Thanks Thanks:  3
Likes Likes:  4
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Thread: Ncam
    Standard RSP member lukas26's Avatar
    24 Mar 2009
    romania
    7 Post(s)
    NCam 7.6-r0 Emu -r781 -
    - [add] PowerVu hash mode 27
    - [fix] Small optimizations and improvements
    DOWNLOAD:
    http://oscam.dreamosat.net/index.php...=1.20_NCAM-EMU
    24 Mar 2009
    romania
    7 Post(s)
    NCAM 7.6
    for DM900, DM920, DM520,DM525, DM820, DM7080 (DEB)
    OOZOON, DREAM ELITE, NEWNIGMA2, GEMINI, Merlin5
    http://www.vuplus4k.com/plugins/ncam...ox_V7.6-r0.deb
    NCAM 7.6
    for vuplus zero, uno, solo2, ZERO 4K/ solo 4k/ultimo 4k/uno 4k, mutant hd51/52, AX 51/52, Xtrend ET11000/120000, Spycat 4K, Edision 4k, Octagon 4k​, DM900, DM920 (IPK)
    OpenATV, BlackHole, OpenBH, OpenLD, OpenPLi, OpenHDF, OpenVix, VTI, SatDreamGr, OpenDroid…
    http://www.vuplus4k.com/plugins/ncam...7.6-r0_all.ipk
    24 Mar 2009
    romania
    7 Post(s)
    NCam 7.7-r0 Emu -r782 -
    - [irdeto] Fixed cw checksum bytes
    - [dvbapi + streamserver] Rework audio identification for extended cw
    - (Removed some stream types from the audio list and added some that were missing. Hopefully this change will fix the rest of the powervu channels that have audio problems. If there are still channels with no audio, please report)
    download:
    43 Post(s)
    Nu prea vad scopul acestei avalanse de actualizari interminabile la NCAM. Eu am testat destul de mult ncam 7.1, acum sunt pe 7.3 si probabil raman aici multa vreme. Tot ce spun ei despre imbunatatiri sunt vorbe goale. Dar imi place NCAM, frate mai mic cu OSCAM! Testat doar pe DM920, diverse imagini. Nu stiu performantele pe alte stb-uri.
    24 Mar 2009
    romania
    7 Post(s)
    ncam-arm-7.7 all.ipk for: BH-OBH-ORIG-OpenAtv-OpenPli-Vti
    https://www.mediafire.com/file/87wth...l.ipk.rar/file
    ncam-mips-7.7 all.ipk for: BH-OBH-ORIG-OpenAtv-OpenPli-Vti
    https://www.mediafire.com/file/ikq7e...l.ipk.rar/file
    24 Mar 2009
    romania
    7 Post(s)
    Ncam 11.8 compiled and patched by marouan & RAED
    -update URL (25.02.2021)”
    -Fixed SoftCam.Key (url) cut file name”
    -fixind srvid on Radegast Module by Adding srvid because ECM contains0000″
    -webif-cacheex-client.reader-description-fix v1″
    (add else conditions)”
    -[biss] Changed tsid-onid combo validation”
    -[gbx] – add dynamic card update/exchange”
    * rearrange hello scheme
    * add peer specific ccc reshare ident filter
    * fix major bug in send hello msg
    * correct checkcode calculation
    * change some default settings
    * add optional send msg Here? to selected peers”
    -Fix need pin for 0961″
    (reader) 0961_sky [videoguard2] classD3 ins54: no cw –> Card needs pin)”
    -[dvbapi] Updated extension descriptor tags”
    (In accordance with ETSI EN 300 468 V1.16.1, table 109.)”
    -[powervu] Added some missing hash modes”
    -[streamserver] Synced extension descriptor tags with the dvbapi code”
    DEB & IPK
    Download:
    https://gofile.io/d/2vpyt8
    24 Mar 2009
    romania
    7 Post(s)
    Ncam 11.9 compiled and patched by marouan & RAED
    -Fix compile error (undefined-reference-to-‘_binary_SoftCam_Key_start’)
    -powervu sharing is blocked (Not Services)
    (Add this reader into the ncam.services file)
    *My Config files updated already (no need to add it again)
    *After this fix should be Ncam read powervu and update keys direct from softcam,key no need to read it from (ncam.fs or CCcam.cfg). So more fast to update keys
    [emulator]
    caid = 0E00
    provid =
    srvid =
    -dvbapi FBC Tuner fix (oscam@11691)
    .ipk
    https://file1.gofile.io/download/40946897-66f2-4501-9d5a-f022a4d8db5a/enigma2-plugin-softcams-ncam_V11.9-r0_all.ipk
    NCam-5.3-r2 (Official)
    Changelog v5.3-r2:
    - Fixed warning messages with GCC 11.x.x
    - Whitespaces cleaned.
    - Fixed Newcamd/CCcam buffer overflow.
    - Fixed Videoguard2.
    - Fixed DVBAPI FBC Tuner.
    - Fixed broken socket.
    - Refactoring the code and more.
    https://www.mediafire.com/file/f5vtu....3-r2.rar/file
    24 Mar 2009
    romania
    7 Post(s)
    enigma2-plugin-softcams-ncam_V11.9-r3_all.deb
    https://www.mediafire.com/file/zcpt4...l.deb.rar/file
    24 Mar 2009
    romania
    7 Post(s)
    Ncam 12.0
    -Update some Free servers url
    -Camd35 src-data is frees
    -fix webif aio proto
    -[gbx] - enhance 'ignore peer' feature
    -*thx to @chimpie232 for providing the patch
    *improve ccc reshare
    *code cosmetic
    -[nagra] Tivusat Silver Rainbow - Show Entitlements thx opti
    ipk
    https://www.mediafire.com/file/g1bhn...0_all.ipk/file
    deb
    https://www.mediafire.com/file/38d5r....0-r0.deb/file
    24 Mar 2009
    romania
    7 Post(s)
    24 Mar 2009
    romania
    7 Post(s)
    Ncam V12.2
    -Add libcurl4 to ncam compile
    -Upgrade curl version to 7.79.1
    ipk
    http://www.mediafire.com/file/ke0f3n...S-IPK.zip/file
    deb
    http://www.mediafire.com/file/gao9in...x-DEB.zip/file
    24 Mar 2009
    romania
    7 Post(s)
    Ncam v.12.2
    -Added bin files that were missing in ipk and deb file....
    ipk
    https://www.mediafire.com/file/cgr1o...PK(2).zip/file
    deb
    https://www.mediafire.com/file/q9c9n...EB(2).zip/file
    24 Mar 2009
    romania
    7 Post(s)
    Ncam v.12.2 r1
    Solved and update files again ..
    deb
    24 Mar 2009
    romania
    7 Post(s)
    NCam_V12.2-r2
    Solved and update deb files again ..
    ipk
    24 Mar 2009
    romania
    7 Post(s)
