Page 23 of 26 FirstFirst ... 131920212223242526 LastLast
Results 331 to 345 of 384
Thread: Cccam - Intrebari si raspunsuri
  1. #331
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    Default conflict sci0 cccam-oscam
    salut, de cateva zile am trecut pe 3c213+oscam, dvbapi activat pe 3c.
    totu ok pana la primul reboot sau unul accidental(pana curent...) in sensul ca sci0 intra in conflict, cu toate ca am marit timpul de plecare la 3c fata de oscam sci este lucrat de catre 3c si nu de oscam.
    dupa primul restart camd din panel sau din scriptul de verificare merge ok.
    exista vreo posibilitate gen dvbapi : -1 pentru cccam, in care sa nu foloseasca sci0?
    merci,
    Azbox HD with OpenSPA 3.0 powered by OSCam
    UE46F8000 powered by SamyGO_OSCam
  2. #332
    29 Nov 2008
    Cu capu' in nori
    Pentru 3c ai cumva si script de verificare si restart ?
  3. #333
    26 Oct 2009
    Walachia / Paname
    e scriptul de verificare la 3 min, si scriptul start stop, in plugin mai are autorestart daily intre orele ... dar nu e activat
    ---------- Post added at 14:51 ---------- Previous post was at 14:47 ----------
    Oscam1.20_CCcam2.1.3_cam.sh
    Code:
    #!/bin/sh
    CAMD_ID=6394
    CAMD_NAME="OSCam 1.20/CCcam 2.1.3"
    INFOFILE_A=ecm0.info
    INFOFILE_B=ecm1.info
    INFOFILE_C=ecm2.info
    INFOFILE_D=ecm3.info
    INFOFILE_E=ecm4.info
    INFOFILE_F=ecm5.info
    #Expert window
    INFOFILE_LINES=1111111111000000
    #Zapp after start
    REZAPP=0
    logger $0 $1
    echo $0 $1
    remove_tmp () {
      rm -rf /tmp/*.info* /tmp/*.tmp* /tmp/*mbox* /tmp/*share* /tmp/*.pid* /tmp/*sbox*
    case "$1" in
      start)
      remove_tmp
      /usr/bin/oscam &
      sleep 10
      sed -i '/DVB API/d' /etc/CCcam.cfg
      /usr/bin/CCcam_2.1.3 &
      stop)
      killall -9 oscam CCcam_2.1.3 2>/dev/null
      sleep 2
      remove_tmp
      $0 stop
      exit 0
    esac
    exit 0
    OscamCCcamcheck.sh
    Code:
    #!/bin/sh
    sleep 30
    if ps x |grep -v grep |grep -c CCcam_2.1.3 >/dev/null
    then
    if wget http://.....................
    rm index.html
    then
    echo "CCcam ok."
    fi
    else
    echo `date` "CCcam restarted." >>/var/log/camd_check.log
      sleep 1
      /usr/bin/oscam &
      sleep 10
      #sed -i '/DVB API/d' /etc/CCcam.cfg
      sleep 2
    fi
    process=`ps auxwww | grep oscam | grep -v grep | awk '{print $1}'`
    if [ -z "$process" ]; then
    echo `date` "Oscam restarted...!" >>/var/log/camd_check.log
    #echo "Restart...!"
      sleep 1
      /usr/bin/oscam &
      sleep 10
    else echo "Oscam ok!"
    fi
  4. #334
    sleep 1
    /usr/bin/oscam &
    sleep 10
    sleep 10 e prea mic pune 20, 30 .... testeaza
  5. #335
    26 Oct 2009
    Walachia / Paname
    se pare ca nu e de la script, daca lucrez (start/restart) cu el merge ok, am testat valori de 1, 10, 15, 20, 30 sec la fel face, am dezactivat si crond pentru a nu lucra acel script de verificare, si lui i-am pus un sleep de 30sec am zis ca pleaca imediat dupa reboot si nu mai asteapta cele 3 minute.....
    toata nebunia e doar in caz de reboot
  6. #336
    Eu am avut aceeasi problema, pana n-am marit mult timpul dintre emu nu s-a rezolvat, din buton mergea...
    Specifica box-ul si imaginea care o ai. unul care merge acum e asa
    oscam
    sleep 1
    sbox
    sleep24
    cccam
    La pornire box scriptul se comporta altfel decat la buton
  7. #337
    Standard RSP member cezarelqwe's Avatar
    Default provider internet cu porturi blocate
    salutare
    am si eu o nelamurire:
    daca provideru de net are porturile blocate ce este de facut?
    1- sa zicem ca serverul nr.1 are porturile de la providerul de net deblocate iar serverul nr.2 are porturile blocate
    se poate macar sa primeasca severul2 de la severul 1 o linie pt share?
  8. #338
    23 Apr 2007
    P3X-888
    Daca providerul nu doreste sa-ti deschida un port atunci nu se poate face nimic pentru a da linii dar poti primi linii adica sa fii doar client . Serverul 2 poate primi linie din serverul 1 in coditiile date de tine .
  9. #339
    23 Jun 2008
    Da. Serverul 2 poate primi o linie de la serverul 1.
    Ar fi o varianta sa instalezi un server VPN in reteaua serverului 1 si un client de VPN in reteaua serverului 2.
    In felul acesta ai putea sa expui niste porturi din serverul 2 in internet folosind tunelul creat intre cele doua retele.
    Exista routere lowcost care au functii de VPN server/client.
  10. #340
    Default multam pt raspunsuri
    multumesc ibitza si stargate
  11. #341
    叛徒 daradici's Avatar
    12 Apr 2008
    覆盆子灌木
    Ne poti da exemplu de un asemenea router ?
    Informatia e chiar interesanta !
    Mai exista varianta Hamachi, dar asta trebuie instalata pe doua calculatoare fiecare in reteaua lui si se pot face conexiuni care fac sa poti comunica si server nu doar client.
    Ideal e sa-ti schimbi providerul de internet, si eu am avut un asemenea provider, am renuntat foarte greu, ca aveam download 30 Mb/s si upload tot 30Mb/s.
  12. #342
    23 Jun 2008
    De exemplu, orice router care pe care se poate instala dd-wrt poate fi configurat atat ca server de VPN cat si client.
    Baza de date cu routerele suportate este aici: http://www.dd-wrt.com/site/support/router-database
    Se poate configura Open VPN Server si pe PC: http://openvpn.net/
    Solutii exista dar nu stiu cat sunt de fiabile pe o conexiune mobila.
  13. #343
    Super Member
    15 May 2007
    Intrebare legata de reshare si downhops..
    Am in .cfg un user (cccam 2.30) care face un consum de 5-6000 de ecm/ora. Imi apare in info ca ar rula 2.0.11 el pe serverul lui, dar chiar si cu
    0 0 0 { 0:0:0 } are acelasi usage. pana la urma l-am sters, intrebarea mea e: CCCam poate fi "protejat" de ignorarea downhops/reshare data de folosirea Oscam ca reader?
    Banuiesc ca despre asta e vorba..
  14. #344
    dMd
    Guest
    Userul respectiv asa cum ai banuit nu ruleaza CCcam, chiar daca apare ca ar avea 2.0.11 si cred ca tasta delete este rezolvarea daca ai discutat cu el si tot acelasi trafic il face. O varianta de protectie ar fi sa folosesti si tu oscam si sa ii setezi userului respectiv functia anticascading in asa fel incat sa fie limitat la un numar de cereri.
  15. #345
    Se impunea delete, dar era interesant sa vedem cum a ocolit 0 0 0 { 0:0:0 }. Asta trebuia verificat.
    In oscam nu-ti pasa de ce reshare ti se da, doar hop-urile conteaza.
    Cat despre anticascading in oscam, cred ca poti pune daca nu se lucreaza cu reshare, altfel ii mai bagi fake.
    Si relatia nu are cum sa dureze...
