IZIBOX ECO TWIN HD SAT
ENIGMA2 OS
DUAL DVB-S2
HEVC decoding support
unlimited channels (TV and Radio) programmable
Two High Speed USB 2.0 Connections
Ethernet Connection
Wireless Connection
Channel Recording to External Storage Devices (optional)
MORE FEATURES
Timeshift support
Channel Recording & Timeshifting Simulteniously (optional)
Channel switching time less than 1 second
True-color, User Friendly On-Screen Display (OSD)
Full Picture In Graphic (PIG) function
Electronic Program Guide (EPG)
Subtitle supported
Teletext supported with VBI insertion
Parental lock facility by channel and program event
Program and Channel information transfer from receiver to
receiver
Satellite Blind Scan & Fast Scansupport
DiSEqC 1.0, 1.1, 1.2 and USALS Compatible
Full HD (1080p) Output via HDMI
Exciting games embedded
Multi-Language support
Software upgrade support via USB, Network, OTA, RS232
Power Consumption in Stand-By: <0.5W
Tuner & Demodulation
Tuner Type: DVB-S / DVB-S2
Input Connector: F-type, Connector, Female
Signal Level: -65 to -25 dBm
LNB Power & Polarization: Vertical: +13V/+14V,
Horizontal: +18V/+19V
Current: Max. 400mA (Overload Protection)
22KHz Tone Frequency: 22±1KHz
DiSEqC Control: Version 1.0, 1.1, 1.2, USALS
Demodulation: QPSK, 8PSK
Input Symbol Rate: 2-45 Mbps,
FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
MPEG TS A/V Decoding
Transport Stream: MPEG-2, H.264, H.265
Input Rate: Max.120Mbit/s
Aspect Radio: 4:3, 16:9, Letter Box
Video Decoding: MPEG-4/H.265 SP@L3 to ASP@L5, AVC,
HP@level 4.1, MP@level 4.1
Video Resolution: 720*480P/I, 720*576P/I, 1280*720p,
1920*1080i, 1920*1080p
Audio Decoding: MPEG-1/2,AAC-LC,HE-AAC,MP3,Dolby Digital
Audio Mode: Left / Right / Stereo/ Mono
Sampling Rate: 32, 44.1 and 48KHz
System Resources
Main Processor:HI3716MV410 CORTEX A-9
Flash Memory: 512MB
DDR3 RAM: 512MB
Power Supply
Input Voltage: 12VDC
Power Consumption: 24W Max
Stand-By Power Consumption: <0.5W
A/V & Data Input/Output
RCA: Jack-type, CVBS Video out, L&R Audio out
USB: Two USB 2.0 slots
HDMI: VER1.4b
Ethernet: 10/100M RJ45
Physical Specifications
Size[W*H*D]: 160mm x 43mm x 135mm
Net Weight: 1.0KG
Operation Temperature: 0°C~+85°C
Storage Temperature: -10°C~+85°C
Storage Humidity: 5%~95% RH (Non-Condensing)
al gasit in portugalia pret 47 euro
download image:
pure2
http://www.pur-e2.club/OU/images/ind...ir=6.3/izibox/
openatv
http://images.mynonpublic.com/openat...en=iziboxecohd
