Results 1 to 15 of 76
Thread: Ncam
    24 Mar 2009
    Thumbs up Ncam
    Ncam V 6.4 compiled and patched by marouan & RAED
    -Fix ecm unmasking issue
    -Fix for tiers with rights set to 0x49xx
    -Revert To [nagra] T1 Resync command error, trying to reactivate!
    NCAM 6.4
    for DM900, DM920, DM520,DM525, DM820, DM7080 (DEB)
    OOZOON, DREAM ELITE, NEWNIGMA2, GEMINI, Merlin5
    download
    http://www.vuplus4k.com/plugins/ncam...ox_V6.4-r0.deb
    NCAM 6.4
    for vuplus zero, uno, solo2, ZERO 4K/ solo 4k/ultimo 4k/uno 4k, mutant hd51/52, AX 51/52, Xtrend ET11000/120000, Spycat 4K, Edision 4k, Octagon 4k​, DM900, DM920
    OpenATV, BlackHole, OpenBH, OpenLD, OpenPLi, OpenHDF, OpenVix, VTI, SatDreamGr, OpenDroid…
    download
    http://www.vuplus4k.com/plugins/ncam...6.4-r0_all.ipk
    24 Mar 2009
    NCam 6.5-r0 Emu -r774 -
    - Fix ecm unmasking issue
    - Fix for tiers with rights set to 0x49xx
    - Revert To [nagra] T1 Resync command error, trying to reactivate!
    download
    http://oscam.dreamosat.net/index.php...=1.20_NCAM-EMU
    24 Mar 2009
    NCam 6.7-r0 Emu -r774 -
    -Don't allow BISS ecm requests with a length shorter than 3 (NCam sends a fake ecm request for BISS with a length of at least 5 anyway. Also make some small optimizations and cosmetic changes)
    -Remove redundant ecm length checks
    -Use the typedef struct types instead (cosmetic)
    -Forbid parallel access to the key db and key file (This should fix
    the rare crash at NCam startup when two or more Emu readers are configured. If the issue remains, please report back!)
    -Fix CW checksums
    download
    24 Mar 2009
    NCam 6.8-r0 Emu -r775 -
    - Add PowerVu hash mode 19 and 20
    download
    http://oscam.dreamosat.net/index.php?&direction=1&order=nom&directory=1.20_NCAM-EMU
    NCAM 6.8
    download
    http://www.vuplus4k.com/plugins/ncam...6.8-r0_all.ipk
    24 Mar 2009
    NCam 6.9-r0 Emu -r776 -
    - Increase usuable EMM keys per group id to 32
    - Forbid parallel access to the key db even more
    download
    24 Mar 2009
    Post
    NCam 7.0-r0 Emu -r776 -
    - Add basic support for BISS 2 ""(This is just a small set of changes that allow BISS 2 ecm and emm detection. Nothing more at the moment!)""
    download
    download
    http://www.vuplus4k.com/plugins/ncam/Ncam%207.0/enigma2-plugin-softcams-ncam-osdreambox_V7.0-r0.deb
    download
    http://www.vuplus4k.com/plugins/ncam...7.0-r0_all.ipk
    17 Jul 2008
    In Tara
    ncam e mai slab ca oscam.
    cu aceeasi linia slaba ncam nu merge ..cere ca nebunu fara sa deschida.
    iar oscam merge.
    alte diferente eu nu am vazut.
    24 Mar 2009
    NCam 7.4-r0 Emu -r780 -
    - Cosmetics"
    - [powervu] Did some cleanup and added a couple debug messages"
    - [dvbapi] Allow the creation of descramblers for all stream pids "(This should fix some streams on powervu channels not working. It should have been fixed on oscam side, so let's hope they will add it.)"
    - [powervu] Added support for hash mode 26
    download:
    24 Mar 2009
    NCAM 7.4
    for vuplus zero, uno, solo2, ZERO 4K/ solo 4k/ultimo 4k/uno 4k, mutant hd51/52, AX 51/52, Xtrend ET11000/120000, Spycat 4K, Edision 4k, Octagon 4k​, DM900, DM920 (ipk)
    http://www.vuplus4k.com/plugins/ncam/Ncam%207.4/enigma2-plugin-softcams-ncam-mips_arm_V7.4-r0_all.ipk
    Imi place Ncam. Nu stiu cine l-a facut, la semnatura scrie Raed si Maruan, probabil arabi dar nu conteaza. Am inceput cu Ncam 7.1 si apoi 7.3 pe DreamElite si parca este mai prietenos decat Oscam, desi mari diferente eu nu gasesc. Atat Ncam cat si Oscam se blocheaza pe PVu atunci cand se iese de pe canalele discovery PVu de pe 5E si 1W si trebuie restartata E2, la PVu AFN de pe 9E nu este aceasta problema. Unii spun ca este un bug DM900/920 si nu ar fi de la emulatoare, eu nu sunt totusi convins si incerc sa gasesc ce este gresit la configuratiile mele. Deocamdata fara succes. Poate ma lumineaza cineva de ce atunci cand deschid canalele discovery PVu de pe 1W/5E si apoi trec pe altele este nevoie de restartare?
    24 Mar 2009
    NCam 7.5-r0 Emu -r780 -
    - [streamserver] Fixed typo in log message and did some code cosmetics
    download:
