salut
se da un vps cu Openvpn:
se mai da un client local legat prin Openvpn la vps:Code:root@vps ~ > ifconfig lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 RX bytes:1295300 (1.2 MB) TX bytes:1295300 (1.2 MB) tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 inet addr:10.8.0.1 P-t-P:10.8.0.2 Mask:255.255.255.255 UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) venet0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 inet addr:127.0.0.2 P-t-P:127.0.0.2 Bcast:0.0.0.0 Mask:255.255.255.255 RX bytes:264275751 (264.2 MB) TX bytes:293221619 (293.2 MB) venet0:0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 inet addr:x.x.x.x P-t-P:x.x.x.x Bcast:x.x.x.255 Mask:255.255.255.0 UP BROADCAST POINTOPOINT RUNNING NOARP MTU:1500 Metric:1
deci tunelul vpn e în picioare, merge. de pe vps pot da ping pe 10.8.0.6 (serverul local) si-l vede; si invers la felCode:root@lunix:~# ifconfig enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.44 netmask 255.255.255.0 broadcast 192.168.0.255 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500 inet 10.8.0.6 netmask 255.255.255.255 destination 10.8.0.5
nu am reusit sa fac rutarea traficului de pe serverul local pe vps în ambele directii, inclusiv deschiderea porturilor pe vps înspre serverul local.
arhitectura ar fii cam asta:
pe server am activat IP forwarding in /etc/sysctl.conf prin "net.ipv4.ip_forward = 1"Code:| VPS | (x.x.x. IP)| |10.8.0.6 {INTERNET}=============={venet0:0 tun0}=============<internal network 192.168.0.44 | \ / | | +----------------------+ | | | iptables and | | | | routing engine | | | +--+----------------+--+ | | |*1 |*2 | | (openvpn)-------{tun0} | | 10.8.0.5 10.8.0.1 |
am încercat tot felul de reguli pentru iptables, dar nu am reusit.
cel mai logic ar fii:
Code:# Allow traffic initiated from VPN to access LAN iptables -I FORWARD -i tun0 -o venet0 -s 10.8.0.0/24 -d 192.168.0.0/24 -m conntrack --ctstate NEW -j ACCEPT # Allow traffic initiated from VPN to access "the world" iptables -I FORWARD -i tun0 -o venet0:0 -s 10.8.0.0/24 -m conntrack --ctstate NEW -j ACCEPT # Allow traffic initiated from LAN to access "the world" iptables -I FORWARD -i venet0 -o venet0:0 -s 192.168.0.0/24 -m conntrack --ctstate NEW -j ACCEPT # Allow established traffic to pass back and forth iptables -I FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT # Notice that -I is used, so when listing it (iptables -vxnL) it # will be reversed. This is intentional in this demonstration. # Masquerade traffic from VPN to "the world" -- done in the nat table iptables -t nat -I POSTROUTING -o venet0:0 -s 10.8.0.0/24 -j MASQUERADE # Masquerade traffic from LAN to "the world" iptables -t nat -I POSTROUTING -o venet0:0 -s 192.168.0.0/24 -j MASQUERADE
dar nu vrea...
Cine ma poate "lumina"? dau o bere!
PS: ideea e ca in viitorul apropiat tot mai multi provideri de internet vor trece la ipv6 pentru clienţii lor, şi vor fii multe schimbări în reţelistica "schimbului de informaţii"
