Robot
Most Wanted
- 82
ASUS ROG Ally X Priced at $799, Battery 40% Larger
We've had our eye on the ASUS ROG Ally X since last week. The Ally X started its life on the rumor mill as a design revision of the ROG Ally that corrects the location of its microSD slot away from a heat vent, before we learned that it's a whole new product positioned above the ROG Ally, which not just fixes the microSD slot, but also comes with a larger battery, and support for M.2-2280 NVMe SSDs to unlock the widest selection of aftermarket SSDs among any handheld console.
Mystery Lupin a source with ASUS leaks, suggests that the ASUS ROG Ally X could be priced at $799, which would be a $100 premium over the top-spec ROG Ally Extreme. For this premium, ASUS is dropping in a battery that's rumored to have a 40% higher capacity than the one the original ROG Ally Extreme comes with; and the sheer convenience of an M.2-2280 drive bay that has a 1 TB SSD. It's also rumored that ASUS may step up the memory size. The other hardware specs are unchanged—the processor is still an AMD Ryzen Z1 Extreme, the display is still that 7-inch 48-120 Hz VRR with 1080p resolution; and with an identical controller layout. ASUS is expected to launch the ROG Ally X on June 2.
More...
