Results 61 to 75 of 76
Thread: Ncam
  1. #61
    Ncam V13.4
    -Added new ATR (Refresh some Prov. Info)
    -Fixes (hopefully) the problems of v7. And there is a switch in the configuration menu to turn off ARM NEON support (can remain switched on for Mipsel/PC/...)
    P.s: No more bin for openssl1.1 (all bin files will be works on all image openssl old/new)
    Download link
    Ncam-Images-IPK (For All devices that use ipk system)
    NCam-Images-OSDreambox-DEB (For all Dreambox with DreamOS images that use dpkg system Such as (original image, Merlin4, Gp4, Dream-Elit ..etc))
    Here are Only Bin file ..
    mips (Gigablue-Dream-VU+-Xtrend-Formuler)
    sh4 & SPARK (Golden Media-Galaxy innovations-Amiko)
    sh4-stapi (xcruiser 400plus, Forever 7878, 7474, 7420, 7830 8200, 9510)
    sh4-stapi5 (Cardiff/Avant) (Forever[9898, 3434, Nano Smart])
    sh4-stapi5_V03 (Cardiff/Avant)
    cortexa9hf-vfp-neon-ARM (DreamoxUHD + VU+4K + osmio4k + Routers Mipsel DD-WRT + RaspberryPI Hardware FPU)
    aarch64-ARM (VU+4K Duo4K + DreamOne/Two/7)
    x86-Linux-pc (32bit-i686)
    x86-Linux-pc (64bit)
    mips (Tiviar plus and similar)
    ncam.gx-csky (uClan (U2C) Denys H.265, Octagon SX88, SX88+, SX88+ Optima, SX88+ Combo, ASAT HDR No.1)
    arm-marvell (Synology DS114, DS214 and similar)
    arm-Coreelec (Mecool KIII Pro , Magicsee N5 Max and similar)
    ************** Bin files for Android Devices Only **************
    Amiko A3 (4.4_KitKat)
    Amiko A4 (5.1_Lollipop)
    Amiko A5 (7.0_Nougat)
    WeTekPlay2 WeOS-v2 (5.0-Lollipop)
    WeTekPlay2 WeOS-v3 (6.0-Marshmallow)
    ----- Android stapi -----
    4.4-KitKat-Androideabi19-stapi
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    6.0-Marshmallow-stapi
    Icone-Iron-stapi
    ************** Ncam with libusb-pcsc **************
    cortexa9hf-vfp-neon-ARM-libusb-pcsc (DreamoxUHD + VU+4K + Routers Mipsel DD-WRT + RaspberryPI Hardware FPU)
    ************** Ncam For Windows **************
    Windows 64Bit
    Windows 32Bit
    **************** config Files **************
    Config File For All devices OE2.0
    Config File For DreamOS OE2.5
    Config File For SH4 Only
    Config File For SH4-Stapi Only (Mod BY sheypooor)
    Config File For Android Only
    Config File For Android-Stapi Only (Mod By samur)
    Config File For Windows
  2. #62
    NCam 6.4-r4 (oficial)
    Changelog v6.4-r4:
    - Add support iCam (Thanks to the creator @icb of the ICAM v8 patch).
    - Add new KScamd protocol (still in development).
    - Fixes for Stream Relay.
    - Fixes for Radegast protocol and icam.
    - Fixes for Viaccess and VideoGuard.
    - Optimized for lower RAM and CPU consumption.
    - Fixed issue preventing ICAM from starting
    - Fixed issue that forced KScamd to have newcamd line active.
    - Fixed the problem that modified the protocols used by users when accessing them via webif.
    OFFICIAL version
    NCam cardserver v6.4-r4, ( MIPS, PPC, X86, X86_64, SH4, ARM, EXE )
    Copyright (C) 2012 - 2022 developed by Javier Sayago (Javilonas).
    Source Code: https://github.com/javilonas/NCam
    Mirror Source Code: https://github.com/ncam-project/NCam
    Compiled:
    ncam.mips Enigma2 - Mipsel (Gigablue, Dream, Vu+, Xtrend, Formuler...).
    ncam.mips-openpli_40 Enigma2 - Mipsel (Openpli 4.0 'Gigablue, Dream, Vu+, Xtrend, Formuler'...).
    ncam.mips-uclibc Enigma2/Others - Mipsel (Tiviar Plus 'firmware no enigma2', and similar).
    ncam.x86 Linux PC (32 bit - i686).
    ncam.x86_64 Linux PC (64 bit).
    ncam.x86_64-syn_atom Linux x86_64 (For Synology ATOM 64 bit).
    ncam.ppc Enigma1 - (Power PC - DM600, 7000, 7020, 7020si...).
    ncam.ppc-old Enigma1 - (Power PC OLD - DM500, 500S, DBox2...).
    ncam.sh4 Enigma2/Spark sh4 - (Golden Media, Galaxy Innovations, Amiko...).
    ncam.cortexa9hf-vfp-neon Enigma2/Others - ARM (Cortex-A9 - Wetek, Vu+4K, Octagon 4k and similar).
    ncam.cortexa15hf-vfp-neon Enigma2/Others - ARM (Cortex-A15 - Gigablue UHD, Vu+4K, Octagon 4k and similar).
    ncam.vuplus4k_arm Enigma2 - ARM (Vu+ Zero|Uno|Duo|Solo|Ultimo 4K and similar).
    ncam.james_donkey_arm Enigma2 - ARM (James Donkey DUO and similar).
    ncam.arm-aarch64-dreambox Enigma2 - ARM (Dreambox ONE|TWO).
    ncam.arm-dreambox Enigma2 - ARM (Dreambox DM9x0 UHD).
    ncam.arm-raspbian ARM (Raspberry pi 3, Prismcube, TInkerboard and other similar).
    ncam.arm-android ARM (For Android ARM (API 24+)).
    ncam.arm-marvell ARM (Synology Armada 375 and similar).
    ncam.arm-armada37xx ARM (Synology Synology Armada 37xx and aarch64 similar).
    ncam.arm-mca ARM (For Matrix CAM Air).
    ncam.arm-samsungtv ARM (For Samsung TV).
    ncam-router.mips Mips (Routers MIPSEL DD-WRT).
    ncam.router-openwrt-brcm47xx.mips Mips (Routers openwrt brcm47xx).
    ncam.router-openwrt-ar71xx.mips Mips (Routers openwrt ar71xx).
    ncam.router-openwrt-brcm63xx.mips Mips (Routers openwrt brcm63xx).
    ncam.router-openwrt-huawei-hg556a.mips Mips (Routers openwrt Huawei HQ556a).
    ncam-x86_64-pc.exe Windows PC (64-bit) (You Need DLL cygwin1.dll in C:\Windows\System32).
    ncam-i686-pc.exe Windows PC (32-bit) (You Need DLL cygwin1.dll in C:\Windows\System32).
    Ncam settings web:
    Ncam Admin Control: http://ip:8181/ (192.168.x.x or host-xx.org)
    user: root
    password: ldteam
    Important: [CCcam] Change (0-9 and A-F) NodeID (Important to respect all 16 characters).
    Change extended_cw_api in ncam.conf (Use 1 for ARM/PC (OE2.2), use 2 MPISEL/PPC (OE2.0)).
    Start ncam with: ncam -b
    Don't include -s (it's already set internally) or other unnecessary parameters or ncam will stop.
    Change in ncam.conf max_time, cw_cache_size and cw_cache_memory:
    max_time = 17 // The time that the ECMs are going to be ‎Keep in the cache‎.
    cw_cache_size = 2700 // CW cache count Max storage size (Affects the CPU (don't set a value too high)).
    cw_cache_memory = 5 // MBs max. memory used for CW cache size (Affects the RAM, don't set a value too high).
    ecm_cache_size = 2700// ECM cache count Max storage size (Affects the CPU (don't set a value too high)).
    ecm_cache_memory = 5// MBs max. memory used for ECM cache size (Affects the RAM, don't set a value too high).
    Config: /var/tuxbox/config
    SoftCam.Key: /var/tuxbox/config
    In order for the ICAM system to work without problems, modify the settings of your enigma2 image like this.
    in the Enigma settings/extras (ATV/OPENLD/OTHERS: MENU/SETTINGS/OPERATION & INTERFACE/ system settings):
    Set Integrate ECM in HTTP streams to YES
    Decrypt HTTP Streams YES
    Decrypt received HTTP streams NO
    SoftCam.Key Not included!!
    The emulator is inactive by default.
    One very important thing to note, official NCam does not work the same as unofficial versions and the settings are not the same.
    Legal warning
    NCam does not emulate by default any payment signal/platform without its corresponding suscription.
    You, as an end user, will be responsible for the use that you will make and neither I (Javier Sayago),
    nor
    Download:
    https://www.mediafire.com/file/1cbgd....4-r4.rar/file
  3. #63
    Ncam V13.5
    -Add Patch V9 for iCam's
    - Adjustment for CMake
    - Compiler parameter -fno-schedule-insns added. (Thanks @@Hacker1 )
    - Removed compiler parameter -fno-tree-vectorize. The binary runs about 10% faster with neon (thanks @@eldi0s )
    - Small change in ffdesca, which is slightly faster.
    Download link
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    Icone-Iron-stapi
    Windows 64Bit
    Windows 32Bit
  4. #64
    NCam 6.5-r0 (oficial)
    Changelog v6.5-r0:
    - Improvement for higher performance.
    OFFICIAL version
    NCam cardserver v6.5-r0, ( MIPS, PPC, X86, X86_64, SH4, ARM, EXE )
    Compiled:
    Ncam settings web:
    user: root
    password: ldteam
    Changelog v6.5-r0:
    Legal warning
    nor are responsible for what third parties can do with official NCam.
    Download:
    https://www.mediafire.com/file/9a9r8....5-r0.rar/file
  5. #65
    NCam 6.6-r1 (oficial)
    Changelog v6.6-r1:
    - Fix bug that prevented ICam from working normally on some architectures.
    - Prevent ffdecsa from going through global optimization at compile time (Makes the system more stable).
    - Added new build for Armada 38x.
    OFFICIAL version
    NCam cardserver v6.6-r1, ( MIPS, PPC, X86, X86_64, SH4, ARM, EXE )
    Compiled:
    ncam.arm-armada37xx ARM (Synology Armada 37xx and aarch64 similar).
    ncam.arm-armada38x ARM (Armada 38x and similar).
    Ncam settings web:
    user: root
    password: ldteam
    Changelog v6.6-r1:
    Legal warning
    Download:
    https://www.mediafire.com/file/ne38m....6-r1.rar/file
  6. #66
    NCam 6.8-r1 (oficial)
    Changelog 6.8-r1:
    - Fixed connection problem with certain IP ranges by Scam protocol
    Download:
    https://www.mediafire.com/file/5g47g....8-r1.rar/file
  7. #67
    Ncam V13.6
    - android-stapi: warning in debug dvbapi
    - Compile Ncam without softcam.key built in
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    Icone-Iron-stapi
    Windows 64Bit
    Windows 32Bit
  8. #68
    Ncam V13.7
    - Fix some codes for CCcam (version and stealth)
    Ncam
    EMU
    Download link
    cortexa9hf-vfp-neon-ARM (DreamoxUHD + VU+4K + Osmio4k + Routers Mipsel DD-WRT + RaspberryPI Hardware FPU)
    x86-Linux-pc (64bit
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    Icone-Iron-stapi
    Windows 64Bit
    Windows 32Bit
    Config File For Android-Stapi Only (Mod BY samur)
  9. #69
    Ncam V13.8
    -Fixing Mapping LOG thanks to Qu4k3 Nagra fix thanks to @w33dburner
    -T3VV fix thanks to ohmza
    -Added T3VV ATR thanks to ohmza
    -Add ATRs for NDS 0927 and 09BF card thanks to @sambas1980
    -Fixing emmcache save to (EMM log dir thanks to @hapeba
    -Fix macOS Monterey compile issues thanks to ohmza
    -unnecessary spaces deleted
    -update ffdecsa neon
    x86-Linux-pc (64bit
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    Icone-Iron-stapi
    Windows 64Bit
    Windows 32Bit
  10. #70
    Ncam V13.9
    - libcurl4 has been deprecated from work ncam
    - FFdecsa reloaded. Depend on (Hope an iCam now more stable more fast)
    - FFdecsa Depend on
    x86-Linux-pc (64bit
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    Icone-Iron-stapi
    Windows 64Bit
    Windows 32Bit
  11. #71
    Ncam V14.0
    - Retuen back again with libcurl4 (impoetant to download powervu keys keys and softcam.keys files)
    x86-Linux-pc (64bit
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    Icone-Iron-stapi
    Windows 64Bit
    Windows 32Bit
  12. #72
    Ncam V14.1
    - More improvment iCam service
    - Added avx2 and avx512, for those who want to experiment
    x86-Linux-pc (64bit
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    Icone-Iron-stapi
    Windows 64Bit
  13. #73
    Ncam V14.2
    x86-Linux-pc (64bit
    5.1-Lollipop-stapi
    7.0-Nougat-stapi
    5.0-Lollipop-stapi
    Icone-Iron-stapi
    Windows 64Bit
  15. #75
    Ncam_Emu-10749_Icone-Iron_Sisyphe
    https://www.mediafire.com/file/83tz8...11.15.zip/file
