Dislikes:
Amiko Impulse 3 Cable and T2
Impulse 3.
One Conax Embedded card reader
6000 channels (TV and Radio) programmable
External IR Sensor (Included in the package)
Mountable on TV (Sticker included in the package)
Two High Speed USB 2.0 Connection
Ethernet Connection & USB WiFi Support (Ralink RT5370 chip only)
RSS Reader & Weather Forecast Functions
Full HD (1080p) Output via Digital Video Output
Channel Recording to External Storage Devices
MORE FEATURES
Timeshift support
Channel Recording & Timeshifting Simulteniously (optional)
Channel switching time less than 1 second
True-color, User Friendly On-Screen Display (OSD)
Full Picture In Graphic (PIG) function
Electronic Program Guide (EPG) for on screen channel information
Subtitle supported
Teletext supported by VBI insertion and software emulation
Parental lock facility by channel and program event
Program and Channel information transfer from receiver to receiver
Exciting games embedded
Multi-Language support
Power Consumption in Stand-By: <0.5W
Tuner Type: DVB-T2 / DVB-C
Frequency Range: 48~862MHz
RF Input Level: -80dBm to -20dBm
Antenna power output: DC 5V at max 75mA, Overload protection
Demodulation: COFDM 1K, 2K, 4K, 8K normal and extended, 16K normal and extended, 32K normal and extended
Input Symbol Rate: 1.0 ~ 7.0Ms/s
Constellations: QPSK, 16QAM, 64QAM, 256QAM / Both rotated and non-rotated
Guard Intervals: 1/4, 19/256, 1/8, 19/128, 1/16, 1/32, 1/128
Code Rate: 1/2, 3/5, 2/3, 3/4, 5/6
System Resources
Main Processor: 333 MHz
Flash Memory: Serial Flash 8MB x 1
DDR RAM: DDRIII 1333 16bit 1Gbit
MPEG TS A/V Decoding
Transport Stream: MPEG-2, H.264
Input Rate: Max.120Mbit/s
Aspect Radio: 4:3, 16:9, Letter Box
Video Decoding: MPEG-4/H.265 SP@L3 to ASP@L5, AVC, HP@level 4.1, MP@level 4.1
Video Resolution: 720*480P/I, 720*576P/I, 1280*720p, 1920*1080i, 1920*1080p
Audio Decoding: MPEG-1/2,AAC-LC,HE-AAC,MP3,Dolby Digital plus
Audio Mode: Left / Right / Stereo/ Mono
Sampling Rate: 32, 44.1 and 48KHz
Power Supply
Input Voltage: 5V DC
Power Consumption: 18W Max
Stand-By Power Consumption: <0.5W
LAN: 10/100M RJ-45 Ethernet Connection
A/V & Data Input/Output
SCART: CVBS Video out / Audio L/R out
USB: One USB 2.0 slot
S/PDIF: Coaxial
IR Port: Internal & Jack Type
Physical Specifications
Net Weight: 0.25KG
Operation Temperature: 0°C~+45°C
Storage Temperature: -10°C~+70°C
Storage Humidity: 5%~95% RH (Non-Condensing)
https://www.amikostb.com/product/499-Impuse-3.
https://www.sat-support.tv/?a=downloads&dir=245
