Thanks Thanks:  52
Likes Likes:  45
Dislikes Dislikes:  1
Page 9 of 20 FirstFirst ... 567891011121319 ... LastLast
Results 121 to 135 of 293
  1. #121
    25 Mar 2008
    Am butonat azi un pic acest receptor " octagon sf8008 "cu img openATV 6,3 am reusit sa fac sa functioneze cam tot ce poate acest receptor, ce nu imi mai amintesc cum sa fac sa imi apara in skin default ecm info server info. O mana de ajutor daca se poate.
    Multumesc.
  2. #122
    25 Mar 2008
    Rezolvat
  3. #123
    24 Mar 2009
  4. #124
    24 Mar 2009
  5. #125
    24 Mar 2009
    pkteam SF8008 HYPERION 7
    http://e2.pkteam.pl/index.php?dir=IM.../HYPERION%207/
    AAF nightly images Octagon SF8008
    Neue Titan stable Version 1.91
    v1.91
    http://atemio.dyndns.tv/nightly-imag...K%20UHD/v1.91/
    v1.90
    http://atemio.dyndns.tv/nightly-imag...K%20UHD/v1.90/
  6. #126
    Thumbs up OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 27.02.2020
    - [SF8008] + [SF8008mini] Update Drivers]:
    - May improve the IR Infrared receiving sensitivity
    - Fix a issue for smart card when close the /dev/sci0
    - Improve the diseqc send when lnb power on.
    - Updated files:
    - hi-dvb.ko
    - hisi_sci.ko
    - hisi-ir.ko
    - libreader
    From tomorrow in images!
    OCTAGON GERMANY SUPPORT​
  7. #127
    02 Sep 2010
    Earth
    Super acest decoder :
    Recomand cu caldura la tori.
    Imaginea cea mai buna e Openeigth.
    Prietenii stiu de ce.
  8. #128
    Thumbs up KODI 18.5 TEST mit NETFLIX OCTAGON SF8008 E2 4K UHD
    https://octagon-forum.eu/sf8008-atv-test185.jpg
    oe-alliance Presends
    Big Thanks goes to openSPA Team and openBH Team for Porting all from KODI 17 to 18
    thanks Captain OpenATV too.
    Anleitung
    Install Netflix Addon for Kodi 18.5 Octagon SF8008 (Test, OpenATV 6.3)
    https://youtu.be/6TREaabHf7Q
    Netflix Repo : https://mega.nz/#!t3ZATIpI!GLiQYqkcq...IIxpPRhQIayjPM
    Amazon Repro: https://mega.nz/#!NigHnQpB!zQX41VJz_...2X2K6-xMH0Jmv4
    Kodinerds Repro z,b, Joyn,DAZN usw : https://mega.nz/#!FygnlaxY!zlzYk4KDv...h8nkITkhttp://
    INFO Netflix ABO wird benötigt!
    Installation am besten über Flash Online aus dem Laufenden Image
    KODI 18.5 ist im Image enthalten
    andere Widevine Addons sollten auch laufen wie dazn, Joyn, Prime usw.
    Schreibt eure Erfahrung und was Ihr Installiert hab mit eine kleinen Anleitung das auch alle es verstehen.
    Link zum Repro oder Addons nicht vergessen.
    und hier wie immer alles Public im GIT nicht wie andere Images die alles Close machen...
    https://github.com/oe-alliance/oe-al...s/meta-octagon
    STATUS was Positive getestet wurde:
    Netflix
    Amazon VOD
    SKY GO VOD, LIVE Spiele gehen nicht
    Joyn
    Xtream
    SF8008 openATV 6.3 Image mit KODI 18.5
    https://mega.nz/#!t3ZS1A5I!F39jzONe6...DQkKgp9zpfT3KE (mega nz)
    https://www.mediafire.com/file/pfvjk...3_mmc.zip/file (mediafire)
    __________________
    OCTAGON SF8008 4K UHD E2 (Single, Combo, Twin)
  9. #129
    Thumbs up OCTAGON SF8008 v2
    Review OCTAGON SF8008 v2 | Deutsch (E2WORLD)
    https://youtu.be/ljD1O1vXjtw
    Danke an Gunnar Koser für das Video.
    Octagon SF8008 Single, Combo and Twin V2. (in Sales since October 2019)
    imporvements:
    - Front Display improved
    - Material Housing cover imporved
    - CPU heathing improved
    - Tuner GAIN improved
    - Rubber foot use better one
    - Giftbox improved
    - WOL HW + HW Full Recovery by Recovery Button.
    https://www.octagon-forum.eu/
    https://www.octagon-germany.eu/
    OCTAGON SF8008 openATV 6.4 KODI 18.6
    Link 1:
    https://mega.nz/#!Mr5TgboR!cCJTKF_64...6n7lUmvOMhttp:
    Link 2:
    https://www.mediafire.com/file/l2flm...5_mmc.zip/file
  10. #130
    Nonsolosat OCTAGON SF8008 Unofficial Image
    http://www.mediafire.com/file/xktw9f...8_usb.zip/file
    http://www.mediafire.com/file/alf7z3...write.zip/file
    ---------- Post added at 11:45 ---------- Previous post was at 11:32 ----------
    OpenEight KODI 18.x OCTAGON (Test)
    OpenEight Kodi 18.6 OCTAGON SF8008:
    https://octagon-forum.eu/test-team/o...200317_mmc.zip
  11. #131
    Thumbs up X-Streamity Plugin (.m3u Player) auf OpenEight
    Config
    Ftp:
    /etc/enigma2/X-Streamity/playlists.txt
    Open playlists.txt and copy (öffne playlists.txt und kopiere m3u link)
    http://domain.xyz:port/get.php?usern...plus&output=ts
    https://octagon-forum.eu/test-team/xtv/1xtv.jpg
    https://octagon-forum.eu/test-team/xtv/2xtv.jpg
    https://octagon-forum.eu/test-team/xtv/3xtv.jpg
    https://octagon-forum.eu/test-team/xtv/4xtv.jpg
    https://octagon-forum.eu/test-team/xtv/5xtv.jpg
    https://octagon-forum.eu/test-team/xtv/6xtv.jpg
    Note; this plugin for all octagon models with open8eight image.
  12. #132
    02 Sep 2010
    Earth
    Noua imagine cu Kodi 18.x pregatita pentru testare, sper sa apara in curand disponibila pentru publicul larg.
    Foarte interesanta.
  13. #133
    45 Post(s)
    Am testat kodi 18.6 Leia cu Openatv 6.4
    Filmele in format HEVC nu le reda. Cele in format mkv sunt redate dar dupa scurt timp Octagonul se blocheaza si trebuie repornit din butonul Power.
    In schimb Youtube reda cursiv imaginile UHD.
    Si pluginul Netflix functioneaza bine, dar mai incomod este de umblat prin menu.
  14. #134
    02 Sep 2010
    Earth
    Tinere, nu uita ca e in beta!!! Tu gandeste ca eu am "alfa 19" de doua luni si stau mai rau ca tine
    Vor apare pe rand versiuni noi. Cunosc personal o parte din echipa de la openeigth cei care dezvolta acest project.
  15. #135
    Vezi ca "tanarul" e de-o seama cu noi .
    Ar vrea el sa fie cu vreo 30 mai mic
