Multics r107
Please dont use fake versions cause there is a server (maybe modified multics) that create fakeCW by changing the last byte of CW (using XOR 0xF0) and send to all peers.
[05.07.2020] r107 * fixed mgcamd conections
* fixed sidlist and changed structure (every service has his own options: dcw checksum/halfnulled)
* added CW Data webpage
* removed log of bad connections that slow down mcs and increase cpu usage
* removed cacheex servers from servers webpage
* fixed cache peer reconnection on startup and stats
* fixed cacheex stats
* added global option to skip sending cache replies to peers with high ping
CACHE MAXPING: 100 # value is in milliseconds (default = 300)
download: x.64
http://www.infosat.org/multics/files/multics
