Results 1 to 14 of 14
Thread: Pheonix soft
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Pheonix soft
    Era un soft de programare pentru pheonix pe serial cu o banana, il mai are cineva sau ce alte softuri mai aveti?
    Standard RSP member pytonu's Avatar
    Navodari
    Default Re: Pheonix soft
    Vezi daca te ajuta asta cu ceva.
    All round Phoenix smartcard programmer for all current smartcards like titanium, MII, KNOT, funcard and MII smartcards. Can easily be used to update a cam like the Joker or Matrix. Switches automatically between different modes. Reading/writing of the whole card is done without intervention. Loaders are in the program. Cards currently supported: titanium, MII, KNOT, Funcard, Jupiter1, Jupiter2, GoldCard, PicCard2. Easy to use. Crd EEPROM file support. The RS232 Cardreader is an encased programmer which can be used for EEPROM, AVR and PIC programming.
    The required RS232 Cardreader is capable of the following modes:
    Phoenix 3.57MHz and 6MHz for EEPROM programming like Titanium, MII, KNOT or Funcard
    Smartmouse 3.57MHz and 6MHz
    JDM mode for PIC programming like in a goldwafer and piccard2
    AVR SPI mode for Jupiter 1 and 2 & Funcard you can free download CardPro 2.0.1.0 now.
    cardpro.zip - 0.38MB
    Pot sa-ti mai dau CDSTUDIO care a fost postat peaici pe forum.
    Sunt cam multe.....
    05 Jan 2007
    Multumesc mult dar nu vrea sa lucreze cu pheonixul. In schimn programul pentru alt tip de programator e fain tare.
    aceeasi chestie si la mine nu vede cardu, ezista o solutie? o setare care trebuie sau cu jumperi?
    05 Jan 2007
    Cred ca trebuie un alt programator
    sa fie de vina vre-un dll din sistem32?
