Thanks Thanks:  40
Likes Likes:  38
Dislikes Dislikes:  1
Page 17 of 17 FirstFirst ... 71314151617
Results 241 to 243 of 243
  1. #241
    25 Sep 2008
    Suceava
    Salut, stie cineva daca exista vreo setare pe undeva, sa nu-mi mai apara numerele programelor in fata numelor programelor in listele de programe editate cum se vede in poza? In listele de programe scanate nu apar acele numere, doar in listele separate! SF8008 cu Openatv 6.4. Multumesc
  2. #242
  3. #243
    13 Post(s)
    Warder private image for Octagon SF8008 and SF8008mini
    New
    - Update DVB
    ----- support for rc03 and rc05
    ----- apploader update
    ----- WiFi drivers update
    ----- long names fixed.
    - Update Enigma2
    - Update pre-installed plugins
    - Update TV settings (Barrandov)
    - Update ArchivCZSK - added modul Antik TV
    - Re-addition plugin CSFD
    Use distro: OpenATV 6.4
    Enigma version: 16-01-2022
    Kernel version: 4.4.35
    DVB version: 05-01-2022
    GStreamer version: 1.18.5
    Python version: 2.7.18
    Resolution mode: 1080p
    Default language: Slovak
    Default skin: HD Glass 17
    OSCam: r11523 - port 8888 - 0624 ICE, IRDETO, M7 L2b
    Pre-installed plugins:
    - AJPanel - 3.3.0
    - ArchivCZSK - 1.3.8
    - Chocholousek picon - 5.0.211125
    - CSFD - 15.20
    - CoolTVGuide - 7.7.0
    - DreamSat Panel - 1.3
    - HBBTV - 2.0-r0-47
    - Filmon - 1.6
    - Levi45 Multicam Manager - 9.2
    - Netflix - 4.0
    - MediaPortal - 2020070101
    - Multi-Stalker - 1.3
    - SubsSupport - 3.1.0
    - Streamlink - 3.3
    - webradioFS - 20.06
    - XStreamity - 3.58
    - Youtube - git963
    - YoutubeTV - 1.0 - the maximum video playback resolution is 1080p !
    - Kodi 18.9
    - under Kodi Skylink Live TV - 1.7.3
    - under Kodi Netflix - 1.12.8
    - under Kodi Stream Cinema - 1.3.28
    - under Kodi Stream Cinema Community - 2.5.29
    Pre-installed skins:
    - HD Glass 17 - 7.07
    - Metrix-ATV - 3.0-git2001
    Login :
    Password : warder
    Installation:
    - copy the file to a USB stick and install via Online image change.
    Download:
    You can download image for SF8008 from
    https://mega.nz/file/ss0EnRgJ#N6TP0b...HdORx58oGOkCVU
    You can download image for SF8008 MINI from
    https://mega.nz/file/tl1i1RDC#aTldf7...7LjVvSSqZr2YxQ
