Thanks Thanks:  2
Likes Likes:  3
Results 1 to 10 of 10
Thread: Tools and software GTmedia v8 uhd
    konstantine's Avatar
    Default Tools and software GTmedia v8 uhd
    Editor de canale actualizat 5 dec. 2020, compatibil cu v8 uhd, v8 finder și v9.
    1. Add multiroom function
    2. Optimize the Diseqc1.2 function
    GTMedia_V8UHD_20210226_V224.zip
    Please do the following steps:
    1)backup the channel list.
    2)export the softcam.key to usb device
    3)update the firmware to box by allcode mode
    4)update channel list then import softcam.key
    ---------- Post added at 22:48 ---------- Previous post was at 21:58 ----------
    Au implementat server NEWCAMD in soft, se conecteaza oscam la el
    2021/03/03 23:33:19 4FA73058 h   (reader) v8xerver [newcamd] Restarting reader
    2021/03/03 23:33:19 4FA73058 h   (reader) v8xerver [newcamd] creating thread for device 192.168.5.123
    2021/03/03 23:33:19 4FA73058 h    (webif) reader v8xerver enabled by WebIf
    2021/03/03 23:33:19 3B76E9E7 p  (newcamd) proxy 192.168.5.123:43433 newcamd525 (fd=0)
    2021/03/03 23:33:19 3B76E9E7 p   (reader) 192.168.5.123: resolved ip=192.168.5.123
    2021/03/03 23:33:19 3B76E9E7 p   (reader) v8xerver [newcamd] connecting to 192.168.5.123:43433
    2021/03/03 23:33:19 3B76E9E7 p  (newcamd) Newcamd Server: 192.168.5.123:43433 - UserID: 1
    2021/03/03 23:33:19 3B76E9E7 p  (newcamd) CAID: FFFE - UA: 0000000000000000 - Provider # 1
    2021/03/03 23:33:19 3B76E9E7 p  (newcamd) Provider ID: 000000 - SA: 00000000
    2021/03/03 23:33:19 3B76E9E7 p   (reader) v8xerver [newcamd] proxy initialized, server 192.168.5.123:43433
    2021/03/03 23:34:00 3B76E9E7 p   (reader) v8xerver [newcamd] disconnected: reason receive error1
    2021/03/03 23:34:00 3B76E9E7 p  (newcamd) Connection closed to remote server
    Se conecteaza da nu cred ca merge.
    17 Jul 2008
    In Tara
    trb platita linia aia mgcamd..
    altfel ramii cu caid FFFE.
    Soft nou.
    20/12/2021
    Change log:
    1. Add recall list function
    2. T2 countries added, Egypt, Israel, Palestine
    3. Support Nagra3 CA card
    GTMedia_V8UHD_V235_20211220.zip
    (5.09 MiB)
    19 Jan 2009
    salve a tutti, posseggo un reciver GTmedia V8 UHD con softweare 2.45,
    ( mars)adesso vorrei cambiare e mettere il nuovo 247 ECam, ma non accetta dopo 3 secondi....fallito qualcuno puo´ aiutarmi GRAZIE
    INGLESE---hi all, I have a GTmedia V8 UHD receiver with software 2.45,
    ( mars) now I would like to change and put the new 247 ECam, but it does not accept after 3 seconds .... failed can someone help me THANKS
    More about "nuovo 247 ECam" please.
    15 Sep 2009
    Dâmbovi?a
    Pentru Ecam, e nevoie de softul original, deci trebuie prima data "eliminat" softul Mars. Mare branza nu este, deci cine doreste lumina cat mai multă, nu vad de ce ar trece la Ecam.
    Ciao, per poter usare Ecam, devi cambiare il software attuale con quello originale prima, usando il cavo rs232. Ma, da quel che ho visto, ecam non e' cosi stabile come la linea Mars, ne tantomeno apre piu' canali.
    ATX-91 + LNA177 la repaus
    My Youtube channel.
    A aparut editor de canale (in cloud) pt. receptoarele cu sw.mars.
    Attached Files Attached Files
    25 Jul 2007
    Da Ecam e cu plus si minus.Plusul e ca nu arde buzunarul rau ,adica 20 euro iar minusul ca nu are doua pachete foarte urmarite pe plan european.
    Mars-ul costa in schimb 40 de euro.Si vanzatorii arabi trebuie sa dea mancare la camila.....
