Thanks Thanks:  52
Likes Likes:  45
Dislikes Dislikes:  1
Page 8 of 20 FirstFirst ... 45678910111218 ... LastLast
Results 106 to 120 of 293
  1. #106
    Für Amateurfunker und DX`er
    Frequenzeingabe 3 stellen nach komma wie Bsp. 1xxxx,xxx.
    Allow to enter DVB-S frequencies in KHz
    But keep the dimension in MHz by adding a decimal point
    PS: Getestet mit OpenEight 6.7
    For amateur radio and DX`er
    Frequency input 3 place after comma as example 1xxxx, xxx.
    PS: Tested with OpenEight 6.7
    https://i.postimg.cc/prGYQZ6j/3decimal2.jpg
    https://i.postimg.cc/Z5Z6QnGn/3decimal1.jpg
    https://i.postimg.cc/25tbCSK4/3decimal3.jpg
  2. #107
    Thumbs up OCTAGON SF8008 Netflix Beta 2 - 05.11.2019
    Ab morgen/übermorgen auf dem Feed.
    From tomorrow / the day after tomorrow on the feed.
    Yarından itibaren / yarından sonraki günden itibaren feed`de (Online güncelleme)
    Beta 2
    v1.0.2
    2019.11.05
    1.Add keys controls.
    ·Subtitle key to call subtitles control, on playing
    ·Audio key to call media track control, on playing
    ·Info key to call playing status, on playing
    ·Playlist key to call episode/seasons control, on playing
    ·Next key(>) to call next episode if exists, on playing
    ·Red color key work as Info.
    ·Blue color key work as Subtitle.
    ·Yellow color key work as Audio.
    ·Green color key work as Playlist.
    2.Fix bugs
    ·update kidpage control.
  3. #108
    Update OCTAGON SF8008:
    Chrome Browser Version 77 (Netflix and co.)
    Ab morgen Images!
    From Tomorrow Images!
    Yarinki Imajalrdan itibaren!
  4. #109
    45 Post(s)
    Testez zilele urmatoare şi revin cu rezultatele.
    A mai testat cineva?
  5. #110
    45 Post(s)
    Am testat astazi NETFLIX si este perfect functional.
    De asta stb-urile astea din care face parte Octagon sf8008 merita toti banii!
    Sa asteptam sa apara si in pluginurile altor stb-uri din familie.
  6. #111
    23 May 2007
    Ab morgen Images!
    Am instalat ultima versiune de imagine Pure2 din data de 02.12.2019,dar nici urma de Chromium Browser 77,nici in System,nici in Plugin-uri,nicaieri!Unde gresesc?Poate sa-mi spuna cineva?
  7. #112
    Thumbs up Update OCTAGON SF8008 06-12-2019:
    Netflix new version chrome browser
    Extensions, Code:
    enigma2-plugin-extensions-netflix - 2.0+20191206-r1 - Netflix for chromium browser
    1.Fix keyboard input on login.
    2.Fix start up issue.
    3.Fix netflix component.
    4.Daily fix.
    Ready in images!
    OCTAGON GERMANY SUPPORT
    https://www.egami-image.com/uploads/...7282cc6742.jpg
  8. #113
    OpenBlackhole 4.2 Octagon sf8008 Image
    Build image open Black Hole 4.2.048 for Octagon SF8008
    https://www.mediafire.com/file/kaohy...8_mmc.zip/file
  9. #114
    10 Jul 2008
    http://www.turkeyforum.com/satforum/...d.php?t=790317
    Cunoasteti ceva despre aceasta imagine ?
  10. #115
    Update OCTAGON SF8008 20-12-2019:
    Extensions, Code:
    enigma2-plugin-extensions-netflix - 2.0+20191217-r2 - Netflix for chromium browser
    https://www4.0zz0.com/2019/12/20/22/438937725.jpg
    - fix. artifacts and stutters.
    Ready in images!
  11. #116
    Thumbs up OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 25.12.2019
    - [SF8008] + [SF8008m] Update Drivers:
    - Improve the DiSeqC Motor control
    - Improve Recovery Menu
    - SF8008m mini: use usb 2.0 as sda for multiboot
    - Updated files:
    - hi-dvb.ko
    - apploader
    - octagon-linux-4.4.35-20191224 (Kernel)
    Ab morgen in den Images!
    From tomorrow in images!
    Yarinki imajlardan itibaren!
  12. #117
    Thumbs up OpenPLi Octagon sf8008 Image
    03-01-20 OpenPLi Octagon SF8008:
    ! TEST !
    openpli-develop-sf8008-20200103_usb.zip:
    https://www.mediafire.com/file/hn0ip...3_usb.zip/file
    Changes:
    - Online Feed enabled!
  13. #118
    25 Mar 2008
    Buna tuturor, as avea o intrebare si eu in legatura cu acest receptor " Octagon Sf8008 " ma intereseaza daca se poate folosi ca si server ?
    Multumesc.
  14. #119
    Da şi ca server, pe lângă multe alte lucruri utile.
    25 Mar 2008
    Multumesc D-nu @horatyu...
