Results 1 to 9 of 9
Thread: oscam interface
    04 Oct 2008
    Default oscam interface
    Salutare, am un DM900, cu Teamblue instalat+oscam11865, dar nu pot accesa oscam webinterface, prin portul 8888.
    Va las mai jos datele din oscam.user, oscam.server respectiv oscam. conf:
    oscam.user
    [account]
    user = DreamOSat
    keepalive = 1
    monlevel = 4
    au = 1
    group = 1,2,3,4,5,6,7,8,9,10
    oscam.server
    [reader]
    label = C+line_server
    enable = 0
    protocol = cccam
    device = hostname,port
    user = user
    password = pass
    services = !powervu_fake,!tandberg_fake,!biss_fake,!afn_fake
    inactivitytimeout = -1
    reconnecttimeout = 12
    disablecrccws_only_for = 098C:000000;09C4:000000;098D:000000;0500:030B00,032830,041950,041960,042800,042820,043800,050F00,051 A00,051A10,060A00,060C00;1709:000000;1802:000000;1810:000000;1811:000007,000107,023311,003311,003315 ,003341,00331B;1813:000068;1815:000000;1817:000000,00006A;1818:000000,000007,00006C;1819:00006D,0000 07;1841:000000;1880:000000;1883:003311;1884:000000;1708:000000;0E00:000000;091F:000000;09BE:000000;0 92B:000000;4AEE:000001;0B00:000000;0B02:000000;0D97:000000;0653:000000;092F:000000;0B01:000000;0963: 000000;0961:000000;0960:000000
    group = 1,2,3,4,5
    disablecrccws = 1
    cccversion = 2.3.2
    ccckeepalive = 1
    audisabled = 1
    [reader]
    label = N+line_server
    enable = 0
    protocol = newcamd
    user = user
    password = pass
    disableserverfilter = 1
    connectoninit = 1
    keepalive = 1
    group = 2
    disablecrccws = 1
    audisabled = 1
    [reader]
    label = cs378x_server
    enable = 0
    protocol = cs378x
    user = user
    password = pass
    keepalive = 1
    group = 3
    blockemm-g = 1
    disablecrccws = 1
    [reader]
    label = cs357x_server
    enable = 0
    protocol = cs357x
    user = user
    password = pass
    keepalive = 1
    group = 4
    blockemm-g = 1
    disablecrccws = 1
    [reader]
    label = constant.cw
    enable = 0
    protocol = constcw
    device = /etc/tuxbox/config/constant.cw
    caid = 2600,0B00,0B02,0500,0963,06AD,0940
    group = 1
    [reader]
    label = emulator
    protocol = emu
    device = emulator
    disablecrccws_only_for = 0E00:000000
    caid = 0500,0604,0E00,1010,1801,2600,2602,2610
    detect = cd
    ident = 0500:000000,007400,007800,021110,023800;0604:000000;0E00:000000;1010:000000;1801:000000,001101,00211 1,007301;2600:000000;2602:000000;2610:000000
    group = 1
    emmcache = 2,1,2,1
    emu_auproviders = 0604:010200;0E00:000000;1010:000000;2610:000000
    oscam.conf
    [global]
    logfile = /tmp/oscam-emu.log
    nice = -1
    ecmfmt = P: c:s:d:i #ECM_L:l #CW=w HOP:j
    disablecrccws = 1
    [cache]
    [cs378x]
    port = 13001
    suppresscmd08 = 1
    [newcamd]
    port = 12121@0000:000000
    mgclient = 1
    [cccam]
    port = 12000
    nodeid = 24D5EF28108C14E0
    version = 2.3.0
    reshare = 0
    #reshare_mode = 0
    #stealth = 1
    [streamrelay]
    stream_source_auth_user = DreamOSat
    stream_client_source_host = 1
    stream_relay_enabled = 1
    stream_relay_buffer_time = 2000
    stream_emm_enabled = 1
    stream_relay_ctab = 098D,0960,0961,0963,0919,093B,09CD
    [dvbapi]
    enabled = 1
    au = 1
    pmt_mode = 0
    request_mode = 1
    delayer = 60
    ecminfo_type = 1
    user = DreamOSat
    read_sdt = 1
    write_sdt_prov = 1
    extended_cw_api = 1
    demuxer_fix = 1
    boxtype = dreambox
    [webif]
    httpport = 8888
    httprefresh = 10
    httpallowed = 10.0.0.0-10.255.255.255,172.16.0.0-172.31.255.255,192.168.0.0-192.168.255.255,127.0.0.1
    Multumesc mult
    Arpi
    none
    01 Jan 1999
    acasa
    42 Post(s)
    porneste oscam? o vezi in procese pornita cu configuratia de acolo? ai verificat: httpallowed ?
    bafta
    04 Oct 2008
    Da, porneste.
    httpallowed: yes
    none
    01 Jan 1999
    acasa
    42 Post(s)
    acolo la httpallowed trebuie sa pui clasa ta de ip locala....
    porneste cu configuratia de unde trebuie?
    daca intri in ssh, si o opresti manual...cind ii dai drumu, tot manual, iti arata portul de webif in consola....
    ca sa fii sigur, pune:
    httpallowed = 0.0.0.0-254.254.254.254
    bafta
    04 Oct 2008
    Nu merge
    Nu se deschide pagina? Nu apare nimic?
    Schimba portul, oricum e recomandat sa nu lasi porturile default.
    [webif]
    httpport                      = 222222222221
    httpuser                      = blabla
    httppwd                       = blabla!
    httprefresh                   = 10
    httppollrefresh               = 10
    httpallowed                   = 127.0.0.1,192.168.xxx bla bla
    httpoverwritebakfile          = 1
    aulow                         = 300
    httposcamlabel                = duo4K
    Pune user si passw, nu stiu daca asta e cauza, n-am folosit niciodata fara
    04 Oct 2008
    Nu merge.
    E oare bun oscamul folosit? enigma2-softcams-oscam-all-images_11865-emu-802-arm+mips_all, luat de pe drembox4k.com, sectiunea oscam
    porneste oscam din linie de comanda
    /usr/bin/oscam -c /etc/tuxbox/config/
    Vezi daca porneste.
    In linia de mai sus iti pui caile tale, nu stiu daca ai asa
    Poate oscamul tau vrea configul in alta parte decat e uzual si asa il obligi sa porneasca cu configul tau
    04 Oct 2008
    Da, aici a fost problema, configul era in alt folder. Multumesc
