Results 1 to 7 of 7
Thread: Ustym 4K PRO
    24 Mar 2009
    Thumbs up Ustym 4K PRO
    Ustym 4K PRO
    4K UHD combo set top box with two tuners (satellite S2 and terrestrial/cable T2/C) with dual boot LINUX
    Specifications uClan Ustym 4K PRO:
    • Combination of 2 tuners: satellite S2 or S2X and terrestrial or cable T2/C
    • Multi-core 64-bit (4x 1.6 GHz) ARM Cortex A53 Hisilicon Hi3798MV200 processor with 15,000 DMIPS
    • GPU: Mali-450 multi-core high performance GPU
    • satellite fast tuner RDA5815m + Silabs Si2166-D60 demodulator
    • terrestrial or cable T2 / C fast tuner Maxlinear MXL608 + Altobeam ATBM7821 demodulator
    • 8GB eMMC flash memory
    • 1 GB RAM
    • 4-digit 7-segment white display
    • High speed 300 Mbps WiFi (2 external antennas)
    • High speed 1Gbps LAN
    Technical features:
    • DualBoot (can choose which operating system boot up)
    • Open source operating system Linux Enigma2
    • Denys_OS proprietary Linux operating system
    • Full support for HW MPEG-2, MPEG-4 AVC, H.264 and H.265 HEVC
    • Multistream and T2MI support
    • DiSEqC 1.0, 1.1, 1.2 and 1.3 (USALS) and Unicable compatible
    • 1x HDTV 2.0a TX output with HDCP 2.2 up to 4K @ 60Hz
    • Video Output Resolution: 4K / 2K UHD 2160p HDR, Full HD 1080p, 1080i, 720p, 576p, 576i and True 3D
    • HDR 10bit and HLG
    • PAL / NTSC support
    • Extended EPG and program timer reservation in EPG
    • Supports XMLTV EPG in DVB mode (Electronic Program Guide)
    • Channel change speed less than 1 second
    • Support for multiple language audio tracks
    • PIP HD and UHD (Picture in Picture)
    • Blindscan (blind channel search)
    • DD (AC3), DD+ support
    • Support for connecting to portals (WEB mode / Simply API)
    • Support for connecting to IPTV servers (.m3u .m3u8)
    • Support for connecting to WEB portals
    • Support for XMLTV EPG in IPTV modes (electronic program guide)
    • Chromium Browser with Mouse Support
    • Ffmpeq HW playback support
    • WEB interface for managing settings
    • Playback of 2160P H.264 and H.265 HEVC media
    • Record and TIMESHIFT in one moment
    • Online software update
    • PVR transmission recording (* optional)
    • Consumption 0.5W in standby
    • Power adapter 12V 2A
    • Dimensions 220mm / 125mm / 40mm
    • CE certificate
    https://uclan.tv/index.php?id_produc...duct&id_lang=1
    support:
    http://images.mynonpublic.com/openat...pen=ustym4kpro
    https://openpli.org/download/uclan/Ustym+4K+pro
    https://www.pur-e2.club/OU/images/in...dir=6.5/uclan/
    http://images.hdfreaks.cc/ustym4kpro/
    https://openspa.webhop.info/#Descarg...tym%204K%20PRO
    https://e2.pkteam.pl/index.php?dir=I.../HYPERION%208/
    26 Dec 2017
    poate cineva sa ma ajute, am cumparat receiverul a venit i-am dat drumul si a intrat openatv ca imagine imediat am pus alta cu recovery usb adica openpli merge super, insa sunt nedumerit spuneau in reclama ca are dual boot etc ca DEnis boot etc
    mi l-au trimis cu open atv si atat dupa cum am vazut
    se poate sti cum pun si imaginea aia denis, am gasito pe net dar sincer nu gasesc indicatii cum sa o pun pe receiver numai in rusa exista tutoriale o gramada, dar sincer rusa nu cunosc
    poate unul dintre voi mai experimentati sa imi dea o ideea de unde sa ma inspir
    receivarul e destul de fiabil si merge foarte bine pt banii dati, e peste vu zero cred eu.....
    multumesc
    24 Mar 2009
    da gasesti aici si pe engleza pdf ce si cum
    https://fex.net/ru/s/b8efbtt
    Poti pune pana la 6 imagini prin multi-boot, dar pentru asta ai nevoie de un card SD in slotul din spate.
    Apoi prin software management>flash online>downloaded images instalezi care imagine vrei
    26 Dec 2017
    am facut pasii dar nu am downloded imagines.......cum fac
    Le descarci pe un PC si le trimiti in /media/hdd. Trebuie sa aiba extensia mmc.zip sau multiboot.zip
