l-am probat....e super..un singur minus...calitatea imaginii sd e mai slaba (e buna) decit la e2board.
Nabilosat Enigma2 - BlackHole DM 800 RC 1
prezentare http://www.maximo.sxhost.info/logoflash/
Enigma version: 2.5 experimental
Enigma cvs date: 29.5.08
Drivers: 26.5.08
Openvpn Kernel module support included. Openvpn fully
embedded in graphic interface.
Nfs kernel support added nfs utils and server included
Default Skin : Army Niro
Alternative Skin : Porto Invader
Main Function KeysButton 1xOK = Light Info SkinAddons
Button 2xOK = Extra Info Skin
Button Blue = Nabilo Blue Panel
Button Blue-Long-Push = Extensions
Button Green = Nabilo Green Panel
Button Green-Long-Push = Subservices
Button Red = Start Record
Button Yellow = Time ShiftDedicated Addons ServerInfobar/OSD
Download and install additional packages from Nabilosat serverNEW Introducing Analogic Clock to Enigma2Nabilo Panels features
Channel Orbital Position
Signal SNR, AGC, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
1) Blue PanelSetupOSD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
OpenVPN Panel
Samba/Cifs Panel
Telnet Panel
FTP PanelInfoCCcam Info
Memory Info
Available Space
Processes
Service Info
Enigma2 Settings
AboutSave2) Green PanelSelect/Start/Restart EMUShoutbox
Fast Plugin
AddonsAddons Download Manager[b]Scripts
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics
DOWNLOAD
NabiloSat Enigma2 BlackHole DM 800 hd pvr
d
Downloand;
http://www.filebox.ro/download.php?k...79353b45809bc1
Scrieti o imagine nou cu ajutorul interfatei webScoateti receptorul din priza, apasati butonul power si introduceti dreamul inapoi in priza. Un mesaj de genul stop va aprea pe display. Acum puteti elibera butonul power. Bootloaderul va intra in "asteptare mod" Deasupra textului STOP, o sa va apara o adresa Ip.
Acum deschideti browserul, tastati "http://ip/" (la ip se va scrie ip-ul afisat de dream). In partea de jos a paginii veti gasi "firmware upgrade", faceti click pe ea. Va va deschide o noua pagina unde aveti posibilitatea sa selectati imaginea flash pe care o doriti. Nu uitati!!! Asigurati-va ca are extensia ". nfi".
Face click pe FLASH si asteptati. Dureaza un pic pana se incarca.
Dupa ce s-a incarcat, inchideti dreamul si redeschideti-l. Noua imaginea ar trebui sa fie instalata si sa mearga.
salut
mi-a venit si mie dreamul 800.....ma puteti ajuta ?....ce fel de settings folositi....?...nu reusesc sa uploadez settings sub nici o forma...cu 2 imagini diferite etc...aceiasi eroare....
Connecting to 192.168.1.70.
Connected.
Dreambox response: Login successful.
Starting FTP transfer
Transfer complete
** Sending file "/var/tuxbox/config/enigma/lamedb" **
Transfer aborted
Error sending file "lamedb" to the Dreambox.
Disconnecting.
Disconnected.
stie cineva ceva...????
daca ai fi citit cu atentie si alte threaduri ai fi vazut ca am explicat deja la cineva cum se face dar tu ai inceput imediat sa te dai la mine fara sa ti fi facut ceva te frige ca nu ti mere dreamul nu ?
va rog sa nu il ajutati pe acest parvenit daca nu este ajutat incepe sa vorbeasca porcos
multumesc anticipat![]()
cu respect Dongle
Cu tot respectul @dongle, dar pe sateliti, eu nu gasesc thread-ul in care faci asta.
pe forumul vecin...... sti tu care![]()
Nu cunosc probleme voastre pe celalalt forum si nici nu ma amestesc. Forumul recomandat la ora actuala nu merge.
As prefera, daca ai dori, sa postezi si aici ce ar trebui sa citim acolo.
Pentru lucrul acesta, dincolo erai acuzat de spam si primeai macar un avertisment. Despre post, n-are rost sa mai spun ce se intampla cu el.
Asa ca, poate-ti faci un pustiu de bine si-i informezi si pe membrii acestui forum.
Multumiri anticipate!
mosule, citeste atent: am spus pe celalalt forum ai fi fost....
nu e cazul aici, ce naiba, tocmai ca ne stim de ceva timp nu am crezut necesar sa explic motamo.
singurul lucru pe care te rugam, era sa posetezi si aici deoarece consider important acest lucru pentru toti viitori posesori de dm800 ai acestui forum.
ps: nu va mai ambalati asa repede, nu-i rdi aici.
ps2: am sa-mi dau toata silinta sa fiu mai clar pe viitor, pana una alta ai ode la mine
bun , si acum lucruri serioase,
are cineva sau exista script de gbox 224 si mgcamd pentru enigma2?..in speta pentru imaginea nabilo??
Ullises postul tau e aici http://sateliti.org/showthread.php?t=2524&page=6 .Tot ce nu contine informatii tehnice va fi mutat acolo.
sincer aseara instalasem nabilo dar azi l am dat jos am dat la nivelul de semnal si il loc de liniuta imi arata o porcarie am crezut ca este greseala de scriere in flash dar l am rescris de 3 orithe same shit
