Thanks Thanks:  6
Likes Likes:  43
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Am cumparat din targ, UFS910
    PKT E2, am sa incerc cu telnet mâine când ajung acasă.
    Cu sbox.sh40 in /var/emu emulatorul apare in EMU Manager dar nu am reusit sa-l pornesc din telnet. Impreuna cu sbox.config le-am mutat in /usr/bin; SBox nu mai apare in EMU Manager (l-am lasat pe "Niciun CAM activ"). Acum porneste din telnet, dar daca restartez receptorul sau intrerup alimentarea cu 220 V Sbox trebuie iar pornit din telnet. Am editat scriptul pentru ppc, l-am copiat in /usr/scriptl dar problema persista:
    #!/bin/sh
    ###### Powered by The Gemini Team ######
    ### http://www.i-have-a-dreambox.com ###
    # camid #
    # 0000 = Commom Interface #
    # 0001->0199 = for User Experiment #
    # 0199 = Dccamd #
    # 0200->0299 = Fbiss #
    # 0300->0399 = Camd3 #
    # 0400->0499 = Camx #
    # 0500->0599 = Camx-Radegast-CS #
    # 0600->0699 = Evocamd -OLD #
    # 0700->0799 = Evocamd_ronlad_cs -OLD #
    # 0800->0899 = Mgcamd -OLD #
    # 0900->0999 = Mgcamd_ronald_cs -OLD #
    # 1000->1099 = Newcamd -OLD #
    # 1100->1199 = Newcamd-ronald_CS -OLD #
    # 1200->1299 = Newcamd-spider -OLD #
    # 1300->1399 = Radegast #
    # 1400->1499 = Ronald-CS #
    # 1500->1599 = Scam #
    # 1600->1699 = Scam-Ronald-CS #
    # 1700->1799 = MPCS #
    # 1800->1899 = NewCS #
    # 2000->2099 = Camd3 #
    # 2300->2399 = Camd3-NewCS #
    # 2600->2699 = Camd3-MPCardserver #
    # 3000->3099 = Evocamd #
    # 3100->3199 = Evocamd-Ronald-CS #
    # 3200->3299 = Evocamd-NewCS #
    # 3300->3399 = Evocamd-MPCardserver #
    # 4000->4099 = Mgcamd #
    # 4100->4199 = Mgcamd-Ronald-CS #
    # 4200->4299 = Mgcamd-NewCS #
    # 4300->4399 = Mgcamd-MPCS #
    # 5000->5099 = Newcamd-Betad #
    # 5100->5199 = Newcamd-Cardserver #
    # 5200->5299 = Newcamd-Spider #
    # 5300->5399 = Newcamd-NewCS #
    # 5400->5499 = Newcamd-MPCS #
    # 5500->5599 = OpenCam #
    # 5600->5699 = RqCamd #
    # 6000->6099 = CCcam #
    # 6100->6199 = CCcam-Capmtserver #
    # 6200->6299 = CCcam-NewCS #
    # 6300->6399 = CCcam-MPCS #
    # 9500->9599 = reserved #
    # 9600->9699 = reserved #
    # 9700->9799 = reserved #
    # 9800->9899 = reserved #
    # 9900->9999 = reserved #
    CAMNAME="Sbox"
    USERNAME=""
    ZAPTIME=6
    CAMID=9501
    DVBSET=0
    INFOFILE="ecm.info"
    INFOFILELINES=
    # end
    remove_tmp () {
    rm -rf /tmp/*.info* /tmp/*.tmp*
    case "$1" in
    start)
    echo "[SCRIPT] $1: $CAMNAME"
    remove_tmp
    /usr/bin/sbox.sh40
    stop)
    killall -9 sbox.sh40
    remove_tmp
    $0 stop
    exit 0
    esac
    exit 0
    Va rog, un pic de ajutor.
    Am pus ultima imagine Neurino 3.7.7 care parea OK.
    Pe Thor nu receptioneaza o mare parte din canale si nu am reusit sa rezolv cu setarile de HIGH_SR !
    Ceva idei?
    Acum ma jucam cu TitanNIT.
    Nu reusesc sa mut antena pe USALS, desi am gasit ceva setari evident idiot facute!
    ---------- Post added at 00:44 ---------- Previous post was at 00:32 ----------
    Am reusit cu USALS, evident trebuia un reboot dupa configurare.
    Maine fac ceva capturi de ecran ....
    Nu merg programele HD CU SR 30000 pe Neutrino, acum ceva timp nici pe TitaNIT.
    Am facut azi ceva "cercetare" si am descoperit ca nu merge decat pe imagini vechi SR30000 de pe Thor.
    Au mutat ceva parametrii din PTI in stmdvb si probabil nimeni nu tzipa!
    CU imagine Neutrino mai veche merg si canalele cu sr30000
    Default Am cumparat din targ, UFS910
    Am reusit sa descarc ultima imagine in care merg canalele cu SR30000:
    BP-NMP_miniFLASH_BASE-rev6402
    Are oscam la download si spatiu de instalare.
    Imaginile noi sunt mai mari si trebuie sa pui stick sa se extindă.
    Recomand in Flash aceasta imagine si altele pe stick.
    Am generat o lista de canale la zi pe 5 sateliti de interes
    EnF_N3_20201004_23E_19_16_13_1W.zip
    Se copiaza satellites.xml in /var/tuxbox/config/
    restul fisierelor in /var/tuxbox/config/zapit/
    apoi restart la box
