listen for incomming tcp connections. -->
    <tcp_port>1001</tcp_port>
    <!-- tcp_options are so you can set own loglevel/type for tcp-logger:
    <tcp_options>normal,init</tcp_options>
    </debug>
    <newcamdserver>
    <name>dolce</name>
    <userfile>/tmp/users.txt</userfile>
    <user>
    <name>un nume uzual la alegere</name>
    <password>o parola la alegere</password>
    <au>on</au>
    <spider>Yes</spider>
    <hostname></hostname>
    <port></port>
    </user>
    </newcamdserver>
    </newCSconfig>
    doar ce am scris cu rosu are nevoie de editare!
    Nu reusesc,nu citeste cardul,unde gresesc?
  7. #22
    Timisoara
    ai incercat varianta trimisa de mine?
    (am incercat sa dau de tine pe mess)
  8. #23
    Quote Originally Posted by simplul View Post
    Am incercat,am pus boxkeyul dar nu vrea,mai trebuie pus ceva?
  9. #24
    Timisoara
    la mine am pus boxkey-ul si a mers din prima, ce am trimis mai devreme este configul meu, de unde am taiat doar linile si parolele. Cccam-ul l-ai instalat bine?
  10. #25
    CCcamul e dat jos direct de pe server,folosesc geminii 440
  11. #26
    Standard RSP member ag.laur's Avatar
    RO
    Question Re: DOLCE in CCcam
    salut,
    dar linia F si C specifica ip dm ai facut-o?
    F: user pass
    C: 192.168.0... 12000 user pass no { 0:0:2 }
  12. #27
    Quote Originally Posted by ag.laur View Post
    salut,
    F: user pass
    Nop,trebuie si asta ca sa-ti vada cardul si sa deschida programele?
  13. #28
    RO
    Post Re: DOLCE in CCcam
    eu zic ca da
    incearca si creeaza aceste 2 linii cu ip dm ,user pass ce doresti
  14. #29
    eu zic ca da
    OK! o sa incerc din nou diseara,ms,mult!
  15. #30
    cardul dolce in cccam este deschis de fisuerul "newcs.xml din var/tuxbox/config
    fara de care nu recunoste cardul
