pentru activare emu oscam meniu + 6363
Gamma X+ DVB-C / T2 hybrid receiver
Digital Full HD DVB-C/T2 (H.265)
Linux OS cable receiver
Full HD cable receiver (DVB-C / T2 H.265):
The Gamma X+ is a powerful cable / Multimedia receiver. The combination of modern cable and terrestrial reception technology with the H.265 DVB-C / T2-capable tuner and extensive streaming solutions such as Stalker, Xtream or .m3u make it a multi-talent. It receives all free channels and is suitable for all well-known cable operators such as Kabel BW, Unitymedia, Vodafone, etc. Thanks to the adjustable autostart function, you can choose whether the device should start in TV or streaming mode. Of course, you can also play back the digital sound via the SPDIF interface on your soundbar or home cinema system, as long as it is supported by the station. Due to its small dimensions of only 13.5 cm x 8.5 cm x 2.5 cm, it can also be easily attached behind a TV set and operation is thus guaranteed by the supplied mini infrared mouse, which can be attached almost invisibly to the TV set But it also cuts a good figure free-standing and thanks to its 7-segment display it can show the set channel number or the time.
Specifications:
-New High Performance ARM Cortex-A7 CPU
Full HD Cable DVB-T2 Receiver (DVB-C/T2 H265)
-H.265 / HEVC (HD and SD resolution)
-Linux OS (high resolution user interface)
-7 segment display
-YouTube
-Stalker middleware & Xtream streaming capable
-Streaming capable (as a client)
-Internet radio & weather service
-Online software updates
-EPG (Electronic Program Guide)+Subtitles & Teletext
-DLNA support
-WiFi & 3G fähig via USB (separat erhältlich)
-Online Softwareupdates
connections
-Conax card reader
-HDMI output
-DVB-C/T2 tuner
-2 x USB 2.0 ports
-Ethernet port (RJ45 10/100 Mbps)
-AV output (3.5mm jack)
-Dolby Digital output SPDIF (optical)
https://www.golden-media.net/en/produktseite-gammax
