Functioneaza si cu Oscam de ceva vreme, dar numai o ora dupa care trebuie iarasi AU
ncam_V12.7-r0
ipk
http://www.mediafire.com/file/ke0f3n...S-IPK.zip/file
deb
http://www.mediafire.com/file/gao9in...x-DEB.zip/file
sh4
http://www.mediafire.com/file/j8oydm...m.sh4.zip/file
linux 32bit
http://www.mediafire.com/file/qs6hjr...m.x86.zip/file
linux 64bit
http://www.mediafire.com/file/9fhw0p...86_64.zip/file
Config File For DreamOS OE2.5
https://www.mediafire.com/file/rkpy8...-2020.zip/file
Config File For All devices OE2.0
http://www.mediafire.com/file/ka8126...Files.zip/file
Config File For SH4
http://www.mediafire.com/file/jepw0e...s_SH4.zip/file
ncam_V12.8-r0
-Change web log (Thank you oktus)
-Fix linuxsat-support.com page number
-Fix some bugs on Android devices
ipk
deb
sh4
linux 32bit
linux 64bit
Ncam V12.9
-Update web logo independently of github and network
-more improvement for linuxsat-support keys
ipk
deb
sh4
linux 32bit
linux 64bit
Ncam V13.0
-updated cmake curl
-Show curl in ncam.version
-Some improvement for Android devices
-If CCcam.cfg is disabled, it cannot be edited on the web interface
ipk
deb
sh4
http://www.mediafire.com/file/j8oydm...v/ncam.sh4.zip
Amiko A3
https://www.mediafire.com/file/5m1qf...itKat.zip/file
Amiko A4
https://www.mediafire.com/file/l2sc1...lipop.zip/file
Amiko A5
https://www.mediafire.com/file/xeicu...ougat.zip/file
linux x32
http://www.mediafire.com/file/qs6hjr...a/ncam.x86.zip
linux x64
Ncam V13.1
-Correction for ICAM ECMs for NDS
-EMM Support for Suisse V7 Card
-Fix for Viaccess EMM Update < V7 broken
-Add support iCam Thank you (icb) author of patch
ipk
deb
sh4
mips
http://www.mediafire.com/file/9t58bz.../ncam.mips.zip
amiko a3
a4
a5
arm-Coreelec (Mecool KIII Pro , Magicsee N5 Max and similar
http://www.mediafire.com/file/ynvt4d...ssl11.zip/file
ubuntu x86
x64
sky de Ncam 13.1 in the ncam.conf files
1 [streamrelay]
2 stream_ecm_delay = 5
3 stream_emm_enabled = 1
4 stream_relay_ctab = 098D
Ncam config file for Ncam 13.1
https://www.mediafire.com/file/5qay5...onfig.rar/file
and a very important setting as in the picture
- Include ECM in http streams - MUST BE ON
I use ciefp settings list
https://www.sateliti.info/showthread...000#post283000
Ncam V13.2
-Some fixes
-iCam work with (DVBAPI and Radegast)
image settings for open source image
Radegast:
1 Set Integrate ECM in HTTP streams to YES
2 Decrypt HTTP Streams NO
3 Decrypt received HTTP streams NO
DVBApi:
1 Set Integrate ECM in HTTP streams to NO
2 Decrypt HTTP Streams YES
ipk
deb
sh4
mips
amiko a3
a4
a5
linux x86
x64
V.13.2_r1
-changes in ncam.server & dvb files
ipk
deb
sh4
mips
amiko a3
a4
a5
linux x86
x64
L-am pus si eu dar am o problema de functionalitate:
Daca am in ncam.server
si dau in webif pe readere, crapa.####################### Icam ############################
[reader]
label = Icam
protocol = cccam
device =
user =
password =
inactivitytimeout = 30
group = 1
disablecrccws = 1
cccversion = 2.3.2
ccckeepalive = 1
audisabled = 1
Asa era in configul pachetului enigma2-plugin-softcams-ncam_V13.2-r0_all
Poate pune cineva un reader icam din ncam care ii functioneaza?
Merci
Config File For SH4 Only
Config File For Android Only
http://www.mediafire.com/file/45em2w...-2020.zip/file
Rezolvarea este stergerea readerului Icam din ncam.server si totul functioneaza, inclusiv icam.si dau in webif pe readere, crapa.
PS Cel putin la partea asta cu icam si radegast pentru nemti, merge mai fluent ca oscam cu icam.
Am (avut) ncam doar pentru uz propriu, până ce am văzut că am trafic pe un reader din care trag "din an în paște"
Mă uit în live log, nimic. Mă uit în statistica readerului și văd vreo 40-50 de sid-uri, toate ok, canale pe care nu mă uit.
Userul pe stb este doar cel dvbapi, deci n-are altcineva ce să ceară.
Intru pe serverul din care trăgeam, și ce să vezi, acolo era activitate, îmi arata tot ce ceream din ncam (cam 3 ecm/10sec, deci ca și 3 useri care se uita pe câte un canal)
Așa că înapoi la oscamul pe care mi l-am compilat după necesități.
Cred că aceste softuri, dacă nu au sursa disponibilă, trebuie tratate cu atenție.
Pentru cine dorește să verifice, să dezactiveze toți userii și să urmărească statisticile readerelor.
Ncam V13.3
-NEON is now used for ARM CPUs. These are special parts of the CPU that can execute certain code faster. This helps with decryption. From my point of view, the load on my sf8008 drops a bit. If you want to compare it, then always with the same station and preferably the same show. The load varies greatly from transmitter to transmitter. This means that 128 packets are decrypted at the same time and not 32 as before.
As far as I've read, Mipsel Broadcom boxes don't have this type of processing. With Mipsel I wouldn't use Radegast (if possible) and I wouldn't even compile it at all
- When zapping to a station with a pause, you don't have to wait for the 30 second timeout before the tuner is released again
- Optimization mostly for MIPS boxes
ipk
https://www.mediafire.com/file/6cwhf...0_all.ipk/file
deb
https://www.mediafire.com/file/dj1wq....3-r0.deb/file
sh4
mips
amiko a3
a4
a5
linux x86
x64
