Hot , Hot, Hot !
versiunea V15 pe val:
## Changelog
## r82-hellboy-V15-beta-dirty
- [ENH] Enable sending cache from multics to oscam (cspsendcache option)
## r82-hellboy-V14-beta-dirty
- [ENH] Added to identify HB version in cache section
- [CLN] Removed ACCEPT NULL CAID and ACCEPT NULL PROVIDER
- [FIX] Disallow to create profiles without CAID and PROVIDERS parameter (before: without these params was able to create profiles with auto 0 as value)
## r82-hellboy-V13-beta-dirty
- [CLN] Code cleanup.
## r82-hellboy-V12-beta-dirty
- [ENH] Send telegram message on failed login attempt to multics web
- [ENH] Added exception for tunneled Nagra 1884,1861
## r82-hellboy-V11-beta-dirty
- [ENH] Implemented restart command in telnet server
- [ENH] This version will identify itself as "Multics-HB r82" in the cache section of your peers. This way you can know which of your peers are using "Hellboy" :)
- [ENH] Added exception for tunneled Nagra 1862
Name change :) NEW NAME hellboy
## r82-hellboy-V10-beta-dirty
- [ENH] Now multics can send you a Telegram message when started or restarted
- [FIX] Solve buffer overflow in logging function
- [FIX] Control null pointer in newcamd server causing segfault
- [FIX] Control null pointer in mgcamd server causing segfault
- [FIX] Added to exceptions tuneled Nagra card (1817, 1818)
## r82-Bust3D-V9-beta-dirty
- [NEW] Added Stealth Mode for CCcam Server: Behaviour like the original CCcam.
NOTE: Because who use this version of multics and will let only with valid PROFILES to run, you can use it as Stealth Mode. :)
Option is available in multics.cfg # CCCAM STEALTHMODE: NO # Behaviour like the original CCcam default NO
## r82-Bust3D-V8-beta-dirty
- [FIX] Stylesheet file check funktion fixed now works.
## r82-Bust3D-V7-beta-dirty
- [FIX] Added to exception tuneled Nagra card 1819
## r82-Bust3D-V6-beta-dirty
- [NEW] Added possibility to choose CCCam up to version 2.3.2 (2.0.11, 2.1.1,2.1.2, 2.1.3, 2.2.1, 2.3.0, 2.3.1, 2.3.2).
- [FIX] Small bugfixes to able to compile other architectures.
TELEGRAM BOT
You need to create a telegram bot and enable telegram in config and configure the token and chatid.
The parameters are:
TELEGRAM ENABLE: 1 ## Enable or disable telegram
TELEGRAM TOKEN: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" ## Token obtained for the telegram bot
TELEGRAM CHATID: "12345678" ## The chatid in your telephone for the conversation with the telegram bot
To create a telegram bot and obtain token and chatid you can look for multiple guides on the Internet like
https://www.shellhacks.com/telegram-api-send-message-personal-notification-bot
To send cache from multics to oscam (without filtering):
CACHE PEER: host port { csp=1; cspsendcache=1 }
To filter cache sent from the multics to other peer (multics or oscam) now you can use "shares" with the syntax:
CAID1:pROVID1&PROVID2,CAID2:pROVID1
Examples:
- Filter only for sending cache only from 1810:000000 to a oscam peer:
CACHE PEER: host port { csp=1; cspsendcache=1; shares=1810:000000 }
- Filter for sending cache only from 1810:000000, 0100:004106 and 0100:00006A to a multics peer:
CACHE PEER: host port { shares=1810:000000,0100:004106&00006A }
