Thanks Thanks:  9
Likes Likes:  8
Page 6 of 7 FirstFirst ... 234567 LastLast
Results 76 to 90 of 95
  1. #76
    17 Jan 2008
    Octagon SF8008 Zapping TDT Satellite Unicable OpenSPA
    1- Satellite and DTT channels Zapping, the Satellite takes a little longer to be visualized for the first time when using
    unicable LNB.
    "Cambio de canales TDT y Satélite, el Satélite tarda un poco mas en visualizarse por primera vez al usar LNB unicable."
    https://www.youtube.com/watch?v=HEVx...ature=youtu.be
    2- Other video on tuner satelite and tdt configuration as well as kodi and test TDT channels in hispasat 30W in Octagon sf8008.
    https://www.youtube.com/watch?v=Oov6...ature=youtu.be
  3. #78
    am reeditat cele doua adrese/filme de pe youtube
    zvon in legatura cu Octagon SF8008
    ----------Model with CI slot should be available after summer.------
  4. #79
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 21.03.2019
    1: Try HDR issue fix (please test)
    2: Update Hiplayer for Kodi fix video sync issue
    3: Try fix Kodi stutter issue (please test)
    4: Add more character for Frontpanel led (Display).
    5: Fixed crash when handle some pes packet.
    6: Remove CEC 0 NOT VALID! message on HDMI CEC driver.
    7: Fixed the screen blank for skip media when refresh rate set to "Auto" mode.
    8: Update: hi-dvb.ko, vtnerc.ko, hi_hdmicec.ko, oled.ko, libreader, stb-kodi-sf8008_17
    Ab morgen in den Images!
    From tomorrow in images!
    Yarinki imajlardan itibaren!
    OCTAGON GERMANY SUPPORT
  5. #80
    Thumbs up HAM RADIO & TV Test with OCTAGON SF8008 4K UHD eshail Sat 26°E
    german:
    Amateurfunk Test mit OCTAGON SF8008 4K UHD: Es’hail-2 @ 25.8° East - Badr-4/5/6/7 @ 26° East
    Hallo,
    Es`hail-2 ist ein geostationärer Satellit auf 26 Grad Ost der einen Transponder für die fast Weltweite Kommunikation von Funkamateure besitzt.
    Er wurde von Katar finanziert.
    Auf der Frequenz 10492, Symbolrate 2000, Fec 2/3, Modulation QPSK, Horizontal (18V), LNB Low, wird eine Dauerschleife(Bake) betrieben um diesen Transponder zu finden.
    Es ist ein umgebautes PLL LNB notwendig um diesen zu empfangen. Im LNB (nicht alle sind zu verwenden) wird der Quarz von 25MHz auf 24MHZ geändert. Damit verschiebt sich der LO auf 9360MHz.
    In der Tuner Konfiguration des SF8008 (Octagon) ist dieser Wert eizutragen.
    Auf der Internetseite HTTPS://eshail.bat.org.uk/wb/ wird die Aktivität auf dem Transponder als Spektrum dargestellt. Ohne dieses Spektrum ist es nicht möglich festzustellen, wann ein Funkamateur sendet.
    Der Octagon SF8008 ist in der Lage tiefe Symbolraten zu empfangen und zu decodieren. Nachweislich folgende Symbolraten empfangen: 00250, 00333, 00500 und darüber.
    Eine Schüssel von 1,2m ist Voraussetzung um die notwendigen Feldstärken zu erreichen.
    viel Spaß und viel Erfolg..
    english:
    HAM RADIO & TV Test with OCTAGON SF8008 4K UHD eshail Sat 26°E: Es’hail-2 @ 25.8° East - Badr-4/5/6/7 @ 26° East
    Hello,
    Es'hail-2 is a geostationary satellite at 26 degrees East that has a transponder for the almost worldwide communication of radio amateurs.
    He was funded by Qatar.
    On the frequency 10492, Symbol Rate 2000, Fec 2/3, Modulation QPSK, Horizontal (18V), LNB Low, a continuous loop (beacon) is operated to find this transponder.
    It is a converted PLL LNB necessary to receive this. In the LNB (not all are to be used) the quartz is changed from 25MHz to 24MHZ. This shifts the LO to 9360MHz.
    In the tuner configuration of the SF8008 (Octagon) this value has to be entered.
    On the website HTTPS://eshail.bat.org.uk/wb/ the activity on the transponder is displayed as a spectrum. Without this spectrum, it is not possible to determine when a radio amateur is transmitting.
    The Octagon SF8008 is capable of receiving and decoding low symbol rates. Proved to receive the following symbol rates: 00250, 00333, 00500 and above.
    A bowl of 1.2m is required to reach the necessary field strengths.
    Have fun and good luck..
    photos will posted soon.
    thanks to: @fethi sabri
  6. #81
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 01.04.2019
    - Multi Transcoding added.
    - HDMI Edid Decode added. (ATV 6.3)
    https://github.com/oe-alliance/oe-al...s/****-octagon
    t2mi test
    openatv-6.2-sf8008-20190401_mmc.zip
    https://wetransfer.com/downloads/8a5...1113151/04fc4a
  7. #82
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 02.04.2019
    - Fixed noise when playing 32bit PCM Audio
    - Sound problem fixed
    - [linux] 4.4.35 Add Hauppauge DualHD bulk models
  8. #83
    OCTAGON SF8008 4K UHD E2 Updates 07.04.2019
    - Scansetup fix BSOD remove old code (T2-MI)
    - T2MI Scan improved:
    - Normal + Blindscan
    - FileCommander Plugin Support
    - VFD Display Control: some fine tuning to adapt for sf8008
    ready in images!
  9. #84
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 08.04.2019
    - Sound problem from Stand-by fixed.
    - Standby looses audio fixed.
    FTP install:
    hi-dvb.ko --> /lib/modules/4.4.35/extra
    Telnet & Putty:
    a) killall -9 libreader
    b) libreader --> /usr/bin (ftp)
    c) Box neustarten (restart Box)
    Ab morgen Images.
    From tomorrow Images.
    Yarinki imajlardan itibaren.
  10. #85
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 11.04.2019
    - Media Playback Jump Button issue fixed.
    - TimeShift improved
    - PowerLED Control Update:
    - echo "on" > /proc/stb/fp/standbyled
    - echo "off" > /proc/stb/fp/standbyled
    - /proc/stb/fp/standbyled for RED
    - /proc/stb/fp/poweronled for BLUE
    - /proc/stb/fp/mixerled for PURPLE
    FTP install:
    hi-dvb.ko + vtunerc.ko --> /lib/modules/4.4.35/extra
    Telnet & Putty:
  11. #86
    Octagon Blindscan Plugin Update 14 04 2019:
    mit heute Images wie ATV, Openeight etc. wurde Plugin Blindscan neue Versiob veröffentlicht.
    Online Updates installieren reicht aus.
    with today images like ATV, Openeight etc. Plugin Blindscan new Version was released.
    Online updates are sufficient.
  12. #87
    OCTAGON SF8008 4K UHD E2 Updates 01.05.2019
    whats'new ;
    - RDS Info for Radio Ch. fix.
    - exteplayer3 fix.
    - webkithbbtv update
    - python-youtube-dl update
    - BlindScan fix BSOF for non legacy images
    Ab heute Images!
    From today Images!
    Bugünki Imajlardan itibaren!
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 05.05.2019
    What's New ;
    - AGC fix. for DVB-S/S2/S2X (for SF8008 SINGLE/TWIN/COMBO).
    FTP install:
    a.) hi-dvb.ko --> /lib/modules/4.4.35/extra
    b.) Box neustarten (restart Box)
    Sieh hier gut aus. Wenn feedback auch gut können wir veröffentlichen.
    Here looks good. After get good feedbacks we will realese.
    link;
    https://www.mediafire.com/file/dkunh...52019.zip/file
  13. #88
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 06.05.2019
    - [sf8008] update ir drivers
    - New Online/Local Flash Menu
    - New Complete Backup Menu
    - Install Full Backup Image from Power Button Standby Menu
    - [multiboot] add MessageBox before reboot
    - [sf8008] update ir treiber
    - Neues Online/Lokal Flash Menü
    - Neues Vollständige Menü
    - Voll Backup Installation mit Power Taste (Boot Menü) eingebaut
    - [multiboot] Info Popup bevor Neustart eingefügt
    - [sf8008] ir sürümü güncellendi
    - Yeni Cevrimici flas Menüsü eklendi
    - Yeni Tam (tüm) Yedekleme Menüsü eklendi
    - Tüm Backup Imajinizi Power tusuna basark Imaj gibi yükleme imkani eklendi
    - Bilgi: Bu Drivers ile Artık Flash Online Yerine Tüm yazılım ve Backup Dosyalarını Öndeki Düğmeye 30 Sn. Basılı Tutup Açılan Boot Ekranında Recovery Menüsünden Yükleyebilirsiniz.
    - [multiboot] cihazi baslatmadan önce Bilgi mesja ekrani eklendi
    Ab heute Images!
    From today Images!
    Bugünki imajlardan itibaren!
  14. #89
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 08.05.2019
    What's new ;
    - Fixed AGC % percent value
    - Fixed a assert error during boot and remove some debug infos
    - Remove the debug info for kernel print
    Treiber Datei per FTP installieren:
    Datei hi-dvb.ko + hisi-ir.ko nach /lib/modules/4.4.35/extra kopieren und Box neustarten.
    FTP install:
    hi-dvb.ko + hisi-ir.ko copy to --> /lib/modules/4.4.35/extra
    Telnet & Putty:
    Download link ;
    https://www.mediafire.com/file/3x914...52019.zip/file
    https://www.octagon-germany.eu/
    https://octagon-forum.eu/
  15. #90
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 15.05.2019
    What's New ;
    - Add GPT usb disk support in fastboot
    - Change the default bootargs in fastboot for sf8008
    - So it can enter recovery even lost bootargs partition for sf8008.
    - Try to fix DVB-T2/C SNR value for ATBM78XX demod.
    - Disable the VFD display when go to deepstandy.
