Results 1 to 15 of 15
Thread: Amiko Viper 4K V40 Combo
    Thumbs up Amiko Viper 4K V40 Combo
    https://www.amikostb.com/product/493...r-4K-V40_Combo
    https://www.amikohome.com/api/file/f..._v40_combo-pdf
    Ultra HD DVB-S2X+ T2/C Digital SatelliteReceiver
    Linux OS
    1.6GHz Quad Core 64 bit CPU Hi3798MV200
    High-Performance Multi-Core Mali 450 CPU
    8 GB EMMC
    1 GB DDR3 RAM Memory
    1 x USB 2.0 Port and 1 x USB 3.0 Port
    100 Mbps Ethernet interface
    2.4G built in WiFi
    Smart Card Reader
    Up to 3840 x2160@60fps, 1 0bit,H DR 1 0 Support
    support e2
    pure2
    https://www.pur-e2.club/OU/images/in...dir=6.5/amiko/
    openvix
    https://www.openvix.co.uk/index.php/...-viper-4k-v40/
    openatv 6.4
    http://images.mynonpublic.com/openat...pen=viper4kv40
    openatv 7.0
    openatv 7.1
    http://www.digitalsatelit.ro/amiko-viper-4k-v40.html
    compatible e2 image
    OpenDroid
    https://opendroid.org/7.0/Vivant/ind...=dinobot4kplus
    openrf
    http://dev.nachtfalke.biz/nfr/feeds/...dinobot4kplus/
    openhdf
    https://images.hdfreaks.cc/dinobot4kplus/
    openvision
    https://images.openvision.dedyn.io/1...dinobot4kplus/
    openspa
    https://openspa.webhop.info/#Descarg...inobot%204K%2B
    - se descarca arhva si se extrage folderul intern pe un stick fat32
    - daca inlocuim o imagine OpenATV sau Pure2 .....redenumim folderul
    "dinobot" in "amiko" si va fi acceptata de bootloader
    update cu butonul VERDE apasat pe MENU la Boot
    - daca inlocuim o imagine OpenSPA pastram numele "dinobot"
    - upgrade cu VERDE apasat pe MENU la Boot !
    multumiri mihaip pt teste
    ---------- Post added at 18:47 ---------- Previous post was at 18:08 ----------
    openvision viper4kv40
    https://images.openvision.dedyn.io/1...ot/viper4kv40/
    corectare imagine compatibila
    openspa
    https://openspa.webhop.info/#Descarg...ot%204K%20Twin
    Official OpenBh Images 5.1 amiko viper4k v40
    https://images.openbh.net/?b=5.1%2Famiko%2Fviper4kv40
    16 Mar 2015
    Se poate folosi ca server pt dvb-c? Ma interesează sa ma pot conecta de pe telefon când sunt plecat din tara.
    Evident ca se poate folosi, e e2!
    Nu cred ca stie sa transcodeze in timp real, adica vei primi stream-urile integral.
    16 Mar 2015
    Adică?
    Trebuie schimbat canalul manual și tu vezi doar ce e pe canalul respectiv?
    17 Jan 2008
    Cum se face pentru canalele dvb-c?
    Am incercat pe Viper 4k si SF8008, dar am reusit doar pentru satelit.
    16 Mar 2015
    Cum se procedează în cazul în care vrei sa vezi canale diferite? Dar nu în același timp. Se poate schimba canalul remotely?
    Cel mai simplu e din interfata web, sau poate exporta și lista direct.
    16 Mar 2015
    Nu reusesc deloc sa fac streaming in reteaua locala.
    Pe orice canal dau (cablu sau satelit), fie ca apas pe iconita cu PC sau Smartphone, dau open la fisierul url generat cu VLC sau MPC si ramane pe buffering sau loading.
    https://ibb.co/yPD5L9S
    https://ibb.co/HdGD57X
    https://ibb.co/XLmjxZW
    https://ibb.co/pXRYSZ7
    https://ibb.co/JRF8n5G
    ---------- Post added at 03:01 ---------- Previous post was at 01:32 ----------
    Hai ca am făcut și o prostie: am dat update Openatv la 7.2 din meniu. După update a rămas în loop restart la imaginea cu Open ATV 7.2. După care o ia de la capăt. Neavând buton de recovery, i am dat după power on cu butonul verde când apare 'menu'. După apăsarea butonului verde scrie 'updt' dar se tot restartează și ajunge tot pana la Open ATV 7.2. Și de aici o ia de la capăt.
    19 Feb 2014
    Oradea
    Salutare! Cisco TFTP Server ai incercat ? ps:cred ca am facut-o de oaie vremurile cu Amiko Alien1 s-au dus...
    16 Mar 2015
    Am reușit sa fac streaming prin aplicația dream player pe android.
    Acum nu știu cum sa setez decodorul pt a face transcoding, tot prin dream player. Am încercat cu ambele porturi 8001 și 8002. Nu vrea cu niciunul. Am făcut port forward la amândouă. Pot sa fac streaming din exterior dar nu pot sa fac transcoding.
    Trebuie sa le setez din decodor? Cum fac asta?
    https://ibb.co/MMbXr9K
    https://ibb.co/CJrmgMZ
    Standard RSP member MCT's Avatar
    12 Oct 2011
    Va salut pe toti tocmai am cumparat receptorul daca va rog frumos ma ajuta cineva daca trebuie contra cost sa-l pun la punct adica oscam,icam etc sa pot viziona pachetul sky germany va multumesc anticipat
    12 Jul 2007
    in sud la dunare
    4 Post(s)
    Daca nu ai linie la schimb buna de Sky De nu ai ce viziona...
    RAPIDIST PUR SINGE
