Results 1 to 6 of 6
Thread: Oscam FreeBSD
    29 Mar 2007
    Default Oscam FreeBSD
    Salut,
    Nu am mai scris de mult, poate pentru ca oscam-ul nu a mai adus nimic nou . Acum ca este mai mult timp, incerc sa revin. O intrebare simpla : A instalat cineva cu succes un oscam+smartgo pe FreeBSD? Am incercat, am compilat,e ok, insa la rulare nu vad smargo.
    La buna vedere,
    Malin
    93 Post(s)
    Asta vara am sapat o luna la problema asta, l-am compilat (evident cu peripetii), merge perfect client - server dar nu am reusit sa vad readerele pe USB.
    Poate mai fac teste.
    29 Mar 2007
    Pe 12.1 am binarul care cica ar sti smargo, insa problema este la lsusb, nu am bus si device ce trebuie la oascam. Am ID cel de gel 0403:6001, In BSD gasesc de genul Bus /dev/usb Device /dev/ugen0.6: ID 0bda:0138 Realtek Semiconductor Corp. RTS5138 Card Reader Controller. O sa mai sap
    93 Post(s)
    Am facut update la ruter ( pfSense) si acum ruleza:
    Version 2.5.0-DEVELOPMENT (amd64)
    built on Fri Sep 11 07:02:17 EDT 2020
    FreeBSD 12.2-PRERELEASE
    The system is on a later version than official release.
    Version information updated at Mon Sep 14 0:12:07 EEST 2020
    Evident ca oscam-ul compilat pe FreeBSD 11.2 nu mai functioneaza..
    Am compilat versiuni noi pt FreeBSD 12.2-PRERELEASE 64 bit !
    Sunt compilate pe "FreeBSD 12.2-BETA1 r365618 GENERIC amd64"
    oscam-1.20_svn11606-x86_64-portbld-freebsd12.1-ssl
    oscam-1.20_svn_emu-798-x86_64-portbld-freebsd12.1-ssl
    In pfSense se creaza:
    /usr/local/etc/rc.d/oscam.sh
    Code:
    #!/bin/sh
    # $FreeBSD: branches/2019Q2/multimedia/oscam/files/oscam.in 405166 2016-01-03 15:55:22Z riggs $
    # PROVIDE: oscam
    # REQUIRE: DAEMON
    # KEYWORD: shutdown
    # Add the following line to /etc/rc.conf[.local] to enable oscam
    # oscam_enable (bool):  Set to "NO" by default.
    #                               Set it to "YES" to enable oscam.
    # oscam_flags (str):    Custom flags for oscam.
    . /etc/rc.subr
    name=oscam
    rcvar=oscam_enable
    load_rc_config $name
    : ${oscam_enable:=YES}
    pidfile="/var/run/${name}.pid"
    confdir="/usr/local/etc"
    logdir="/var/log/oscam"
    command="/usr/local/bin/oscam"
    command_args="-b -B ${pidfile} "
    start_precmd="${name}_prestart"
    PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin
    oscam_prestart()
            if [ ! -f "${pidfile}" ]; then
                    /usr/bin/install -m 644 /dev/null ${pidfile}
            fi
            if [ ! -d "${confdir}" ]; then
                    /usr/bin/install -m 755 -d ${confdir}
            fi
            if [ ! -d "${logdir}" ]; then
                    /usr/bin/install -m 755 -d ${logdir}
            fi
    run_rc_command "$1"
    In continutul scriptului sunt caile unde se copiaza fisierele de configurare.
    93 Post(s)
    Fiind compilat de pfSense, nu stiu ce ii lipseste si nu apar adaptorele usb2serial in /dev .
    Spre norocul meu minipc-ul are port serial.
    Am reusit sa citesc direct pe seriala:
    Code:
    [reader]
    label                         = HDPLUS
    description                   = HDplus
    protocol                      = mouse
    device                        = /dev/ttyu0
    autospeed                     = 0
    boxkey                        =
    rsakey                        =
    fix07                         = 0
    detect                        = cd
    nagra_read                    = 1
    mhz                           = 500
    group                         = 1,5
    lb_weight                     = 1000
    lb_force_fallback             = 1
    Code:
    2020/12/18 11:39:48 483783E1 r   (reader) HDPLUS [nagra] ROM:    D N A S P 1 8 0
    2020/12/18 11:39:48 483783E1 r   (reader) HDPLUS [nagra] REV:    M e r 0 0 0
    2020/12/18 11:39:48 483783E1 r   (reader) HDPLUS [nagra] SER:    ############
    2020/12/18 11:39:48 483783E1 r   (reader) HDPLUS [nagra] CAID:   1843
    2020/12/18 11:39:48 483783E1 r   (reader) HDPLUS [nagra] Prv.ID: 00 00 34 11 (sysid)
    2020/12/18 11:39:48 483783E1 r   (reader) HDPLUS [nagra] Prv.ID: 00 00 00 00
    2020/12/18 11:39:49 483783E1 r   (reader) HDPLUS [nagra] IRD ID: ############
    2020/12/18 11:39:49 483783E1 r   (reader) HDPLUS [nagra] active to: 2021/02/07 11:59
    2020/12/18 11:39:49 483783E1 r   (reader) HDPLUS [nagra] -----------------------------------------
    2020/12/18 11:39:49 483783E1 r   (reader) HDPLUS [nagra] |id  |tier    |valid from  |valid to    |
    2020/12/18 11:39:49 483783E1 r   (reader) HDPLUS [nagra] +----+--------+------------+------------+
    2020/12/18 11:39:49 483783E1 r   (reader) HDPLUS [nagra] |8011|0066    |2020/12/16  |2021/12/17  |
    2020/12/18 11:39:49 483783E1 r   (reader) HDPLUS [nagra] |8011|0067    |2010/01/19  |2010/01/20  |
    93 Post(s)
