Thanks Thanks:  5
Likes Likes:  9
Dislikes Dislikes:  1
Results 16 to 30 of 33
Thread: DM 920 4K Imagini
    All new dreambox update Satlodge image enigma2: 4.3.2r7 31/07/2019 possibility update rc and flash - https://ufile.io/py1doqj7
    enigma2: 4.3.2r7
    * added support for FBC DVB-C tuner
    * fixed Graphical MultiEPG Setup skin
    * allow the description of configuration entries to grow up to the actual size of the value (if it's text or a pixmap) minus some margin (font-size in pixels)
    for skin and plugin developers:
    * ConfigLists:
    - implemented on/off pixmaps for boolean config types
    Example:
    <listboxcontent>
    <config onPixmap="skin_default/switch_on.svg" offPixmap="skin_default/switch_off.svg" size="30,16"/>
    </listboxcontent>
    * fixed several rendering/blending issues in listboxes
    - don't render incomplete last item in grid mode or with selection zoom enabled
    - alpha-blend zoomed selection
    - fixed issues with alpha-blended lables and pixmaps in multicontent lists
    - fixed item size calculations in horizontal mode when there's a margin
    * fixed eLabel having the wrong background color in some cases
    * - update satlodge Distro
    * - update satlodge plugins etc
    - new satlodge EPG IMPORTer and other small fix
    - possible update via remote software update
    Open Black Hole 4.3.001 - http://www.mediafire.com/file/af7xl5...s.tar.bz2/file
    -Build from open-blackhole git source
    -DM900 -SIM2.30
    -GCC 8.2.0
    -GStreamer 1.17.0.1
    -Python 2.7.15
    -Linux 3.14.79
    Open Vision 9.2-r35 - OpenVision, which is based on OpenPLi - http://www.mediafire.com/file/45it93...5_web.zip/file
    Thanks: OpenVision Team
    online update; opkg update; opkg upgrade
    NB! feed changed:
    GStreamer - 1.17.0.1
    python - 2.7.16-r0
    GCC - 9.2.0
    Glibc - 2.30
    OpenSSL - 1.1.1c
    Busybox - 1.30.1
    FFmpeg - 4.1.4-r0
    exteplayer3 - 63
    wget - 1.20.3-r0
    curl - 7.65.3-r0
    kernel-image - 3.14-r0
    kernel-image-zimage-3.14-1.17-dm9x0 - 3.14-r0
    dreambox-dvb-modules-dm9x0 - 3.14-1.17-20190830-r0
    Build: DreamOSat
    Thanks audi06_19
    Redeschis, insă aveţi grijă la obiectul secţiunii!
    Ban direct pt. polemici de dragu' de-a scrie!
    Să nu ziceţi că că nu ştiaţi, nu vă mai aduceţi aminte de regulament, ş.a.m.d
    Open Vision 9.2-r47 - http://openvision.dyndns.tv/images/9.2/dm920/
    OpenATV 6.4 für DM920UHD - http://www.mediafire.com/file/dwrosi...19.tar.gz/file
    BlackHole 6.0 für DM920UHD - https://gofile.io/?c=zPsY2b
    Standard RSP member giku fredolin's Avatar
    20 Feb 2009
    ROMANIA
    Imagine noua Openvision 9.3-r70-dm920- openvision-enigma2-upcoming-multilanguage-9.3-r70-dm920_web.zip
    Succes la teste !!!
    Thumbs up Open Vision 9.3-r74
    Open Vision 9.3-r74
    online update;
    NB! feed changed:
    python - 2.7.16-r0
    GCC - 9.2.0
    Glibc - 2.30
    OpenSSL - 1.1.1d
    Busybox - 1.31.1
    FFmpeg - 4.2.1-r0
    exteplayer3 - 63
    wget - 1.20.3-r0
    curl - 7.67.0-r0
    Build: audi06_19
    Thanks OpenVision Team
    https://www.mediafire.com/file/jf6vx...0_web.zip/file
    OE2.0 - 2.6 Softcam/Plugins/Config - http://de-extra.co/index.php?dir=
    PurE2 - https://easyupload.io/zfjw77
    OpenTS Image 6.2 - https://easyupload.io/pp6y1k
    -Change feeds url
    -Update Drivers
    -Update some pythons
    -Update Gstreamer
    -Update some lib files
    BlackHole 6.x DM920 - https://easyupload.io/z5t4h9
    Versiunea 6.2
    - Schimbarea feed-uri URL-ul
    - Schimbarea bootlogo si mulţumesc (zelda77)
    - Update Drivers (Acum teleportarea de lucru din nou)
    - Actualizaţi nişte pitoni
    - Actualizare Gstreamer
    - Update unele fişiere lib
    - Schimba skin-ul implicit (MX_Sline-Black-I-mod) si adăugaţi/editati unele ecrane pentru imagine
    OpenVision 9.3-r98 - https://easyupload.io/c9tv9a
    OneStep Image DM920 ( OE2.5 ) - https://easyupload.io/xmtc9p
    Este o imagine pentruDM9x0 bazate pe Gemeni OE2.5 ramurã cu Gemini4 şi cam feed.
    Dupã pornire, apoi utilizaţi butonul albastru pentru a apela AddonsManager şi, dacã este afişat, upgrade cu butonul verde
    - MediaPortal + Extensie
    - MetrixStyle HD
    - MetrixStylehd mediaportal 2.0
    - Startupservice
    - Menusort
    - Pluginsort UltraHD-Box
    Openvision-10.2-r299-dm920_piterfree - https://mega.nz/file/owhwhSqC#Zegjbl...LusaZrYUYSbDhk
    updated by piterfree TvSat Cam + Card.Nera ok 100x100
    setting Vhannibal + dtt milano Motor Lnb 4 (13 + 19 + 5w + 9e)
    skin Pd1loi-HD-night ok disply picon + info
    CCcam 2.3.2
    ncam______reader TvSat ok
    oscam-emu_reader TvSat ok
    dBackup
    EPGImport 2020
    FileCommander
    IPTVPlayer
    NGsetting
    tvPanel 1.9.4
    VpnManager
    Weather Plugin_Varese
    MountManager
    AutomaticCleanup
    Care este cea mai bună imagine pentru DM920 și principala diferență beetween OE2.0 și OE2.5
    - Cea mai buna este imaginea originală sau orice alta imagine cu OE2.5 , in functie de ce ai nevoie
    - Cea mai buna imagine pentru tuner FBC , este NewEnigma2
    - Se poate opta si pentru Openpli, dar trebuie să știți că nu este optimizata bine pentru un tuner FBC
    27 Aug 2013
    Default Dream Elite 6.0
    Salut,
    Am obtinut de curand un DM920 UHD si incerc sa gasesc toate canalele funzorului (1802, 1880) la care am abonament.
    Inainte am avut un EVO7 de la OptiBox si totul functiona bine, dar s-a defectat si l-am inlocuit cu receiver-ul de mai sus.
    Am instalat Dream Elite 6.0, am actualizat fisierul satellites.xml (obtinut de pe satallites-xml.org), apoi OSCam pentru ARM7. Citeste card-ul fara probleme, insa nu reusesc sa gasesc toate canalele din grila.
    Spre exemplu, pe lyngsat.com, imi spune ca pe 12687H voi gasi cateva posturi, acest transponder este in fisierul meu satellites.xml, dar la scanare (satellite, blind sau transponder) nu imi gaseste nimic. Aveti idee de ce?
    Apoi as mai avea o intrebare: un receiver, atunci cand scaneaza un satelit, grupeaza canalele pe Services, Services FTA, Providers si New. Nu inteleg cum se face aceasta grupare a serviciilor pe furnizori, daca se face doar pe baza informatiilor obtinute la scanare sau are undeva memorate informatii legate de canale si provideri.
    P.S. As fi preferat imaginea originala, insa nu am reusit sa instalez OSCam pentru procesor ARM7 decat pentru imaginea Dream Elite 6.0
    Multumesc.
    o intrebare pentru posesorii de dm920, de ce sunt imagini cu terminatia rootfs.tar.bz2 si web.zip ? am si eu un dm920 care il tin intr-un sertar si vreau sa pun niste imagini de test cind o sa am liber. multumesc
    chevron gas station near me
    Coco , exista daca nu ma insel doua modalitati de a instala imaginii pe acest receptor :
    1 - Cu stick usb - in acest caz dezarhivezi acele fisiere ''web.zip'' in care se gaseste un dosar ''DM 920'' si il copiezi direct pe stick si apoi incepi instalarea propiu-zisa a imaginii
    2 - Prin ip-ul receptorului , daca il stii - ai un ''How to'' aici ( pt aceasta metoda ) - https://www.sateliti.info/showthread...920-UHD/page20
    Gdragu , la chestia cu negasitul prg tv de pe o anumita frecventa ...sincer , poate numai sunt active respectivele prg tv/radio
    De exemplu - Pe 12687H - prg tv U-TV a fost - Streaming liniar - Acest canal a fost verificat ultima dată pentru a fi streaming în octombrie 2020 - https://www.lyngsat-stream.com/tvchannels/ro/U-TV.html
    Celelalte vad ca sunt niste posturi radio.......care tot asa numai sunt active probabil
    Legat de - .......grupeaza canalele pe Services, Services FTA, Providers si New - tine de imagine
    Asa am si eu la plasma Panasonic , imi grupeaza pe - Toate canalele dvb-s - Free - Pay - HDTV - Radio gratuit si apoi cele 5 liste de Favorite pe care le fac eu
    In schimb la Samsung-ul 4K nu am decat - Toate - si apoi cele 5 liste de Favorite pe care le fac eu
    27 Aug 2013
    Multumesc pentru raspunsuri, mario08.
    Incerc in continuare sa fac sa functioneze receptorul DM920 UHD 4K 1x DVB-S2X Multistream FBC Tuner si nu reusesc. Tunerul est BCM45308X (DVB-S2), iar procesorul ARMv7 Processor rev 3 (v7l).
    Am pozitionat antena pe Thor si cu blind scan am gasit toate posturile din grila abonamentului pe care il am, inclusiv cele de pe 12687H despre care vorbeam mai sus. A functionat o vreme, apoi nu a mai functionat deloc. Am schimbat LNB-ul cu un altul (vechi) de la Inverto iar satmeter-ul pe care il folosesc la pozitionarea antenei, care are un receptor integrat, imi afiseaza imagine pe FTA (ex. Focus Sat Info) si 90% calitate semnal pe canalele criptate. Din pacate receptorul la rescanare manuala nu gaseste nimic. Am verificat semnalul cu satmeter-ul si la LNB direct langa antena, dar si la capatul cablului dinspre receptor, in casa, iar in ambele cazuri imi afiseaza imagine. Acest lucru indica, in opinia mea, ca nu ar fi probleme cu cablul, pe care sunt dispus sa il inlocuiesc, daca el ar fi sursa problemelor. Am masurat si impedanta cablului, are 6 Ohmi. Am instalat din nou ultima imagine originala (stable, apoi unstable), dar acelasi lucru, la scanare, niciun post.
    Ma intreb daca a mai intalnit cineva astfel de probleme si daca le-a rezolvat.
    Multumesc.
