- Rep Power
- 68
Re: AzBox HD
salutare!
Am dm800.. dar as testa si un mbox..
ma gandesc sa cumpar un Azbox pt al doilea rec hd si media player hd.
din ce vad eu pe site uri diferentele sunt intere Elite si Premium.
Wlan incorporat , flash 32 fata de 16 mb si inca un port USB pt Premium, mai e ceva semnificativ?
Wlan e incorporat sau trebe sa cumperi ceva pe usb, etc?
cum se comporta wifi-ul? pica la un anumit trafic? etc?
banuiesc ca se poate pune hdd pe usb pe unul din porturi?
Internet WebCam Viewer
Internet WebCam Viewer Plugin
There is new plug-in from Kanber_Kav, and it is Internet WebCam Viewer. Watch thousands of Internet Web Cams arround internet ( City, Sex, Games etc )
Installation:
Extract archive webcamview.rar and You will see two files ( webcamviwer.plugin and plugins.lst ).
Copy that Files to USB or simply transfer them by FTP to /tmp folder of Your AzBox HD, and now enter on TV in Plug-ins, press Red Button on Remote controller to add plug-in.
If You are using USB select to install it from USB, or if You transfered files to /tmp folder install it from tmp folder.
Thanks to Kanber_Kav
http://www.sendspace.com/file/28y762
Azbox GoogleMap plugins
Azbox GoogleMap Plugins...
Link...
http://www.mediafire.com/?ll2ygjzimoo
/tmp folder extract
Azbox plug-ins
red button
install/tmp/plugins.lst
Hadi kolay gelsin
yellow and blue button step..
step=1 fast moving
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- Rep Power
- 73
Re: AzBox HD
NEW Firmware 0.9.2372
fixed DVB-C
http://azupd.com/0.9.2372/patch.bin
update via usb
Re: AzBox HD
llink is a media streamer that let's you play movies, view online trailers, browse images or play music over a network using the http protocol. It should work with most Syabas NMT hardware (NetworkedMediaTank middleware based players), such as the Popcorn Hour A- and B-series, HDX, iSTAR, Egreat a whole range of others, possibly even a couple of older ones like the LinkTheater. Some of the best reasons to run llink is that it can run on a great many platforms, including most popular NAS devices - even on the NMT player itself - and it can play media directly from RAR files.
More info on :
Code:
http://www.lundman.net/wiki/index.php/Llink
Features:
Code:
* Parses various video containers: vob, avi, ts, mkv, tp, mov, m2ts, evo.
* Streams any file type the NMT player can handle: mp3, flac, jpeg, png etc.
* Can play straight from rar files: no more need to unrar your media. (Comes with special unrar-3.7.8-seek.)
* SSDP / UPnP discovery support (although minimal).
* Skin support: make your own html templates or choose from pre-built.
* Simple iMDb querying to look up media information for Jukebox skins.
* Both HD and SD skins available.
* Light, tiny and clean code for Unix, OsX and Windows.
* Paginating: support to send listings in pages, with tags for Next/Prev.
* PlayAll cgi tag, and PlayAllFrom.
* External subtitles: subtitle files can be consolidated in one directory.
* libdvdnav support (and libdvdcss): provides basic playback of DVD .iso and .img files and from DVD drives.
* UDF 2.50 BD5-ISO support: provides basic playback of Bluray and HD-DVD.
* (External process support, like mencoder: incomplete).
Installation :
Extract files from llink-2.2.0-nmt.tar.gz , You can transfer files to /EMU , /tmp or to transfer files on USB stick [img]images/smilies/smile.gif[/img]
Give CHMOD 77f to llink and unrar files.
Now You have to connect to AzBox HD with putty ( telnet or ssh ) and to start it with :
./llink
Configuration file for skins and ports are in llink.conf file
http://www.sendspace.com/file/hwltcc
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- Rep Power
- 0
Hellassat 2 39' 11012 V not working on Azbox
A incercat cineva TP 11012 V de pe Hellas pe Azbox?
La mine arata semnat 86 si calitate 0. Nu pot sa scanez, nu gaseste nimic.
Ma tot gandesc, e pb la LNB-ul meu? restul TP-urilor sunt ok.
Am setat si DVB-S2/8PSK si nimic.
- Rep Power
- 65
Re: AzBox HD
Da , merge cu sw 2371 - acum sunt 21 canale .
- Rep Power
- 0
Re: AzBox HD
Salut Valerica, merci de raspuns.
eu am actualizat ieri la 2372 si nu mi-a mers. Oare aici sa fie problema? Sa fac un downgrade la 2371?
- Rep Power
- 65
Re: AzBox HD
Salve ,
Varianta 2372 nu are in + decat search pt. dvb-c , deci nu ne foloseste . Inca ceva : pune toti parametrii transponderului in menu , nu lasa nimic pe auto ; poti sa te joci si la frecv. +/- 1-2 MHz .
- Rep Power
- 0
Re: AzBox HD
tot nu merge, chiar daca am pus 2371
am incercat sa pun in loc de 11012 V, 11010 , 11015 dar tot nimic. Am pus SR-ul la 30000 si FEC-ul la 3/4, totul e ok. Dar tot nu merge.
Interesant e ca nivel semnal e totusi la 86, dar calitate 0.
Am incercat si alt TP de low 10956 V si acelasi lucru, calitate 0. de la 11512 H am si calitate, si pot scana.
Ma tot gandesc sa nu fie o pb la tuner? sau la LNB?
- Rep Power
- 65
Re: AzBox HD
Poate mai exista in lista frecventa (memorata anterior) cu alti parametrii .
Daca e asa , trebuie sters transp. si adaugat iar cu param. buni . Sau daca ai unde , probe pe alta antena ....
- Rep Power
- 0
CCcam v2.1.1 Auto-Install v1.6
Changes:
-> [+] Add unistall
by terrorman
http://www.sendspace.com/file/urlrhy
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
New Firm 0.9.2880
Changelog:
Fixed - SmartCard driver is updated because internal smartcard is sometimes reset or crashed
Fixed - Using at least the 3 last firmware releases (0.9.2163, 0.9.2371 and 0.9.2372), the WIFI has some problems related with WEP(64/128) encriptation 1. Prevented the box from booting 2. Not possible to use the wireless connection
Fixed - DVB-C - Search of frequenz < 177 Mhz is not possible ("Out of range")
Fixed - DVB-C - Search-Mode Automatic ist not working
Fixed - When selecting GUIDE on TVP sports, Box hangs up.
Fixed - Moving of more than one channels shows error message
Added - Germany DVB-C Frequency
Added - Turkish OSD language
Added - AC3 audio file is supported.
http://rapidshare.com/files/260176339/patch.rar.html
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
