Thanks Thanks:  18
Likes Likes:  35
Page 4 of 4 FirstFirst 1234
Results 46 to 58 of 58
Thread: GTMEDIA V8 UHD (DVB-S/S2/S2X+T/T2/Cable/ATSC-C/ISDBT)
  1. #46
    24 Oct 2009
    Targoviste
    Buna ziua.Am intrat in posesia unui GTMEDIA V8,am instalat ultimul soft si am incercat sa activez emu dar nimic.Am respectat intocmai activarea :Meniu / Rețea / săgeată dreapta / 6666.Care ar fi problema?Multumesc.
  2. #47
    Cred ca am scris mai sus in topic.
    Au restructurat meniurile și a apărut unul special de card, acolo apeși pe 6.
  3. #48
    Main Chip Sets Multi-core CPU architecture MIPS 74Kf core operating frequency up to 1GHz, 16KB I-cache, 16KB D-cache and 1 Register File
    Flash Memory 64MB SPI Flash
    DDR3 Memory 2G bit*2
    TS Demux Demultiplexer ISO/IEC 13818-1
    Input Bit Rate 2 parallel TS input ports @864Mbps in parallel mode
    Video Decode Video Decode MPEG-2 ISO/IEC 13818-2 MP@ML, ISO/IEC 14496-2 (MPEG4) compliant, Supports SP@L3 to ASP@L5,Multi-format ultra-high definition video decoder (MPEG1/2/4, H.264/265, VC-1, AVS/AVS+, VP8 and VP9)
    Video Resolution By Source, 480i,480P,576i,576P,720P_50,720P_60,1080i_25,1080i_30,1080P_25,1080P_24,1080P_30,1080P_50,1080P_60,4 K2K_25,4K2K_30,4K2K_50,4K2K_60;
    Video DAC 1 x 10bit DAC for CVBS output
    Composite NTSC M/N/J, NTSC-4.43
    Composite PAL M/N/B/D/G/H/I, PAL-60
    Aspect Mode Auto, 16:9 Pillar box, 4:3 Pan & Scan, 4:3 Letter Box
    HDMI Video Out Auto, RGB-Normal, RGB-Expand, YCbCr 4:4:4, YCbCr 4:2:2
    HDMI deep color Auto, Normal, None, HDMI deepcolor 24, HDMI deepcolor 36
    Audio Decode Audio Decode MPEG-1/2 Layer I/II, AAC/HEAAC v1/v2, Dolby Digital (AC3),Dolby Digital Plus (EAC3),RealAudio,WMA/WMA Pro,MP3,OGG,APE,FLAC,ALAC
    Sound Mode LEFT/RIGHT/STEREO/MONO
    Audio DAC Supports 2 channels, 16-bit resolution and 8k-192k sample rate,
    Audio Out LPCM Out, BS Out
    Hardware specifications Panel display 8-digit white LED display,With multiple function indicators
    LED Indicator Power ON :Green; Standby :Red
    Button NOT
    Wifi Built in 2.4G WiFi Support IEEE 802.1.1b/g/n
    IR Exit IR for 38KHz,Infra Remote control
    Rear Panel ANT IN ( EC-type IEC169-2 Female)
    LNB IN (Frequency Range950MHz to 2150MHz)
    HD OUT(HDMI2.0, up to 4kx2kp50/60 output )
    SCART OUT
    1*Coaxial (RCA:black)
    1*USB2.0 HOST
    1*RJ45 (For 10M/100M MAC)
    1*CA card solt
    DC IN (DC12V/1.5A)
  4. #49
    VB-S/S2 specificati-ons System standard ETS 302 307
    Frequency Range 950~2150MHz for DVB-S/S2/S2X baseband demodulator
    LNB Power and Polarization DiSEqC1.0/1.1/1.2/USALS Motor fully support,
    Support Unicable, 13/18V DC @ 400mA MAX, 22KHz±0.4KHz(0.6V±0.2V)tone,Overload Protection
    Input Level Range -80dBm ~ -20dBm (average power)
    Symbol Rates DVB-S QPSK,DVB-S2 QPSK/8PSK/16APSK/32APSK,
    DVB-S2X QPSK/8PSK/16APSK/32APSK/64APSK
    Forward error correction rate 1/4,1/3,2/5,3/5,2/3,3/4,4/5,5/6,8/9,9/10
    Carrier frequency acquisition range ±5MHz for symbol rates above 3 Msps and ±3MHz for the remaining symbol rates
    Symbol Rates Symbol rate range:
    QPSK/8PSK/16APSK 56M, 32APSK 49.6M, 64APSK 41.3M
    Roll-off factors Roll-off factors for pulse shaping: 0.2, 0.25 and 0.35
    Code Rates 1/2,2/3,3/4,5/6,7/8 for DVB-S, 1/4,1/3,2/5,1/2,3/5,2/3,3/4,5/6
    ,8/9,9/10 for DVB-S2,
    DVB-S2X Normal Frame and Short Frame FEC code rates
    Features Supporting CCM/VCM/ACM
    Supporting PLHEADER Scrambling (AMC)
    Integrating LDPC and BCH decoders
    ANT. Connector Connector:IEC TYPE F Input Impedance:75 Ω
    DVB-T/T2 specificati-ons System standard ETSIEN 302 755
    Frequency Range VHF: 174~230mhz, UHF: 470~862mhz for DVB-T/T2
    Demodulation COFDM,16QAM,64QAM,256QAM
    Bandwidth model 6MHZ,7MHZ and 8MHZ
    Country Italy, Poland, Russia, Spanish, Sweden, United Kingdom, Germany,Greek, Slovenia, Argentina, Australia, Denmark, Finland, France, England, Brazil, Chile, Peru, Colombia, India, Georgia, Indonesia.
    FEC Code Rate 1/2, 3/5, 2/3, 3/4, 4/5, 5/6
    FFT 2K and 8K
    Guard interval 1/4, 19/256, 1/8, 19/128, 1/16, 1/32, 1/128
    Input Signal level: Min -80dbm max -20dbm (64QAM,8K 1/8,7/8)
    Antenna Power 5V DC @ 150mA MAX
    ANT. Connector IEC 169-2, female. Input Impedance:75 Ω
    ISDB-T specificati-ons System standard ISDB-T broadcast (1, 3, 13 segment),MPEG-2/MPEG-4 AVC/H.264 HD/SD Video , DiVX
    Frequency Range VHF:177.143~213.143 MHz:UHF 473.143~803.143MHz
    Country Brazil and Japan
    FFT 2K/ 8K/32K
    Demodulation QPSK / 16QAM / 64QAM/QPSK or DQPSK
    FEC Code Rate 1/ 2, 2/3, 3/4, 5/6, 7/8 Automatic
    Guard interval 1/4,1/8,1/16,1/32
    DVB-Cable specificati-ons Frequency Range 50--858MHz For DVB-Cable (J.83A/B/C)
    Demodulation 16QAM,32QAM,64QAM,128QAM,256QAM
    FEC Code Rate 1/2 , 2/3 , 3/4 , 5/6 , 6/7 or 7/8
    Input Signal level Min -80dbm max -20dbm
    Country (ATSC-C) U.S.ATSC Cable STD/U.S.ATSC Cable IRC/U.S.ATSC Cable HRC for ATSC-C
    Sortware Features Standard Fully comply with DVB-S/S2/S2X (SCPC and MCPC receivable from C/Ku band satellite), DVB-T/T2/Cable(J83.A/B/C)/ISDBT, MPEG-2/4 H.265 Standard
    Channel Search Supports Automatic network search for newly added transponders, and Supports NIT Search for DVB-T/Cable.
    Channels Number 6000+ channels TV and Radio programmable
    Channel Play Type Can choose All, Free and Scrambled.
    Channel You can switch to any other channel while recording the channel;
    Various channel editing unction(favorite,move,lock,skip,delete,rename,find,sort);
    Favorites 32 different favorite groups selection
    OSD Language English,French,German,Italian,Spanish,Portuguese,Russian,Turkish,Polish,Arabic,Persian,Thai,Vietnam, Czech,Armenian,Georgian,Ukrainian,Albanian,Hungary,Malay,Indonesisch,Dansk,Greek,Serbian.
    OSD Color 32-bits OSD with anti-flickering,
    OSD Setting Support OSD Timeout and Transparency, Subtitle Display, Channel list displays pages 1-3.
    Support menu in the small window to play programs
    Other Setting Sets up multiple habitual operation Settings
    Parental Ctrl Parental control for channels
    Easy Menu Plug and Play installation, with an easy to use Menu System
    EPG Fully support to 7 days Electronic Program Guide(EPG)
    Subtitle support DVB EN300743 and EBU
    Teletext support DVB ETS300472 by VBI
    Auto Standby Can open STB to enter play auto standby.
    SoftUpgrade Software upgrades through USB port, or FTP upgrade.
    Time Set Time set by GMT offset automatic and manual,Summer Time support
    Timer 8 event timers,off/Once/Daily Mode
    USB Decode USB 2.0 Support FAT/FAT32/NTFS big capacity hard disk
    PVR Option USB 2.0 for PVR,TIMESHIFT,media files playback
    Media Codec TS,mkv, mp4, avi, flv, f4v, ts, m2ts, mov, 3gp files
    Audio Codec WMA,MP3
    Photo Codec JPG, BMP, PNG, GIF
    Packing Product Dimension 205*80*140MM(L*W*H)
    Packaged Size 205*150*88MM
    Carton Size 510*460*305mm (20pcs/ctn)
    Unit Weight 0.75 Kg with gift box
    Carton Qty&Weight 20 pcs/Carton, 15.5 kgs
    Accessories Gift Box, Adapter, IR remote control, HDMI Cable, User Manual,Warranty card
    Physicals Power Supply AC 100V ~250V, 50/60Hz
    Power Consumption 12W in operation
    <=1 W Standby Power Mode
    Temperature Operation 0~+45ºC; Storage -10~+60ºC
    Humidity 20~90%, non-condensed
  5. #50
    konstantine's Avatar
    Chiar credeam că are design original... Cănd colo, e furăciune.
    Soft "proaspăt":
    https://www.freesat.cn/forum/viewtopic.php?f=40&t=19117
    Au aparut doua functii noi in meniul ascuns.
    Update luna septembrie https://www.freesat.cn/forum/viewtopic.php?f=40&t=19117
    Change log:
    1. Solve the problem of bit error rate program playback
    2. Support V7 remote control
    3. Support fast forward and rewind
    4. Update Polish DVB-T frequency
    5. V8 UHD subtitles are off by default
    6. Updated the video website application under APP.
  9. #54
    Default GTMEDIA V8 UHD (DVB-S/S2/S2X+T/T2/Cable/ATSC-C/ISDBT)
    Au rezolvat bug-ul cu subtitrarea care nu dispărea !
    Parca și subtitrarea arată mai bine.
    Telecomanda e jaf ! Nu mai merge aproape deloc comanda Săgeata sus, deși l-am folosit doar la teste.
    ---------- Post added at 17:10 ---------- Previous post was at 17:02 ----------
    Nu l-au rezolvat
  10. #55
    Change log:
    1. In full screen, press the EPG key, the cursor stays on the current program
    2. In ECM status, press INFO key to display status
    3. Logo display problem of xtream live show;
    4. The subttile subtitles of newly searched programs are off by default;
    5. Add cline info menu
    6. Added Block EMM and CAID Tunnelling menus.
    7. Fix the error ts hang problem
    8. Add cc function to the subtitle menu
    9. Hide/show record icon
    10. Fix Youtube Live Music playback OK
    GTMedia_V8UHD_V232_20211020.zip
    (5.08 MiB)
  11. #56
    Change log:
    1. Add recall list function
    2. Repair V8UHD_playlist.m3u export format
    3. Under the INFO interface, add YouTube QR code
    GTMedia_V8UHD_V237_20220309.zip (5.29 MiB)
    link original
  12. #57
    Soft nou "GTMedia_V8UHD_V238_20220520". Posibil să fie ultima actualizare pt. ca se apropie de EOL.
    20/05/2022
    Change log:
    1: Add TNTSAT card support
    2: xtream problem modification
    3: tivusat card update
    4. Remove the ivi web application app.
    5. V8UHD_playlist.m3u export fix
    GTMedia_V8UHD_V238_20220520.zip
    (5.29 MiB)
    Se pare că nu au abandonat versiunea de sw. "clasică". Soft din august 2023
    03/08/2023
    Change log:
    1. Version information update
    2. Fix cc subtitles
    3. Fix known bugs
    GTMedia_V8UHD_V245_20230803.zip
    https://disk.yandex.com/d/chydASTlLKUjCw
