Thanks Thanks:  6
Likes Likes:  9
Results 1 to 4 of 4
Thread: Viper 4K V20 V30 update din telnet
    Default Viper 4K V20 V30 update din telnet
    In ultimele saptamani, @nicuvu a constatat ca nu mai poate face update cu stickul la Viper 4K V20 dupa ce a scris o imagine .... mai ciudata, mai exact :
              https://gisclub.tv
       Welcome to OpenFIX 5.4 viper4kv20
             Linux 4.4.35 armv7l
      Thursday, 01 January 1970, 02:11:51
    openfix 5.4 viper4kv20
    viper4kv20 login: root
    Aparatul functiona, scana etc, ii mergea reteaua dar nu mai facea update pe sistemul de directoare clasic.
    Probabil cei care au construit imaginea au facut ceva greseli.
    Dupa multa tevatura pe forum la noi si la altii, a ajuns aparatul la mine si am incercat procedura sugerata de @lukas26
    using telnet
        Insert the USB drive with the image you want to flash
        Connect to the box using telnet (even if It's bootlooping, it works)
            The username is "root"
        Now use the command:
            ofgwrite -n <path-to-the-image>
        If this results with no errors, You can proceed to flash the image using this command:
            ofgwrite -k -r <path-to-the-image>
    Note: the usb drive should be mounted in /media/hdd, so the image path should start with it.
    For example: /media/hdd/amiko/u57, this should be the standard.
    Am pus imaginea pe stick in directorul u57, am bagat stickul in aparat, am intrat in telnet cu root root, am schimbat directorul in /media/hdd pentru ca acolo aparea stickul montat si uite rezultatul la prima comanda:
    root@viper4kv20:/hdd# ofgwrite -n u57/
    mkdir: can't create directory '/newroot': File exists
    ofgwrite Utility v4.5.6
    Author: Betacentauri
    Based upon: mtd-utils-native-1.5.1 and busybox 1.24.1
    Use at your own risk! Make always a backup before use!
    Don't use it if you use multiple ubi volumes in ubi layer!
    Searching image files in u57/ resolved to /media/hdd/u57
    Found kernel file: /media/hdd/u57/kernel.bin
    Found rootfs file: /media/hdd/u57/rootfs.tar.bz2
    Setting default parameter: Flashing kernel and rootfs
    Found EXT4 rootfs
    Found mounted /newroot
    Found mountpoint for rootfs file: /media/hdd
    Found /proc/mtd entries:
    Device:   Size:     Erasesize:  Name:                   Image:
    Using kernel mtd device:
    Using rootfs mtd device:
    Read /proc/cmdline
    Current rootfs is: /dev/mmcblk0p10
    Current kernel is:
    Current root sub dir is:
    Found cmdLine kernel device: /dev/mmcblk0p9
    Found cmdLine rootfs device: /dev/mmcblk0p10
    FBIO_SET_MANUAL_BLIT: Operation not permitted
    Syncing filesystem
    Flashing kernel ...
    Successfully flashed kernel!
    Untar: tar xf /media/hdd/u57/rootfs.tar.bz2
    Successfully flashed rootfs! Rebooting in 3 seconds...
    asta practic a fost o comanda de test, apoi am dat:
    ofgwrite -k -r u57/
    am primit o gramada de erori in consola dar pe tv a aparut ecranul de scriere imagine de forma:
    (poza e cu titlu exemplificativ, preluata de la @MihaiP, eu nu am captat ecranul atunci)
    Dupa se s-a terminat scrierea si restartarea a aparut meniul de configurare la primul boot al imagini pe care am scris-o, in cazul meu Pure2.
    Iar l-a pus in cap, dupa ceva teste pe AnyDesk am ajuns la concluzia ca doar din portul USB 3.0 (albastru) merge update din telnet!
    Iar l-a pus in cap si l-am refacut prin procedura de mai sus.
    19 Post(s)
    https://mega.nz/file/L8lwlTbT#V8n-fg...sdt4mAEdizlLtg
    Pentru V30 am o procedura mai simpla si mai sigura !
    un upgrade de tip recovery !!! Nu am imagine decat pentru
    V30 si ea rezolva problema driverului dvb-c ! ea ... si numai ea !
    - scrie-ti fisierul pe un stick formatat FAT32 ...
    - PowerOFF
    - introduceti stickul
    - si apoi PowerON
    ---------- Post added at 08:36 ---------- Previous post was at 06:41 ----------
    Incidentul care i se tot intampla lui @nicuvu se datoreaza experimentelor
    de instalare ale unor imagini diferite de cele originale dar construite pe un
    HW compatibil ! acestea au de regula o structura de foldere diferita de cele
    originale asa ca la incercarea de a reveni ... bootloaderul va cauta altceva
    decat ce contine pachetul de instalare !
    Experimentele de acest gen sunt total lipsite de sens ! familia Viper este
    construita dupa modelul Dinobot si are un set comun de drivere ! deci
    imaginile nu au cum sa mearga mai bine !!! Mai binele este dusmanul binelui !
    link securizat
