Likes Likes:  1
Results 1 to 3 of 3
Thread: Instalare Windows 11 pe dispozitive nesuportate
    95 Post(s)
    Default Instalare Windows 11 pe dispozitive nesuportate
    Stiu ca a aparut metoda Rufus dar exista metoda oficiala Microsoft:
    Warning:
    Microsoft recommends against installing Windows 11 on a device that does not meet the Windows 11 minimum system requirements. If you choose to install Windows 11 on a device that does not meet these requirements, and you acknowledge and understand the risks, you can create the following registry key values and bypass the check for TPM 2.0 (at least TPM 1.2 is required) and the CPU family and model.
    Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\Setup\MoSetup
    Type: REG_DWORD
    Value: 1
    Note: Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall the operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk.
    Procedurile de instalare sunt descrise aici de Microsoft.
    LE:
    La ultimele versiuni de W11 nu mai merge aceasta metoda!
    Ma scuzati
    17 Jan 2008
    95 Post(s)
    E alta metoda prezentata acolo: ștergeți din stick fișierul “install.wim” din “sources”.
    Se pare ca metoda din primul post nu mai e valabila la ultimele versiuni de W11 !!!
