MultiCS r84 E0:
**** Sky Germany package fixed, CARD 098C,09C4 patch based on oscam patch for multics.
* GUI Flat CSS.
* Cacheex Mode2/3 optimized (cccam/cs378x/camd35).
* CS378x/Camd35 server fixed (now cs378x server or camd35 server can answer to ecm request like CCcam/MGcamd).
* Fixed CCcam 10s freeze with somes old box.
* Sids limit on Fline/MGUSER added => F: user pass { sids=sid1:chid1:ecmlen1,sid2:chid2:ecmlen2; } (same for mguser).
* SkipCWC added to profile (for french packages and german packages 098c,09c4 ) - default=no.
* AcceptNullDCW added to profile (for some NDS packages)- default=no.
* Cacheex server not disconnected on restart fixed.
* Fixed many bugs.
PROFILES:
Code:##################### [SKY DETSH - 098C:000000] ##################### PORT: + ONID: 0085 CAID: 098C PROVIDERS: 000000 DCW CHECK: 0 ECM CHECK LENGTH: 0 DCW RETRY: 0 DCW HALFNULLED: 1 DCW SWAP: 1 ACCEPT NULL SID: 1 ENABLE SKIPCWC: YES cache timeout: 250 enable cache: 1 ACCEPT NULL DCW : 1For TNTSAT:Code:################## [SKY DETSH - 09C4:000000] ################## PORT: + ONID: 0085 CAID: 098C PROVIDERS: 000000 DCW CHECK: 0 ECM CHECK LENGTH: 0 DCW RETRY: 0 DCW HALFNULLED: 1 DCW SWAP: 1 ACCEPT NULL SID: 1 ENABLE SKIPCWC: YES cache timeout: 250 enable cache: 1 ACCEPT NULL DCW : 1
Download: 64.bitCode:################## [TNTSAT 0500:30B00] ################## PORT: + CAID: 0500 PROVIDERS: 030B00 ECM CHECK: NO ECM CHECK LENGTH: YES DCW TIMEOUT 4000 DCW CHECK YES DCW HALFNULLED:NO DCW SWAP:NO ENABLE SKIPCWC: 1 DCW MAXFAILED: 1 SERVER MAX: 0 SERVER INTERVAL:100 SERVER TIMEOUT:3500 SERVER VALIDECMTIME:5000 SERVER FIRST:5 ACCEPT NULL DCW:0 ACCEPT NULL CAID: 0 ACCEPT NULL PROVIDER:0 ACCEPT NULL SID:NO ENABLE CCCAM:YES ENABLE NEWCAMD:YES ENABLE RADEGAST:NO ENABLE CS378X:YES ENABLE CACHE:YES ENABLE CACHEEX :1 CACHEEX MAXHOP:2 RETRY NEWCAMD:0 RETRY CCCAM:0 CACHE TIMEOUT: 250 CACHE SENDREQ: YES
https://www.mediafire.com/file/b2lpe...84_e0.zip/file
