Thanks Thanks:  3
Likes Likes:  2
Results 1 to 5 of 5
Thread: AB IPBox ONE 4K
    Default AB IPBox ONE 4K
    AB IPBox ONE 4K S2X
    Features
    • 4K Resolution (UHD)
    • 2x DVB-S2X tuner
    • Processor: QUAD CORE
    • Flash: 8GB eMMC
      RAM: 2GB DDR4
    • OS: Android 8.0 Oreo
    • 1x card reader
    • TFT LCD display
    • 1x HDMI
    • 1x USB 3.0 + 1x USB 2.0
    • Built-in WiFi
    • Built-in Bluetooth
    • Video Format: 4: 3, 16: 9, Letter Box, Pan & Scan
    • Video Resolution: 10bit, Up to 3840 x 2160 @ 60fps, HDR10 Support
    • Ethernet RJ45: 10/100 Mbps
    • S/PDIF optical digital audio output
    • Video Format: 4: 3 Letter Box, 4: 3 Pan Scan, 16: 9
    • Video Decoding: ITU-T H.265 / HEVC & H.264, ISO / IEC 13818-2 MPEG-2, AVS & AVS +, VP6, VP8, VP9
    • Audio Decoding: MPEG I&II, MP3, Dolby Digital Plus, AAC-LC, HE-AAC V1 / V2
    • Audio Mode: Stereo / Mono / Left / Right / Exchange
    • Dimensions: 150mm X 100mm X 40mm
    View Technical specification
    Operation system
    OS Android
    System Resources
    CPU ARM Cortex A53, Quad core 64bit
    GPU High-performance multi-core Mali T450
    Storage Memory 8GB eMMC 5.0
    System Memory 2 GByte, DDR3 SDRAM
    MPEG Transport Stream A/V Decoding
    Transport Stream ITU-T H.265/HEVC & H.264, ISO/IEC 13818-2 MPEG-2
    AVS&AVS+, VP6, VP8, VP9
    Profile Level ITU-T H.265 Main 10 Profile@L5.1 high-tier
    MPEG-2 MP@HL
    Input Rate Max. 160Mbit/s (H.265)
    Video Format 4:3, 16:9, Letter Box, Pan& Scan
    Video Resolution 10bit, Up to 3840 x 2160@ 60fps, HDR10 Support, HLG
    Audio Decoding MPEG I& II,MP3,Dolby Digital Plus,AAC-LC,HE-AAC V1/V2
    Audio Mode Stereo/M ono/Left/Right/Exchange
    Rear Panel
    DC Power Jack 12V / 1.5A
    Tuner DVB-S2X
    Smart Card 1 x
    RJ-45 Connector 10/100Mbps
    HDM I Connector Version 2.0a, HDCP 2.2, HDCP1.4
    SPDIF Optical
    Side Panel
    1 x USB3.0
    1 x USB2.0
    USB3.0 and 2.0 Host Interface
    USB Memory Stick&HDD, HUB Support
    FAT, NTFS Support
    5Vdc, 500mA Max.
    On board
    Bluetooth Internal Antenna Yes. 4.0 + EDR
    Wifi Antenna Internal Antenna IEEE 802. 11b/g/n/ac, 2.4GHz/5GHz Dual band(2T/2R)
    Tuner Option
    Input Connector F-Type Female(Si-Labs SI2166) Support S2X
    Frequency Range 950M Hz to 2150M Hz
    Signal Level -25 to -70dBm
    LNB Power & Polarisation Vertical : +13.5V ± 0.5V Max 400mA
    22KHz Tone Horizontal : +18.5V ± 0.5V Max 400mA
    Frequency : 22KHz ± 4KHz, 0.6Vp-±p0.2Vp-p
    Diseqc Control Version 1.0, 1.2, USALS Compatible
    Demodulation QPSK & 8PSK
    Input Symbol Rate DVB-S : 1 ~ 55M bps / DVB-S2 : 1 ~ 45Mbps
    Front Panel
    TFT LCD 1.77 inch TFT LCD
    Power Supply
    Input Voltage AC 90 ~ 250V, 50/60HZ
    Output Voltage 12Vdc / 1.5A
    Type External AC to DC Adaptor
    Power Consumption(Watt) Stand-by Mode : Under 0.5W
    Physical Dimension
    Size(WXDXH) 150mm X 100mm X 40mm
    Net Weight 0.6 Kg
    Operating Temperature 0 ~ 45 °C
    Storage Temperature -10 ~ 70 ℃
    https://www.abcomeu.com/ab-ipbox-one
    https://www.abcomeu.com/download-software?category=33
    ---------- Post added at 20:06 ---------- Previous post was at 19:10 ----------
    FW 03.08.2022
    Info and link to satupdate...
    The software includes pre-installed applications:
    Antique TV
    Skylink Sk
    Skylink CZ
    O2 TV SK
    Magic GO
    Orange TV
    Watching TV
    HBO Max
    Changes:
    improved - Freesat card support on Skylink channels M7
    improved - option to backup CAM configuration files (menu/settings/backup)
    improved - paging in the channel list from the first position to the last and vice versa, just like in Enigma 2
    To download AB IPBOX One
    https://mega.nz/file/vWpFFY7A#E5OV2t...-Cu7Vze9n4iCoo
    To download AB IPBox TWO, TWO Combo
    https://mega.nz/file/uGYzzJKI#5sLCog...hrj697YauRrWVs
    Addon settings quote.
    Improved functionality with Skylink cards. Functional cards of the operator Antik and others.
    Improved - Freesat card support on Skylink channels M7
    After uploading the addon, the "Cam" submenu will appear in the "Live TV" application, in which you can set the basic functionality of oscam -
    connect to a remote server, create a local server from the receiver, or restart the oscam.
    How to upload an addon to the receiver:
    - copy the file "update.zip" on the USB key to the root folder
    - connect the USB key to the receiver and open the ATV Settings (the gear wheel at the top right of the initial Android launcher)
    - select "USB update" and select a USB key (e.g. sda1)
    The receiver starts uploading the addon and restarts itself after completion.
    How to set up the oscam configuration files themselves via a samba connection:
    - open the explorer program on the PC and enter the recipient's IP address in the top line in the form, e.g. "\\192.168.1.1" and confirm enter
    - the address book "ab" will be displayed, confirm enter
    - you will see the address tree of the receiver, the configuration files are in the "oscam" directory
    Warning: This setting is intended for more experienced users who know what they are setting. Changes in the configuration files may have an impact
    to display oscam data in the "Cam" submenu.
    oscam
    update-Addon citacky AB IPBox One rev.3
    https://www.mediafire.com/file/clkhp...rev.3.zip/file
    update-Addon citacky AB IPBox Two rev.3
    https://www.mediafire.com/file/z1q3x...rev.3.zip/file
    update-Addon citacky AB IPBox Two_Combo pre Pluste... rev.3
    https://www.mediafire.com/file/qgdsw...rev.3.zip/file
    Member Visitor kadletfero's Avatar
    13 Jan 2023
    Oradea, Alesd
    i use last update for two combo, from romanian cable(digi) freeze any free channel in 2 hour
    13 Jan 2023
    Oradea, Alesd
    I don't find cccam 2.3.9 for sky de, only 2.3.0 and oscam don't work with corect DIGI keys N 2111 00.., N 2111 01.., N 2111 M1..
    16 Feb 2009
    primul impact cu
    ipbox two combo 4k
    oribil,
    Netflix doar cel mobil merge,dar si ala e oribil,trebuie sa folosesti functia de mouse,altfel nu merge,cel oficial,da erroare ca nu poate fi rulat pe acest dispozitiv,.am incercat mai multe variante,..
    tunerul cablu ce ma intereseaza cel mai mult,ingheata ,merge sacadat nonstop,chiar si cu ultimul soft,
    Skyshowtime merge cat de cat ok,
    am auzit ca tunerul s.ar rezolva cu alta aplicatie live.tv (pe care inca o caut)
    imaginea pare mai buna ca pe vechiul meu amiko a4k ce a mers si inca merge(i.mi pare rau ca nu am luat amiko a6k dar poate asta o sa fac)
    vreau ceva sa mearga dvb-c ,netflix,showtime,in primul rand,si sa aiba si dvb-s2x
    initial ma orientasem spre gtmedia gtx combo,dar nu sant cu garantie in Ro,sau un mecool kt1
