Thanks Thanks:  2
Likes Likes:  1
Results 1 to 8 of 8
Thread: 1-Stream / Xcode
    Thumbs up 1-Stream / Xcode
    1-Stream / Xcode
    New code base, built according to modern standards
    Utilizing the capabilities of ELK stack for system monitoring and activity logging
    Ability to develop complex statistics and security features using the detailed logs in ELK without affecting system performance
    Has API for 3rd party integrations and full management of API clients and restrictions
    Distributed - full install on own servers with full control over them
    Fast growing list of supported streaming devices and apps
    Using newer technologies and best practices for software development
    Improved security connections for end users, but backwards compatible with the old connection methods
    Long list of planned features unique to the platform
    Multiple player support, including own player
    Stalker player for MAG devices
    Legacy software code, hard to extend
    Logging/monitoring performend in files/sql database makes it neccessary to keep data only for short period
    Hard to integrate with 3rd party systems
    Stopped developing
    Base for many copies
    Centralized ?? - installed on the provider servers
    Using outdated methodologies
    200 EUR/month Unlimited Load balancers FREE
    1-Stream 1.1.21 Nulled
    Before installation run the following or make sure to have mainserverip postgresqlsrv (e.g 12.12.12.12 postgresqlsrv) in /etc/hosts on every server.
    or run the following: echo "mainserverip postgresqlsrv" >> /etc/hosts (e.g echo "12.12.12.12 postgresqlsrv" >> /etc/hosts
    Be sure this is done BEFORE installation.
    put onestream_all_v1.1.21.tar.gz in /home/onestream/iptv/
    run bash /install_main.sh
    when asked for APP_NAME, enter anything like 1-Stream
    when asked for LICENCE, enter anything like 1stream-00000000000000000000
    when installing load balancer, again put onestream_lb_v1.1.21.tar.gz in /home/onestream/iptv/
    https://www.mediafire.com/file/6dycp....1.21.zip/file
    07 Dec 2022
    salutare .cine ma poate ajuta cu un link de unde pot descarca zip/file .cel afisat nu functioneaza ...multumesc
    none
    01 Jan 1999
    acasa
    42 Post(s)
    functioneaza înca... mai incearca...
    bafta
    07 Dec 2022
    nu pot descarca arhiva .te rog vrei sami lasi an privat ?
    ---------- Post added at 11:01 ---------- Previous post was at 10:59 ----------
    la acele puncte nu stiu ce sa pun ?sal pot descarca .vrei sami lasi te rog linkul antreg ?multumesc
    none
    01 Jan 1999
    acasa
    42 Post(s)
    ce puncte?...trebuie sa dai numai click pe el..e linkul complet:
    PHP Code:
    https://www.mediafire.com/file/6dycpc7hb2128uu/onestream_v1.1.21.zip/file
    L.E.: ...nu merge pus pe vps... trebuie dedicat!
    bafta
    07 Dec 2022
    salutare este picat ftp
    dac ala este picat kitul de instalare este 0
    practic nu al gaseste sal instaleze
    404 Not Found [IP: 87.238.57.227 80]
    none
    01 Jan 1999
    acasa
    42 Post(s)
    ceva faci tu gresit... merge fara probleme...fii atent la: Before installation run the following or make sure to have mainserverip postgresqlsrv (e.g 12.12.12.12 postgresqlsrv) in /etc/hosts on every server.
    bafta
