Results 1 to 2 of 2
Thread: Amiko Viper Twin
    Standard RSP member lukas26's Avatar
    24 Mar 2009
    romania
    Default Amiko Viper Twin
    Amiko Viper Twin
    Fully DVB-S/DVB-S2, MPEG-2/HD MPEG-4/H.264/H.265 HEVC compliant
    E2 Operating system
    Support Full HD 1080P, HDMI 576i, 576p, 720p, 1080i, 1080p
    DiseqC 1.0/1.1/1.2/1.3 (USALS) supported
    Aspect ratio 16:9 and 4:3
    CVBS/RGB/HDMI/ output supported
    Universal LNB, NIT search support
    Support more than 5000 channels
    7-days Electronic program guide (EPG)
    Video resolution: 576i, 576p, 720p and 1080i, 1080p
    Auto/Manual Program search
    Multi-language supported
    Two High Speed USB 2.0 Ports
    USB 2.0 for PVR, Timeshift, Software upgrade, Multimedia Playback
    Multimedia format: Picture, JPEG, BMP, PNG, Audio: MP3/ M4A/AAC/WMA/ASF
    Video: MKV, AVI, DIVX, XVID, MOV, VOB, FLV, 3GP, DAT MPEG, MPG, MP4, TS, TRP
    Built-in WiFi
    Kodi, IPTV, YouTube, Internet VOD Supported
    Support UNICABLE
    Tehnical Specification
    Main Systems
    Main Processor: Hisilicon 3716MV410”
    DDR3 Memory: 512MB
    Flash Memory: 512MB
    MPEG Transport Stream & A/V Decoding
    Transport Stream: MPEG-2, H.264
    Input Rate: Max. 120Mbit/s
    Aspect Ratio: 4:3, 16:9, Letter Box
    Video Decoding: MPEG-2, MPEG-4 part10/H264
    Video Resolution: 720*480P/I, 720*576P/I, 1280*720p, 1920*1080i, 1920*1080p
    Audio Decoding: MEPG-1 layer I/II, Mpeg2, layer II, Dolby digital
    Audio Mode: Left/Right/Stereo/Mono
    Sampling Rate: 32, 44.1 and 48KHz
    Connections:
    2x LNB S2
    1x HDMI
    2x USB 2.0
    1x AV
    1x RJ45
    1x WiFi
    1xDC 12V/2A
    Environmental Condition
    Operation Temperature: 0oC~+45oC
    Storage Temperature: -10oC~+70oC
    Storage Humidity: 5%~95% RH (Non-Condensing)
    Input Voltage: 100-240V~, 50/60Hz
    Power Consumption: 24W (Stand by: <0.5W)”
    Accessories:
    1xRemote
    1xHDMI Cable (1meter)
    1xUser Manual
    1xPower Adapter: 12Vx2A
    2xBattery
    1xWifi antenna (Internal)
    Size:
    Machine Size (WxHxD): 160*30*90mm
    Carton Size: 590*270*245mm
    Gross Weight: 10.25-10PCS/per Carton
    al gasit in romania la pretul de 286 roni
    dupa cum observati e copie dupa IZIBOX ECO TWIN HD SAT
    info:
    https://www.sateliti.info/showthread...co-twin-hd-sat
    ---------- Post added at 22:25 ---------- Previous post was at 21:50 ----------
    imagini testate
    pure2
    http://www.pur-e2.club/OU/images/ind...3/jamesdonkey/
    openatv
    http://images.mynonpublic.com/openat...p?open=jdhdduo
    24 Mar 2009
    romania
