Results 1 to 15 of 15
Thread: Optibox HDCX
    O zi frumoasa! Snow's Avatar
    Default Optibox HDCX
    Un nou receptor HD se gaseste pe piatza. Costa 699 si-l puteti cumpara de la http://digitalsatelit.ro/shop/produc...roducts_id=154
    Date tehnice:
    1 interfata Smart Card cu modul Conax sau Multicas incorporat
    Memorie pentru 6000> Canale
    Ghid de program electronic (EPG)
    Functie de cautare Manuala & Automata
    suporta HDMI (High Definition Multimedia Interface)
    Meniu OSD in mai multe limbi
    3 Moduri de operare (Digital TV, Digital Radio, Favorit)
    Functie Parental Lock
    Suporta Teletext via VBI & OSD
    Memorie ultimul canal vizionat
    Tensiune de alimentare: 90~240V AC 50/60 Hz
    Consum de curent: max 45 W
    Temperatura de operare: 0°C ~40 ° C
    Dimensiuni (LxIxL) in mm: 280x60x245
    Greutate: 2,0 kg
    Tuner:
    Input Frequency Range: 950~2150 MHz
    Nivel de intrare RF:-25~-65 dBm
    Tensiune LNB: 13/18 V DC (+(- 5%)
    Max. 500 mA
    Ton 22kHz: 22+/-4kHz, 0.6 +/- 0.2Vpp
    Decodor Video:
    Profile level: MPEG-4 part10 (H264) Level4
    MPEG-2 MP@ML; MP@HL
    Rezolutie Video: 1080i; 720p; 576p; 576i(PAL)
    Format afisare: 4:3, 16:9(Letter Box)
    Demodulare:
    Modulare: QPSK; 8PSK
    Introducere rata simbolurilor: DVB-S: 2~45Ms/s
    DVB-S2: 10~30Ms/s (QPSK); 10~30Ms/s (8PSK)
    Sistem si Memorie:
    Procesor: STi7100
    Memorie Flash: 8Mbyte
    Memorie Sistem: 64 Mbyte DDR-SDRAM
    Memorie Video: 64 Mbyte DDR-SDRAM
    EEPROM: 16 kbyte
    Decodor Audio:
    MPEG/MusiCam Layer I & II
    Sampling Rate: 32,44.1 & 48KHz
    Mod Audio: Mono/Dual Mono/Joint Stereo/Stereo
    Conectoare:
    HDMI
    Intrare SAT
    Iesire SAT (Loop Out)
    2 SCART TV (RGB, CVBS)/ VCR(RGB, CVBS)
    RCA/Compozit Video(CVBS)/Audio Stanga & Audio Dreapta
    S/PDIF(Optical)
    RS232: port serial cu 9 pini D RS232 DCE
    va urma....
    Default Re: Optibox HDCX
    sa fie fratele mai mic, produs de aceeasi firma : http://www.globostb.com/?cmd=select&...03407821907264 produs de vecini nostri :http://www.globostb.com/?cmd=contact fiindca la noi : http://www.globostb.ro/receptoare.htm liniste deocamdata.
    da, e fratele mai mic.
    se poarta, nu?
    pai uite si fratele mai mare la aceeasi firma de la noi la vanzare : http://digitalsatelit.ro/shop/produc...roducts_id=128 si din cate am citit pe acest forum este un model fara linux, deci mai mult ca sigur ca si fratele mai mic impartaseste aceeasi chestie "fara linux" pacat.
    da, practic e acelasi receptor, fara Ci si fara VFD, are afisajul normal
    26 Mar 2009
    Cine poate sa ma ajute sa fac upload la HDCX
    am load si pr
    17 Apr 2008
    Spune ce doresti sa faci...
    26 Mar 2009
    Am un OPTIBOX HDCX MPEG4 (H264) HDTVcu versiunea de soft din 09.10.2008 Am introdus kei si nu se vad decat o parte din programe. Celelate nu le decodeaza. Ma poate ajuta cineva ?
    17 Apr 2008
    nu ai rezolvat nici akum?
    26 Mar 2009
    Acest receptor numit Optibox HDCX este membru PCR . Celelalte programe le decodeaza numai dupa ora 00. Cred ca am sa-mi schimb porgramul sa fiu in ton cu el. Ma poate ajuta cineva ?
    Reula 12.
    26 Mar 2009
    Azi 08.04.2008 am reusit .Deoarece nu ma prea pricep vreau sa-ti da un soft ca sa il pui la sectiunea optibux hdcx ca sa nu se mai chinuie si altii. Softul este din 20.11.2008. Si sa pui si k deoarece acest tip de receptor citeste doar acest tip de fisier.
    QUOTE=mesterika;77292]nu ai rezolvat nici akum?[/QUOTE]
    09 May 2009
    Cum fac si eu rost de softul de la optimbox hdcx ???
    17 Apr 2008
    softul original ? sau un emu?
    27 Aug 2009
    Prima oara vreau sa va salut pe totiVa rog daca poti sa-ma ajuti cu ceva sfaturi.am cumparat un optibox 8750 am introdus ultima varianta de soft am activat emu dar vad ca nu da drumul la gigima puteti ajuta cu un sfat daca vreti!!!Mersi!!!!!
