Thanks Thanks:  7
Likes Likes:  15
Results 16 to 30 of 52
Thread: Problema funcționare Oscam+ Digi 1802
    18 Nov 2018
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] THIS WAS A SUCCESSFUL START ATTEMPT No  1 out of max alloted of 1
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] ROM:    D N A S P 1 4 2
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] REV:    R e v G 0 6
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] SER:    ############
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] CAID:   1802
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] Prv.ID: 00 00 20 11 (sysid)
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] Prv.ID: 00 00 00 00
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] IRD ID: ############
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] active to: 2019/04/23 12:59
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] -----------------------------------------
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] |id  |tier    |valid from  |valid to    |
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] +----+--------+------------+------------+
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] |2111|0067    |2010/09/16  |2018/06/01  |
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] |2111|0065    |2010/09/16  |2018/06/03  |
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] |2111|F639    |2011/05/01  |2018/06/03  |
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] |2111|121A    |2012/05/09  |2018/09/09  |
    2018/12/30 13:46:10 18190CBA r   (reader) gigi [nagra] |2111|0040    |2018/11/12  |2019/03/07  |
    2018/12/30 13:46:11 00000000 s     (main) init for all local cards done
    2018/12/30 13:46:11 00000000 s (emmcache) loaded 67 emmcache records from /tmp/.oscam/oscam.emmcache in 14 ms
    2018/12/30 13:46:11 00000000 s (emmcache) loaded 67 emmstat records from /tmp/.oscam/oscam.emmstat in 17 ms
    2018/12/30 13:46:11 00000000 s (anticasc) anti cascading disabled
    2018/12/30 13:46:11 3104C28C c   (client) plain dvbapi-client granted (local, au=auto (2 reader))
    2018/12/30 13:46:11 3104C28C c   (dvbapi) dvbapi channelcache loaded from /var/tuxbox/config/oscam.ccache
    2018/12/30 13:46:11 3104C28C c   (dvbapi) Detected /dev/dvb/card0/demux0 Api: 1, userconfig boxtype: 1 maximum amount of possible filters is 23 (oscam limit is 32)
    2018/12/30 13:46:11 3104C28C c   (dvbapi) Demuxer 0 ecmpid 0 CAID: 1802 ECM_PID: 1016 PROVID: 000000
    2018/12/30 13:46:11 3104C28C c   (dvbapi) Demuxer 0 ecmpid 1 CAID: 1880 ECM_PID: 1017 PROVID: 000000
    2018/12/30 13:46:11 3104C28C c   (dvbapi) Demuxer 0 found 2 ECMpids and 3 STREAMpids in caPMT
    2018/12/30 13:46:11 3104C28C c   (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1802 PROVID 000000 ECMPID 1016 ANY CHID PMTPID 0000 VPID 01F5
    2018/12/30 13:46:11 3104C28C c   (dvbapi) Demuxer 0 found 2 ECMpids and 3 STREAMpids in PMT
    2018/12/30 13:46:12 3104C28C c      (ecm) local (1802@000000/0000/03E9/92:53F0B440FB62210C2CB83EA495D26938): not found (454 ms) by gigi - TVR 1
    2018/12/30 13:46:12 3104C28C c   (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
    2018/12/30 13:46:12 3104C28C c   (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1802 PROVID 000000 ECMPID 1016 ANY CHID PMTPID 0000 VPID 01F5
    2018/12/30 13:46:13 3104C28C c      (ecm) local (1802@000000/0000/03E9/92:53F0B440FB62210C2CB83EA495D26938): not found (205 ms) by gigi - TVR 1
    2018/12/30 13:46:13 3104C28C c   (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
    2018/12/30 13:46:13 3104C28C c   (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1802 PROVID 000000 ECMPID 1016 ANY CHID PMTPID 0000 VPID 01F5
    Asa apare dupa ce am scos caid si indent de la userul dvbapi
    Daca mut pe tv1000 apar alte balarii.
    Nu dau copy paste, problema a aparut dupa ce am adaugat inca un pachet la card.
    Abia am reusit sa il actualizez fara conserva originala
    none
    01 Jan 1999
    acasa
    10 Post(s)
    pune aici oscam.config, oscam.reader (strictul necesar) si oscam.user (idem)... fara parole..
    bafta
    18 Nov 2018
    oscam.conf
    [global]logfile                       = stdout
    nice                          = -1
    maxlogsize                    = 0
    [cache]
    [newcamd]
    port                          = XXXX@1802:000000,002111
    key                           = 0102030405060708091011121314
    keepalive                     = 1
    [cccam]
    port                          = XXXX
    nodeid                        = A1B2C3D4E5F61122
    version                       = 2.1.3
    reshare                       = 2
    forward_origin_card           = 1
    stealth                       = 1
    updateinterval                = 180
    [streamrelay]
    stream_relay_enabled          = 0
    [dvbapi]
    enabled                       = 1
    au                            = 1
    pmt_mode                      = 0
    user                          = local
    boxtype                       = dreambox
    [webif]
    httpport                      = XXXX
    httppollrefresh               = 3
    oscam.server
    [reader]label                         = gigi
    protocol                      = internal
    device                        = /dev/sci0
    services                      = gigi
    caid                          = 1802
    boxkey                        = XXXX...XXXX
    rsakey                        = XXXX...XXXX
    ecmwhitelist                  = 92
    ecmheaderwhitelist            = 80308F078D,81308F078D
    detect                        = cd
    nagra_read                    = 1
    cardmhz                       = 3150
    ident                         = 1802:000000,002011,002111
    group                         = 1
    emmcache                      = 1,3,2,0
    cccreshare                    = 2
    ccchop                        = 1
    oscam.user
    [account]user                          = local
    monlevel                      = 2
    au                            = 1
    group                         = 1
    services                      = gigi
    cacheex_block_fakecws         = 1
    [account]
    user                          = XXXX
    pwd                           = XXXX
    caid                          = 1802
    group                         = 1
    services                      = gigi
    cccreshare                    = 2
    Daca mai e nevoie de ceva sa imi spuneti, am disperat boncaind in el
    Testele sunt pe 2xDM500s originale si un cloud ibox 2 plus (o clona cat de cat reusita)
    7 Post(s)
    Scoate services ala de la reader si userul local,
    Intra in config si bifeaza la webif
    http save full config
    apoi pune userul local si readerul aici.
    Vad ca nu apare la tine
    mhz                           =
    Pune
    mhz                           = 450
    cardmhz                       = 2700
    Experienta este cel mai dur profesor, pentru ca intai iti da testul si apoi iti spune care era lectia. - Vernon Law
    18 Nov 2018
    oscam.server
    description                   =
    enable                        = 1
    protocol                      = internal
    device                        = /dev/sci0
    key                           =
    password                      =
    pincode                       = none
    gbox_max_distance             = 2
    gbox_max_ecm_send             = 3
    gbox_reshare                  = 2
    cccam_reshare                 = 2
    readnano                      =
    services                      =
    lb_whitelist_services         =
    reconnectdelay                = 60000
    resetcycle                    = 0
    keepalive                     = 0
    smargopatch                   = 0
    autospeed                     = 0
    sc8in1_dtrrts_patch           = 0
    fallback                      = 0
    fallback_percaid              =
    localcards                    =
    disablecrccws_only_for        =
    cacheex                       = 0
    cacheex_maxhop                = 0
    cacheex_ecm_filter            =
    cacheex_allow_request         = 0
    cacheex_drop_csp              = 0
    cacheex_allow_filter          = 1
    cacheex_block_fakecws         = 0
    caid                          = 1802
    atr                           =
    boxid                         =
    boxkey                        = xxxxxxxxxx
    rsakey                        = xxxxxxxxxx
    deskey                        =
    ins7e                         =
    ins7e11                       =
    ins2e06                       =
    fix07                         = 1
    fix9993                       = 0
    readtiers                     = 1
    force_irdeto                  = 0
    needsemmfirst                 = 0
    ecmnotfoundlimit              = 0
    ecmwhitelist                  = 92
    detect                        = cd
    nagra_read                    = 1
    detect_seca_nagra_tunneled_card= 1
    mhz                           = 450
    cardmhz                       = 2700
    chid                          =
    class                         =
    aeskeys                       =
    group                         = 1
    emmcache                      = 1,3,2,0
    blockemm-unknown              = 0
    blockemm-u                    = 0
    blockemm-s                    = 0
    blockemm-g                    = 0
    saveemm-unknown               = 0
    saveemm-u                     = 0
    saveemm-s                     = 0
    saveemm-g                     = 0
    blockemm-bylen                =
    lb_weight                     = 100
    lb_force_fallback             = 0
    savenano                      =
    blocknano                     =
    dropbadcws                    = 0
    disablecrccws                 = 0
    use_gpio                      = 0
    cccreshare                    = 2
    ccchop                        = 1
    use_ssl                       = 0
    force_ua                      =
    exec_cmd_file                 =
    stmkeys                       =
    emu_auproviders               =
    extee36                       =
    extee56                       =
    dre36_force_group             =
    dre56_force_group             =
    deprecated                    = 0
    audisabled                    = 0
    auprovid                      =
    ndsversion                    = 0
    ratelimitecm                  = 0
    ecmunique                     = 0
    ratelimittime                 = 0
    srvidholdtime                 = 0
    cooldown                      = 0,0
    read_old_classes              = 1
    oscam.user
    [account]user                          = local <- AU USER
    monlevel                      = 2
    au                            = 1
    group                         = 1
    services                      = gigi
    [account]
    user                          = cccam-user
    pwd                           = xxxxxxxxxx
    caid                          = 1802
    au                            = 1
    group                         = 1
    services                      = gigi
    Gata si modificarile.
    01 Jun 2009
    pentru 500s , simply the best :
    oscam server
    [reader]
    label = Digi
    protocol = internal
    device = /dev/sci0
    detect = cd
    mhz = 525
    cardmhz = 3150
    caid = 1802
    boxkey =
    rsakey =
    group = 1
    emmcache = 1,3,2
    oscam conf
    [global]
    logfile = /var/log/oscam.log
    nice = -1
    maxlogsize = 50
    preferlocalcards = 1
    [newcamd]
    port = 14000@1802:000000, 002011, 002111
    [webif]
    httpport = 80
    httpuser = root
    httppwd = gheorghe
    httprefresh = 20
    httpallowed = 127.0.0.1,192.168.0.2-192.168.0.2
    oscam user
    [account]
    user = dvbapi
    au = 1
    group = 1
    preferlocalcards = 2
    cacheex_allow_filter = 0
    18 Nov 2018
    Acelasi lucru e si la mine.
    Mii de multumiri lui @lao, a aruncat el o privire
    Cardul pare actualizat doar pe pchetul extra1 si atat, baza canci
    Revin cu detalii dupa ce mai fac ceva sapaturi sa ma dumiresc care e baiul
    none
    01 Jan 1999
    acasa
    10 Post(s)
    offtopic:
    am mutat "discutiile" la: http://sateliti.info/showthread.php/...e-supara-frate!
    exact acolo se incadreaza...
    La multi ani!
    bafta
    Standard RSP member piccolo08's Avatar
    02 Sep 2010
    Earth
    Nu mai poostati configuri de habarnisti cu carduri care nu intereseaza discutia.
    Simplu si la obiect :
    1 card
    1 reader
    1 user
    1 prioritatea pe card ( global config)
    1 dvb-api gol
    1 services gol
    1 tiers gol
    1 log de init
    Nu ne intereseaza nici o alta sectiune in caz eceptional doar daca avem enable la userul default pe dvb-api/newcamd
    Invit expertii sa faca lumina.
    Un 2019 mai bun!
    02 Sep 2010
    Earth
    Pune
    mhz                           = 450
    cardmhz                       = 2700
    Cred ca e destul valoarea de 2700, nu-i asa ?
    "Smargo-Reader und interne Reader der Dreamboxen werden durch den ATR automatisch eingestellt, wenn autospeed = 1 (siehe nächsten Parameter) gesetzt ist."
    18 Nov 2018
    Quote Originally Posted by piccolo08 View Post
    1 card
    1 reader
    1 user
    1 dvb-api gol
    1 services gol
    1 tiers gol
    1 log de init
    Un 2019 mai bun!
    La multi ani in primul rand
    La cat esti de expert de ce nu oferi un raspuns la problemele expuse de noi aici?
    Discutam de cardul digi 1802, nu vad de unde atata sarcazm din partea ta.
    02 Sep 2010
    Earth
    Nu e sarcasm. E realitate. Fotbal joaca doar 11 dar un stadion intreg se pricepe mai bine.
    Eu doar joc , nu ma pricep.
    Inviato dal mio TA-1012 utilizzando Tapatalk
    ---------- Post added at 16:50 ---------- Previous post was at 16:48 ----------
    Configurati bine la nivel de soft, daca e nevoie rescrieti imaginea. Daca nu merge probati si pe alt aparat sau daca aveti cunostinte minime de electronica faceti masuratorile de tensiune pe cip.
    18 Nov 2018
    Nu am jucat fotbal in viata mea, am cerut ajutor colegilor de aici si ofer cu plcere daca stiu.
    Nu se naste nimeni cu oscam-ul in brate, totul se invata pe parcurs cu putin ajutor.
    18 Nov 2018
    Putin ajutor daca se poate, pe mine ma terorizat, nu pot sa inteleg de ce nu actualizeaza total cardul jiji
    Din cate se poate vedea AU lucreaza ok, parerea mea
    Si aici si ceea ce a actualizat
    Eu unu nu mai stiu ce sa ii mai fac, cred ca cedez si renunt total la abonament.
    Dar ce se întâmplă mai exact? In log live ce spune cere de pe alte carduri , de pe net și nu ia localul?
    ---------- Post added at 21:47 ---------- Previous post was at 21:41 ----------
    Acum văd că ai o versiune de oscam care nu are live log în meniu.
    Pune altă versiune de oscam
    LA TOTI N'I GREU
