Thanks Thanks:  2
Likes Likes:  1
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Configurate corecta FocusSat card
    17 Nov 2008
    ALBA
    [reader]
    label = focussat
    protocol = internal
    device = /dev/sci0
    pincode = 1234
    services = foc_familia
    cacheex = 1
    caid = 0B02
    ecmwhitelist = 0B02:4E,60,97,84
    detect = cd
    mhz = 800 ( sau 600 depinde ce cititor folosesti )
    ident = 0B02:000000
    group = 1
    emmcache = 1,2,3
    blockemm-unknown = 1
    lb_weight = 300
    dropbadcws = 1
    cccreshare = 1
    audisabled = 1
    auprovid = 000B02
    mai ai Card Mhz 357 asta in oscam reader
    ce anume nu reusesti?
    23 Apr 2008
    Bucharest West
    Quote Originally Posted by cipryDXfeed View Post
    [reader]
    auprovid = 000B02
    aveam asa, internal reader.., si mergea, dar am zis ca s-au mai schimbat, mai ales service, srvid..
    services = foc_familia --> poti te rot sa postezi si serviciile, sau ce prio ar fi bine de pus in dvbapi.
    Merci!
    mhz = 450
    cardmhz = 2700
    emmcache = 1,3,15,0
    Vu+Zero4K, Offset Motor 1m
    7 Post(s)
    [reader]
    Fac o rectificare scurta la ecmwhitelist se adauga pachete care le aveti pe card, in acest fel nu este nevoie de "services"
    In cazul meu
    ecmwhitelist =0B02:4E,A9,84,97,8A,60,72,9C
    17 Nov 2008
    ALBA
    Sunt testate !
    [foc_familia]
    caid = 0B02
    provid = 000000
    srvid = 7789,03F3,0492,76C2,03ED,055A,76C6,76C7,0DB6,76CA,0B87,76CB,76CD,03F7,055C,78BC,0D8E,055F,76C4,79E3, 78B9,0550,79E8,76C8,0DC0,798B,2AFA,78BE,0B9A,76C1,2AFD,0B86,2AFB,7A06,76D3,0D84,76CC,76CE,76D2,0C30, 77AF,797D,0D34,060E,1771,01FB,0407,0DDE,0D48,77A8,77AA,7925,773E,0FFA,03F6,0B50,77B0,759C,76C9,780C, 780D,780A,7988,01FA,7928,75B7,76DE,7672,772F
    Trebuie si service ! primesti cereri aiurea la card !
    Zii ce tip de reader sau aparat ai, si mai ales ce emu, difera config-ul!
    Sa nu mai zic de tipul de card, sunt unele care raspund de 3 ori mai repede la ecm, dar asta e alta poveste.
    23 Apr 2008
    Bucharest West
    salut!
    reader intern, VUzero 4k, Oscam
    card B02, banuiesc ca model 2022,
    Merci!
    09 Jul 2010
    rog si eu ajutor (am repornit focussat si oscam dupa 5 ani pt TVR hd) si nu imi merge
    am incarcat, merge TVR 1 dar nu TVR HD (bine nici Digi24 nu merge). Am cerut la Focussat sa imi mai trimit EMM-urile (sper ca imi aduc bine aminte) dar tot nu o ia.
    E ceva din setari la reader, nu?
    Rog ajutor, meciurile pe SD sunt execrabile.
    Am un DM800se cu Oscam de pe vremea bunicii... minim 5 ani nefolosit. A stat acolo singurel
    03 Jul 2022
    romania
    Receptorul Focussat nu-l mai ai? Lasi pe tvr1 juma-de ora sau in oscam cu dvbapiau pornit tot timpul daca ai corect scris readerul dar ajuta mult daca ai si o linie externa N de la cineva cu card focussat.
    7 Post(s)
    Eu cred setarile tale nu sunt corecte, daca tvr ok si tvr hd trebuie sa fie ok.
