Results 1 to 4 of 4
Thread: OpenBH 4.3 Kodi 18.3 Beta 2 with Addons Netflix, Amazon Prime
    29 Sep 2017
    Bucharest
    Default OpenBH 4.3 Kodi 18.3 Beta 2 with Addons Netflix, Amazon Prime
    Whats New:​
    • Now working with Addons that support Netflix, Amazon Prime and other streaming services with your regular subscription.
    • There is no hardware acceleration at the moment so the player is not perfect but it is working.
    PLEASE NOTE THIS IS A BETA RELEASE FOR KODI 18.3 FOR VU+ 4K ARM STB'S ONLY.
    Warning as this is a beta image, Kodi is included, so do not try to install from the feeds or you will load an old version (Kodi 17) and do not try and online update this image as it will fail and you also risk corrupting the image.
    You can test Kodi 18 addons for Netflix, Amazon and so on.
    Here are the two repositories that we have tested and know the addons from here are working:
    Castagna.it for Netflix and Sandmann79 for Amazon (if you can not get Amazon to work then use the Amazon VOD addon instead).
    You have to enable external sources, install as zip file and then install from the repository or search for these addons on google for detailed instructions.
    *** These images have Kodi 18 pre-installed, so please do not try to load Kodi from the feeds. ***
    **** There is currently no Beta 2 image for Duo4K due to a driver issue that we are waiting for Vu+ to fix first ****
    Where can I find the OpenBH git ?
    The OpenBH git is located here: https://github.com/BlackHole
    Thanks to:
    • Rytec, doglover and all the teams that host EPG feeds for EPG Importer, for their continued support.
    • All developers for their plugins used in the feeds of this image.
    • All of the BH Beta team for their hours of testing and dedication on improving the image.
    • All those who have submitted patches/fixes
    • To all who have submitted translation work for OpenBH.
    • Huevos for his work on blindscan and ABM.
    • Peter de Jonge, abu baniaz & Huevos for their work with Andyblac to improve ABM.
    • Matrix10 for OpenBH skins.
    DISCLAIMER
    THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
    THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
    https://www.vuplus-community.net/boa...-beta-2.39672/
    29 Sep 2017
    Bucharest
    Am instalat si eu de test si pot spune ca, sunt placut surprins atat de calitatea imaginii mai ales in format 4K cat si de calitatea sunetului care este pe anumite filme 5.1 Dolby HD,clar sunt diferente majore intre redarea Netflix pe un tv care are implentat acest apps si ceea ce se reda cu ajutorul receiverului VU+solo4K si Kodi 18,instalarea se face usor,practic se instaleaza imaginea din link-ul de mai sus,se deschide Kodi si se instaleaza repositories unul din ele sau amundoua la alegere,aveti tutoriale pe youtube cum sa procedati,iata cateva imagini dupa instalarea si activarea Netflix:
    05 Oct 2016
    Petrosani
    Salut! Netflixul este doar o aplicatie smart instalata si payata sau miracol... free. Multumesc!!!
    29 Sep 2017
    Bucharest
    #Kiru
    Important este sa si functioneze pe ceea ce vrei,altfel degeaba este .."aplicatie"...daca,nu iti functioneaza pe ce device-uri vrei....iar in cazul de fata eu ma declar multumit.
