Results 1 to 11 of 11
Thread: r82-hellboy-V10-beta-dirty
    02 Sep 2010
    Earth
    Thumbs up r82-hellboy-V10-beta-dirty
    ## Changelog
    Name change NEW NAME hellboy
    ## r82-hellboy-V10-beta-dirty
    - [ENH] Now multics can send you a Telegram message when started or restarted
    - [FIX] Solve buffer overflow in logging function
    - [FIX] Control null pointer in newcamd server causing segfault
    - [FIX] Control null pointer in mgcamd server causing segfault
    - [FIX] Added to exceptions tuneled Nagra card (1817, 1818)
    Un nou concept, bazat pe profile construite tehnic si nu in mod arbitrar,stabilitate, optimizat pentru mai multe arhitecturi.
    Prin acest nou concept s-a incercat eliminare "cache-ului otravit" si a bad ecm recquest/ bad dcw/cwc release.
    pentr a o putea folosi trebuie sa va adaptati ( CORECTATI !!! ) doar profilele.
    PENTRU CEI CARE VOR SA O INSTALEZE PE CURAT LE RECOMAND FOLOSIREA REVIZIEI R46 de profile create de "watchdogs"
    Nu am cum sa pun un link pe un gestionar de arhivbe acuma asa ca deocamdata pana cineva il urca in sticky il puteti descarca din site-ul oficial aici !
    07 Sep 2013
    https://t.me/blackhatshiller
    Fa update la ultima versiune
    RSR Cache Blaster!
    02 Sep 2010
    Earth
    Hot , Hot, Hot !
    versiunea V15 pe val:
    Code:
    ## Changelog
    ## r82-hellboy-V15-beta-dirty
    - [ENH] Enable sending cache from multics to oscam (cspsendcache option)
    ## r82-hellboy-V14-beta-dirty
    - [ENH] Added to identify HB version in cache section
    - [CLN] Removed ACCEPT NULL CAID and ACCEPT NULL PROVIDER
    - [FIX] Disallow to create profiles without CAID and PROVIDERS parameter (before: without these params was able to create profiles with auto 0 as value)
    ## r82-hellboy-V13-beta-dirty
    - [CLN] Code cleanup.
    ## r82-hellboy-V12-beta-dirty
    - [ENH] Send telegram message on failed login attempt to multics web
    - [ENH] Added exception for tunneled Nagra 1884,1861
    ## r82-hellboy-V11-beta-dirty
    - [ENH] Implemented restart command in telnet server
    - [ENH] This version will identify itself as "Multics-HB r82" in the cache section of your peers. This way you can know which of your peers are using "Hellboy" :)
    - [ENH] Added exception for tunneled Nagra 1862
    Name change :) NEW NAME hellboy
    ## r82-Bust3D-V9-beta-dirty
    - [NEW] Added Stealth Mode for CCcam Server: Behaviour like the original CCcam.
    NOTE: Because who use this version of multics and will let only with valid PROFILES to run, you can use it as Stealth Mode. :)
    Option is available in multics.cfg # CCCAM STEALTHMODE: NO # Behaviour like the original CCcam default NO
    ## r82-Bust3D-V8-beta-dirty
    - [FIX] Stylesheet file check funktion fixed now works.
    ## r82-Bust3D-V7-beta-dirty
    - [FIX] Added to exception tuneled Nagra card 1819
    ## r82-Bust3D-V6-beta-dirty
    - [NEW] Added possibility to choose CCCam up to version 2.3.2 (2.0.11, 2.1.1,2.1.2, 2.1.3, 2.2.1, 2.3.0, 2.3.1, 2.3.2).
    - [FIX] Small bugfixes to able to compile other architectures.
    Code:
    TELEGRAM BOT
    You need to create a telegram bot and enable telegram in config and configure the token and chatid.
    The parameters are:
    TELEGRAM ENABLE: 1 ## Enable or disable telegram
    TELEGRAM TOKEN: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" ## Token obtained for the telegram bot
    TELEGRAM CHATID: "12345678" ## The chatid in your telephone for the conversation with the telegram bot
    To create a telegram bot and obtain token and chatid you can look for multiple guides on the Internet like
    https://www.shellhacks.com/telegram-api-send-message-personal-notification-bot
    To send cache from multics to oscam (without filtering):
    CACHE PEER: host port { csp=1; cspsendcache=1 }
    To filter cache sent from the multics to other peer (multics or oscam) now you can use "shares" with the syntax:
           CAID1:pROVID1&PROVID2,CAID2:pROVID1
    Examples:
    - Filter only for sending cache only from 1810:000000 to a oscam peer:
    CACHE PEER: host port { csp=1; cspsendcache=1; shares=1810:000000 }
    - Filter for sending cache only from 1810:000000, 0100:004106 and 0100:00006A to a multics peer:
    CACHE PEER: host port { shares=1810:000000,0100:004106&00006A }
    07 Sep 2013
    Link direct de download pt executabile(UNGUR BULAN) si config (ferari)
    https://www.dropbox.com/s/aqlbiqrwut...dirty.zip?dl=0
    https://www.dropbox.com/s/lhr2kvtqhg...files.rar?dl=0
    RSR Cache Blaster!
    02 Sep 2010
    Earth
    Code:
    ## Changelog
    ## r82-hellboy-V16-beta-dirty
    - [ENH] Identify Hellboy version of the newcamd and mgcamd servers you connect to.
    - [CLN] Some more Code cleanup.
    New release.
    07 Sep 2013
    Mda,schimba unguru versiunile zilnic...eu raman la v15 2,3 sapt pana ajunge asta la v30 sau daca chiar schimba ceva la el ,nu doar numele ))
    RSR Cache Blaster!
    24 Mar 2009
    multics-r82-hellboy-V58-NOLIMIT-beta-dirty
    https://www.mediafire.com/file/4mkfz...dirty.zip/file
    24 Mar 2009
    Standard RSP member cristian's Avatar
    22 Dec 2007
    undeva candva
    Ok.... dar nu este bin-ul ptr multics
    22 Dec 2007
    undeva candva
    https://wormhole.app/68rL8#qYjUrVprf0_kh0G0O8_l7w
    aici este bin-ul ptr hb59....insa este inutil deoarece
    /var/etc/bin/multics.x64 -C /var/etc/multics.cfg -b4
    ONEUpdaterCheck failed!
    24 Mar 2009
    MultiCS HB59 - NO_LIMIT
    Dear, I know it was time for an update and without further ado, here it is!
    This modification needs no introduction but it is always good to remember that it is unstable and unexpected results can occur.
    Changes from the original:
    Removed row limit as a server.
    Removed user limit
    It allows connection to any version both as a server and as a cache.
    Update message disabled
    Removed ONEupdater check (initial and while running every 30 minutes)
    All functions and menus available when there is a new version
    Size: 423856 bytes (413 KB)
    CRC32: 567E26A0
    CRC64: 1AAF660EE0043C6B
    SHA256: 5BBD4167C9C3849D1830D79CC3B55B66A6374471179405DF6FF7915BD3E24DD2
    SHA1: 79562CAE38DC90751F19832A76D5A74E6CEE7C5E
    BLAKE2sp: E9C6CC0866DC483C5591C24801490E208DA02FB1B87474ACD7167E0B1E22E907
    https://www.mediafire.com/file/hk8tc...t.x64.zip/file
