Results 1 to 7 of 7
Thread: Amiko Ella FTA
    Thumbs up Amiko Ella FTA
    Amiko Ella FTA
    Descriere FTA Satellite Receiver
    High Speed USB 2.0 Connection Support
    SCART support
    TimeShifting Support
    Software Upgrade via USB
    MKV, AVI, MPG, MP4, TS, VOB, JPEG & MP3 Playback Support
    Dolby Digital Bit-Stream out via HD OUT
    Low Power Consumption in Stand-By
    True-color, User Friendly On-Screen Display (OSD)
    Full Picture In Graphic (PIG) function
    Electronic Program Guide (EPG) for on screen channel information
    Subtitle supported
    Teletext supported by VBI insertion and software emulation
    Parental lock facility by channel and program event
    Program and Channel information transfer from receiver to receiver
    Multi-Language support
    Power Consumption in Stand-By: <0.5W
    Tuner & Demodulation
    Tuner Type: DVB-S / DVB-S2
    Input Connector: F-type, Connector, Female
    Signal Level: -65 to -25 dBm
    LNB Power & Polarization: Vertical: +13V/+14V,
    Horizontal: +18V/+19V
    Current: Max. 400mA
    Overload Protection
    22KHz Tone Frequency: 22±1KHz
    DiSEqC Control: Version 1.0, 1.1, 1.2, USALS
    Demodulation: QPSK, 8PSK
    Input Symbol Rate: 2-45 Mbps,
    FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
    System Resources
    Main Processor: 650MHz based CPU
    Flash Memory: 32MBits
    MPEG TS A/V Decoding
    Transport Stream: MPEG-2, H.264/H.265
    Input Rate: Max.120Mbit/s
    Aspect Radio: 4:3, 16:9, Letter Box
    Video Decoding: MPEG-2, MP@ML, MPEG-4 part 10/H264
    Video Resolution: 720*480P/I, 720*576P/I, 1280*720p, 1920*1080i, 1920*1080p
    Audio Decoding: MPEG-1 layer I/II, MPEG-2 layer II, Dolby digital
    Audio Mode: Left / Right / Stereo/ Mono
    Sampling Rate: 32, 44.1 and 48KHz
    Power Supply
    Input Voltage: 12V DC
    Power Consumption: 18W Max
    Stand-By Power Consumption: <0.5W
    A/V & Data Input/Output
    SCART A/V: Video CVBS output, Audio L/R output
    USB: One USB 2.0 slots
    HDMI: VER1.4, Type A
    Pagina producătorului
    al gasiti in romania la 110 roni
    suport sw:
    https://www.sat-support.tv/?a=downloads&dir=229
    la acest reciver puteti achizitiona stik wirless
    Se pot introduce linii de test, are asa ceva in meniu?
    banuesc ca da din cate am inteles e la fel ca mira
    Standard RSP member valysatt's Avatar
    08 May 2007
    Salut!
    acest receptor are un meniu ascuns?am testat o data un receptor chinezesc care arta identic,se putea edita lini in meniu ascuns accesat din 4 cifre.
    Multumesc
    Salut@re!
    Din service-ul unuia dintre magazinele ce vând acest receptor mi s-a răspuns prin mail că nu este posibil. Postează codul respectiv, poate probeaza cineva.
    14 May 2011
    7 Post(s)
    Nu cred ca merita sa-ti pierzi vremea cu pocnitori de 100 lei care evident ca nu prea au nici un fel de suport si nici nu prea poti sa faci mare lucru cu el.
