Results 1 to 2 of 2
Thread: oscam auto install linux pc server ubuntu
    Standard RSP member lukas26's Avatar
    24 Mar 2009
    romania
    Thumbs up oscam auto install linux pc server ubuntu
    Installation via putty
    svn co http://streamboard.tv/svn/oscam/tags/1.10/ oscam-1.10
    cd oscam-1.10
    wget https://raw.github.com/manio/vdr-plugin-dvbapi/22733ee/patches/oscam-vdr.diff
    patch < oscam-vdr.diff
    mkdir build
    cd build
    cmake -DWEBIF=1 -DHAVE_DVBAPI=1 ..
    make
    sudo make install
    svn co http://streamboard.tv/svn/oscam/trunk/ oscam-1.2
    cd oscam-1.2
    mkdir build
    cd build
    make
    sudo make install
    add oscam emu to /usr/local/bin atribute 755
    add configuration files and place them in /usr/local/etc
    auto start oscam on reboot via putty
    nano /etc/crontab
    # /etc/crontab: system-wide crontab
    # Unlike any other crontab you don't have to run the `crontab'
    # command to install the new version when you edit this file
    # and files in /etc/cron.d. These files also have username fields,
    # that none of the other crontabs do.
    SHELL=/bin/sh
    PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
    # m h dom mon dow user command
    17 root cd / && run-parts --report /etc/cron.hourly
    25 6 * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
    47 6 7 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
    52 6 1 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
    @reboot root /usr/local/bin/oscam -b
    save ctrl+o
    exit ctrl+x
    reboot
    oscam 11578 .x64 with emu
    rework code ref gbox_maxecmsend
    fix for gbox_max_ecm_send
    change default to 5
    clean up some ecm stuff
    download:
    http://www.mediafire.com/file/rqpowg...u.zip.zip/file
    24 Mar 2009
    romania
    oscam-svn11603-Ubuntu-20.04-webif-dvbapi-emu798
    download:
    http://www.mediafire.com/file/1khlbi...mu798.zip/file
