Thanks Thanks:  3
Likes Likes:  4
Results 1 to 2 of 2
Thread: Meecol K7 receiver combo cu android 9
    30 Post(s)
    Default Meecol K7 receiver combo cu android 9
    Dupa cum era de asteptat , concurenta nu ''sta cu mainile in san'' si dupa ce a scos receiverul anterior - Meecol K6 cu SoC-ul de la Hisilicon HI3798MV200
    Acum au scos un nou receptor - Meecol K7 - cu SoC-ul de la AmLogic , in speta - S905X2 - insa noul receptor e mai ''potent'' la memorie :
    - 4Gb ram sistem in loc de 2Gb ram sistem la receptorul anterior
    - 64Gb flash in loc de 16Gb flash la receptorul anterior
    Din pacate multi fabricantii , inca nu doteaza receptoarele lor cu android cu ram-ul adecvat ultimilor versiuni de android si de aici pot aparea varii prb
    - Specification Meecol K7 :
    Hardware
    GPU: Mali-G31
    System: Android 9.0
    CPU: Amlogic S905X2
    Core: Quad Core
    RAM: 4G RAM
    RAM Type: LPDDR4
    ROM: 64G ROM
    Max. Extended Capacity: TF card up to 32GB (not included)
    Communication
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac
    Bluetooth: Bluetooth 4.1 + EDR
    LAN: 1000M
    Media
    Decoder Format: HD MPEG1/2/4, H.265/HEVC, HD AVC/VC-1, RM/RMVB, Xvid, RealVideo8/9/10
    Audio format: Supports MP3, AAC, WMA, RM, FLAC, Ogg and programmable with 7.1/5.1 down-mixing
    Video format: Hardware decoders
    - VP9 Profile-2 up to 4Kx2K@60fps
    - H.265 HEVC MP-10@L5.1 up to 4Kx2K@60fps
    - AVS2-P2 Profile up to 4Kx2K@60fps
    - H.264 AVC HP@L5.1 up To 4Kx2K@30fps
    - H.264 MVC up to 1080P@60fps
    - MPEG-4 ASP@L5 up to 1080P@60fps (ISO-14496)
    - WMV/VC-1 SP/MP/AP up to 1080P@60fps
    - AVS- P16(AVS+) /AVS-P2 JiZhun Profile up to 1080P@60fps
    - MPEG-2 MP/HL up to 1080P@60fps (ISO-13818)
    - MPEG-1 MP/HL up to 1080P@60fps (ISO-11172)
    - RealVideo 8/9/10 up to 1080P@60fps
    Photo Format: HD JPEG/BMP/GIF/PNG/TIFF
    Support 5.1 Surround Sound Output: Yes
    Interface
    ANT-OUT, CVBS/L/R, DVB-S2, HDTV In, HDTV Out, LAN, Optical, S2, T2, TF card, USB2.0, USB3.0
    Other Features
    Antenna: Yes
    Language: Multilanguage
    HDMI Version: 2.1
    Other Functions: Others
    HDMI Function: HDCP
    Power Consumption: 5W
    RJ45 Port Speed: 1000Mbps
    Remote Controller Battery: 2 x AAA Battery ( not included )
    Power
    Power Type: External Power Adapter Mode
    Power Input Vol: 12V
    Power Adapter Input: 100-240V / 50-60Hz
    Power Adapter Output: 5V 2A
    Dimensions&Weight
    Product Weight: 0.2816 kg
    Package Weight: 0.7070 kg
    Product Size (L x W x H): 16.20 x 12.10 x 2.90 cm / 6.38 x 4.76 x 1.14 inches
    Package Size (L x W x H): 18.30 x 15.70 x 7.20 cm / 7.2 x 6.18 x 2.83 inches
    Package Contents
    1 x TV Box
    1 x Remote Control
    1 x HDMI Cable
    1 x Power Adapter
    1 x English Manual
    sursa - https://androidpctv.com/review-mecool-k7-opinion/
    Ca si puncte negative are:
    - lipsa orice fel de cititot ( cam sau/si cartela ) si asta presupune folosirea unui cititor extern pe usb
    - fiind cu SoC de la AmLogic - S905X , nu sunt prea multe imaginii E2 ca la SoC-ul de la Hisilicon - Hi3798MV200
    Cumparat de pe afara , ca pret e undeva la 700 lei
    31 Aug 2010
    Am cumpărat K7 de pe Geekbuying, vine cu firmware 20191015 şi nu are root. Mai exact e prost făcut şi nu e recunoscut de aplicaţii. Aplicaţia DTV găseşte doar două posturi TV pe Digi cablu cu setarea implicită China şi maxim 109 posturi cu alte ţări. Deşi are SoftCam.key cu aproape tot ce îi trebuie inclus, nu funcţionează deloc. Network ID scan nu funcţionează pentru că au greşit numărul de cifre la Symbolrate. Chiar dacă pun 6900, aplicaţia adaugă un zero şi evident nu găseşte niciun post.
    Faţă de K3, telecomanda e mult mai subţire şi mai uşoară, are butoane dedicate pentru DTV şi browser, trecerea între ele se face aproape instantaneu. Butoanele de la telecomandă sunt însă tari şi fac un zgomot. Nu mai are buton fizic pentru pornire, butonul de reset e ascuns în portul audio de 3,5.
    Sfatul meu e să nu îl cumpăraţi momentan, aşteptaţi să rezolve problemele de soft.
