Results 1 to 4 of 4
Thread: Overclock optimizarea vitezei
    Golden Member sateros's Avatar
    02 Mar 2007
    Romania / Piatra Neamt
    Default Overclock optimizarea vitezei
    Pentru a inbunatati viteza cardului de a trimite ecmuri si a avea o calitate optimala la serverul vostru iata cateva idei pt cei care folosesc cccam.
    Va sfatuiesc inainte de a incepe sa va uitati la ECM time al cardului asa va dati seama de inbunatatire daca nu e necesar nu folositi setajul
    Pentru cardul de max Viaccses Card setam in CCcam cfg
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 5500000 #slot lower(jos)
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 5500000 #slot upper(sus)
    Asta inseamna ca am marit frcvenza normala de la 3,57 mhz la 5500000 = 5.5mhz
    Pentru cardul Conax folositi
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 5600000 #slot lower(jos) conax de la 0.275 pana la 0.178
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 5600000 #slot upper(sus) conax de la 0.275 pana la 0.178
    Alte setari utile care le puteti incerca
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 8200000 (irdeto ECM 0.195 - 0.1370
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 5250000 ( nds ECM 0.210 - 0.191
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 5300000 ( Sky uk 0.191 - 0.172
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 5600000 ( conax 0.275 - 0.178
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 8300000 ( BULSAT IREDETO 2 PURPLE 0.215 - 0.151
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 8420000 ( SHOWTIME IREDETO 2 0.225 - 0.141
    SMARTCARD CLOCK FREQUENCY: /dev/sci1 4800000 ( SECA2 CARD )
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 6000000 ( jsc sport irdeto )
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 6400000 ( TOTAL TV nds ECM 0.150 - 0.110)
    Folosind usb smartreader+
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB0 7200000 #NL irdeto
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB1 6200000 #PW betacrypt
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB2 7200000 #Sexvieuw via
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB3 7200000 #MCT irdeto
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB4 7200000 #SRG via2.6
    SERIAL READER: /dev/sci0 6000000 #SKY ITALA
    dupa configurare verificati daca se vede cardul in http://ipdream:16001/entitlements
    bv rom3os
    24 Jun 2008
    Default Re: Overclock optimizarea vitezei
    multumesc pentru sfaturi
    04 Jun 2008
    eu am un DM 800 SI ARE UN SINGUR READER,deci tu ai spus ca:
    eu trebuie sa introduc ambele linii sau doar prima ?
    multumesc
    La DM cu un singur card reader de obicei e slotul de jos,dar daca le pui pe ambele nu e nici o problema.
