Page 10 of 28 FirstFirst ... 6789101112131420 ... LastLast
Results 136 to 150 of 413
Thread: Octagon sf8008 4k uhd e2 dvb-s2x & dvb-c/t2
  1. #136
    OpenPLi Support OCTAGON SF8008 4K UHD E2 Models
    https://openpli.org/download/octagon/sf8008/
    OCTAGON SF8008
    Image ab Morgen (Image from Tomorrow, Yarinki imajlardan itibaren)
    Add Hiplayer HW Playback Support !!!!
    4k geht dann ohne Ruckler wieder mit Local media (Kodi 18.6 / Netflix etc.)
  2. #137
    Octagon SF8008 4K UHD Preview neues HW Multiboot und Recovery Menü
    Das Menü Features:
    Installation von USB und Images Online.
    Recovery wenn Box nicht mehr richtig Arbeitet.
    Formatieren SD Karte für noch mehr Platz und weitere Images.
    Online Update geht nun ohne USB Stick an der Box.
    Booten ins Recovery aus E2 oder eine Fernbedienungstaste beim Starten der Box.
    Keine SD Karte wird mehr benötigt Multiboot nun auch mit dem Internen EMMC Speicher.
    Startet eines Images im Multiboot ohne Enigma2 zuvor zu starten.
    The Features menu:
    Installation of USB and Images online.
    Recovery when box no longer works properly.
    Format SD card for even more space and additional images.
    Online update is now possible without a USB stick on the box.
    Boot into recovery from E2 or a remote control button when starting the box.
    No SD card is needed anymore Multiboot now also with the internal EMMC memory.
    Starts an image in the multiboot without starting Enigma2.
    https://www.youtube.com/watch?v=VY1G...ature=emb_logo
    Octagon-Germany.eu
    Octagon Forum
  3. #138
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 13.04.2020
    - [SF8008] + [SF8008m] Update Drivers:
    - update hisi drivers fix led brightness when set to 0
    --> echo 100 > /proc/stb/fp/oled_brightness on
    --> echo 0 > /proc/stb/fp/oled_brightness off
    - New HW Multiboot function added
    - New Recovery Menü added
    --> Images with New Functions in few days!
    --> Preview Video: https://youtu.be/VY1GdcmPcgQ
    - add rcu button detect to enter recovery menu while booting
    --> if user want to use the new multiboot system, all image have to use the new ones. so all e2 team have to update there BSP to release the new image to support it!
    - add STARTUP_ONCE checking while booting
    - add image list on github oe-alliance/bootmenu
    - multiboot image upgrade from network can update without usb device
    --> Bootmenu Images: https://github.com/oe-alliance/bootm.../master/sf8008
    - Updated files:
    - hi-dvb.ko
    OCTAGON GERMANY SUPPORT
    __________________
    OCTAGON SF8008 4K UHD E2 (Single, Combo, Twin)
    https://www.octagon-germany.eu/
    https://octagon-forum.eu/
    http://openeight.de/
  4. #139
    OCTAGON SF8008: Kodi 18.6 + Netflix (Chrome Browser) Update 15.04.2020
    - Hiplayer update
    - Hiplayer erkennt nun DRM das umstellen muss nicht mehr gemacht werden
    - Netflix neue Version
    - URL eingabe möglich für Chome Browser (Netflix)
    - Hi Player update
    - Player now recognizes DRM that switching no longer has to be done
    - Netflix new version
    - URL entry possible for Chome Browser (Netflix)
    Ab morgen in den Images!
    From tomorrow in images!
    Yarinki imajlardan itibaren!
    Octagon-Germany.eu
    Octagon Forum
  5. #140
    OCTAGON SF8008 4K UHD E2 Fastboot & Recovery Update 25.04.2020
    - [SF8008] + [SF8008m] Update:
    * fixed crash driver when press any rcu key
    * fixed crash when load more as 3 Image to same time
    * add delete image from slot (Multiboot Deletion)
    * add common partition update get latest recovery menu
    * optimise install performence
    * stop der installation wenn fernbedienung betätigt wird
    * fehler bei nutzung min. 3 Images behoben
    * löschfunktion images auf slot x eingebaut (Multiboot Deletion)
    * Hinzufügen eines allgemeinen Partitionsupdates (eueste Wiederherstellungsmenü)
    * Installationsleistung optimiert
    Wenn Neue Multiboot + Recovery Image genutzt wird, reicht ein Online Update!
    If new Multiboot + Recovery Image is used, an online update is sufficient!
    Yeni Multiboot + Kurtarma Imaji kullaniliyorsa, online güncelleme yeterlidir!
    Octagon-Germany.eu
    Octagon Forum
  6. #141
    OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 01.06.2020
    * add sx88/sx88+/sx888 rcu support.
    * Remote Contols as:
    * SX88 /+/SE/WL, SX888 IP/WL, SX88+ Optima & Combo.
    * sx88/sx88+/sx888 Fernbedienung support eingebaut.
    * Fernbedienungen wie:
    Info:
    DE, Auswahl Menü mit mehr Optionen & Fernbedienungen später!
    EN, Selection menu with more options & remote controls later!
  7. #142
    OCTAGON SF8008/SF8008m Mini Multiboot with Octagon SX88 Linux OS
    OCTAGON SX88 yazilimimlarini SF8008 Modellerinde kullanma imkani!
    Octagon SX88 Linux işletim sistemi artık Multiboot menüsünde de mevcut
    Görüntü IPTV ve DRM içeriği için optimize edilmiştir
    SF8008 ve SF8008m Mini modelleri için mevcuttur.
    The Octagon SX88 Linux OS is now also available in the recovery menu.
    The image is optimized for IPTV and DRM content.
    Available for the SF8008 and SF8008m Mini.
    Es gibt im Recovery Menü nun auch das Octagon SX88 Linux OS
    Das Image ist Optimiert für IPTV und DRM Content
    Verfügbar für die SF8008 und SF8008m Mini.
    https://youtu.be/HGnG3QFuRZQ
  8. #143
  9. #144
    24 Mar 2017
    da, e bun si ptr server ...
  10. #145
    Egami 9.0 recovery
    Download: egami-9.0.2-sf8008-20200413_recovery_emmc.zip
    https://drive.google.com/uc?id=1L7NC...xport=download
  11. #146
    OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10526 13-07-2020
    Changes:
    1. Touchpad WEBIF Android and iOS.
    2. Voume Control steps improved.
    3. Keyboard Support YouTube.
    Online Update:
    Menu - Software Update OK - 0000 - Internet Upgrade: v10526 OK
    Online Aktualisierung:
    Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10526 OK
    Online güncelleme:
    Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10526 OK
    SW offline - USB:
    DUAL OS Menu: https://www.mediafire.com/file/t7we4...0713.mupg/file
    Recovery Bootmenu (E2):
    SF8008 & SF8008m mini- https://www.mediafire.com/file/cmzd7...40720.rar/file
    __________________
  12. #147
    Thumbs up SAPRO - Backup images openatv-6.4 OCTAGON SF8008 + SF8008mini
    SAPRO Image for Octagon SF8008 1.6oa
    Use distro: OpenATV 6.4
    Enigma version: 25-11-2020
    Kernel version: 4.4.35
    DVB version: 19-11-2020
    GStreamer version: 1.17.0
    Python version: 2.7.16
    Resolution mode: 1080p
    OSCam: r11678 - port 8888 - ICE 0624
    Default language: Czech
    Pre-installed plugins:
    - ArchivCZSK with SCC - 1.3.6 - 2.1.14
    - Chocholousek picon - 3.1.201103
    - CSFD - 12-50-20180505
    - CoolTVGuide - 7.7.0
    - HBBTV - 2.0-r0-34
    - Netflix - 2.2 + 20201119-r0
    - MediaPortal - 2020060104
    - SubsSupport - 1.5.8-20201004
    - webradioFS - 19.28
    - XStreamity - 2.65.20201116
    - Youtube - git602
    - KODI 18.9
    - under Kodi Skylink Live TV - 1.7.1
    - under Kodi Netflix - 1.11.0
    - under Kodi Stream Cinema - 1.3.28
    - under Kodi Stream Cinema Community - 1.6.12
    Login :
    Password: sapro
    Installation:
    - unpack the file on the USB stick and install via Online image change.
    You can download version for SF8008
    https://ulozto.sk/file/gJ1tTp0YsWL9/...6oa-sf8008-zip
    https://mega.nz/file/x4kyDDYQ#37dj7l...gWN6g9BI-lnj9E
    You can download version for SF8008mini
    https://ulozto.sk/file/NInvXJoqLaXR/...sf8008mini-zip
    https://mega.nz/file/Il12gbIB#Ma_FtC...7VGlgo_OphHpXc
  13. #148
    OpenFix Image For Octagon SF8008
    openfix-5.4.17-sf8008-20201127_mmc.zip
    http://www.mediafire.com/file/p08wi8...7_mmc.zip/file
    openfix-5.4.17-sf8008-20201127_recovery_emmc.zip
    http://www.mediafire.com/file/6o0v32..._emmc.zip/file
  14. #149
    23 May 2007
    - HBBTV - 2.0-r0-34
    - Youtube - git602
    - KODI 18.9
    Login :
    Password: sapro
    Installation:
    Ar fi si mai bine daca s-ar si putea instala pe Octagon SF8008 multiboot!Eu nu am reusit nicicum!Nu mi-l vede de pe stickul USB!No image found!Asa ca pauza!
  15. #150
    @thomasstar
    Vezi la postarea #9 https://www.linuxsat-support.com/thr...ctagon-sf8008/
    ---------- Post added at 09:19 ---------- Previous post was at 09:01 ----------
    Cu mentiunea ca nu folosesc stick USB ci micro-SD in slotul din spate
