Page 15 of 21 FirstFirst ... 5111213141516171819 ... LastLast
Results 211 to 225 of 315
Thread: Dream Box 920 UHD
  1. #211
    Ce înseamnă DMIPS:
    https://en.m.wikipedia.org/wiki/Dhrystone
    Dhrystone may represent a result more meaningfully than MIPS (million instructions per second) because instruction count comparisons between different instruction sets (e.g. RISC vs. CISC) can confound simple comparisons. For example, the same high-level task may require many more instructions on a RISC machine, but might execute faster than a single CISC instruction. Thus, the Dhrystone score counts only the number of program iteration completions per second, allowing individual machines to perform this calculation in a machine-specific way. Another common representation of the Dhrystone benchmark is the DMIPS (Dhrystone MIPS) obtained when the Dhrystone score is divided by 1757 (the number of Dhrystones per second obtained on the VAX 11/780, nominally a 1 MIPS machine).
    Another way to represent results is in DMIPS/MHz, where DMIPS result is further divided by CPU frequency, to allow for easier comparison of CPUs running at different clock rates.
    https://acronyms.thefreedictionary.com/DMIPS
    Majoritatea micro-procesoarelor de ultimă generaţie folosite la telefoane şi alte electronice sunt arm
    With over 100 billion ARM processors produced as of 2017, ARM is the most widely used instruction set architecture and the instruction set architecture produced in the largest quantity.[8][9][10][11][12] Currently, the widely used Cortex cores, older "classic" cores, and specialized SecurCore cores variants are available for each of these to include or exclude optional capabilities."
    https://en.m.wikipedia.org/wiki/ARM_architecture
    Mai jos lista lor:
    https://en.m.wikipedia.org/wiki/List...oarchitectures
    PS:. Offtopic
    Parabola.cz.......
    .cz e clar că nu e tot una cu .pl
    .cz e prescurtarea şi domeniul de la Cehia===> limba cehă,
    Limba poloneza se vorbeşte în Polonia===> .pl prescurtarea şi domeniul de la Polonia
    Cum .ro este domeniul pentru site-urile româneşti, scrise în limba română.
    Și el zice că am ceva cu el.
    Dar dacă nu e atent şi e împrăştiat trebuie atenţionat
    Când i-am spus despre "graţie" s-a supărat
    pana la urma si gigablue 4k e tot arm ..au astea 4k ceva de tot pe arm sant
  3. #213
    16 Feb 2009
    Cu ventilatorul tip Noctua NF-A9x14 PWM nu am reusit sa am rezultate ok. Din cauza conectorului de la ventilator care este prea gros, contactul intre pinii de pe placa de baza si conectorul ventilatorului nu este corect, adica ventilatorul porneste, merge cateva secunde , iar in momentul in care imping conectorul pana la capat, ventilatorul se opreste. Reporneste doar daca conectorul este pus in contact mai superficial cu pinii, dar in pozitia aceasta HDD-ul nu se mai poate pozitiona pe locul lui. A reusit cineva sa-i dea de cap cu modelul acesta? Avantajul lui e ca are 14 mm inaltime, ramane spatiu suficient pana la capacul box-ului.
  4. #214
    16 Sep 2007
    Azi imi soseste si mie dar la asta vechi ce l-am pus asa am facut , probabil si la al tau trebuie operatia urmatoare: se scot cele 4 fire de la conectori le impingi usor cu un ac dupa ce le-ai scos pe toate cele 4 fire tai cu un cater aproximativ 2 milimetri din mufa de plastic si bagi firele inapoi ba le poti acu indoi la 90 grade. Succes...al meu e acu la cargus astept sa vina.
  5. #215
    16 Sep 2007
    Faceti retur repede care ati comandat acest ventilator ,eu nu pot sa mai fac caci l-am desfacut. Este o mare chinezarie...nu are fan control merge numai pe turatie maxima indiferent ce ce reglaje faci cu fancontrol ...bucsa la el e din bronz nici vorba de rulmenti un pin din cei 4 este in aer ...asta e am pierdut 100 lei...sa fim sanatosi...pun inapoi ala vechi care are turatii reglabile.
  6. #216
    Default Dream Box 920 UHD
    Deci folosiţi numai ventilatoare de pe procesoare de PC-uri, au fir pentru controlul turaţiei.
  7. #217
    Gelu , pai el are fan controler in functie de temperatura si nu sa ii reglezi tu turatia manual
    Pe mine asta ma intereseaza sa imi mentina o temperatura constanta in mod automat , fara sa umblu eu manual la turatie
    Cu temperatura cum stai in timp ?
    Se poate vedea o diferenta majora fata de situatia in care nu l-ai folosi/conecta ( ma refer la temperatura ) ?
    Cat despre conectorul ventilatorului , v-am AVERTIZAT anterior ca nici conectorulul ventilatorului INTEL probat/facut poze de mine nu l-am putut introduce pana la capat , ci doar fortat atat cat sa poata functiona
    Exista 4 variante legat de incompatibilitatea conectorului de la ventilator si cel de pe pl de baza :
    1 - la conectorul ventilatorului se taie cu caterul ce este in plus si se lasa doar forma conectorului curata
    2 - se poate cauta/cumpara un conector tata pt conectorul mama de pe pl de baza si se face un adaptor cu conectorul ventilatorului
    3 - se scot pini din conectorul ventilatorului si se conecteaza pe direct - ATENTIE! sa nu faceti scurt intre ei
    4 - scoateti pini din conectorul ventilatorului , cumparati un conector tata compatibil cu conectorul mama de pe pl de baza si introduceti pini in ordinea/dupa culori asa cum este descrisa in una din fotografiile postate de mine
    Ma repet - Personal NU doresc sa modific eu turatia ventilatorului MANUAL , ci SA SE FACA AUTOMAT IN FUNCTIE DE TEMPERATURA
    Daca voi doriti sa modificati manual turatia ventilatorului , atunci cautati modele de ventilatoare fara PWM
  8. #218
    OpenEsi DM920 UHD
    http://www.openesi.eu/images/index.p...190325_web.zip
    ( nu detin DM920 UHD )
    succes tuturor
  9. #219
    16 Feb 2009
    Cand recomandati un anumit tip de ventilator, ar fi bine sa fie testat inainte. Asadar, Noctua NF-A9x14 PWM e inutilizabil, 100 de lei aruncati pe geam. Ingineria propusa de @mario e prea complicata, in conditiile in care cu ventilatorul Arctic F9 PWM PST, care e de 3 ori mai ieftin, se poate aplica solutia propusa de team Newnigma ( cea aratata de @sasa13). Adica nu se foloseste conectorul de sub HDD, ci cel din spatele afisajului LCD. Merge instant si stabil, temperatura cu 20 de grade mai mica.
    Totusi, pentru o raciere mai eficienta, ar fi mai bine sa se indeparteze radiatorul pus peste CPU, operatie care nu stiu cat de facila este....
  10. #220
    Am montat şi eu un ventilator, dar pe conectorul din spatele display-ului.
    Este silenţios, dar funcţionează şi pe idle mode.
    Având în vedere preţul ventilatorului, mai puţin de 6 lei cred ca am să-l las să meargă non-stop, mai ales că radiatorul se încălzeşte uşor şi in modul standby
    Ventilatorul este acesta:
    Am să testez şi soluţia cu NOCTUA, cu grijă iar în caz de nemulţumire voi returna produsul conform avertizării lui @gelu_dh.
  11. #221
    16 Sep 2007
    Cate grade ai daca lasi pe un program 4k? ...sunt 2 randuri de pini pe care rand ai pus?
  12. #222
    E complicat pt cine nu le are cu electrotehnică, fiindcă nu iti trebuie facultate pt asa ceva
    Conectorul in cauza e DEDICAT pt un ventilator de răcire, ca modelul recomandat nu funcţionează cum vor unii asta e alta poveste
    Se pare ca multi fac confuzie intre reglajul manual si cel automat in functie de temperatura
    Cine doreste reglaj manual poate sa isi cumpere orice model de ventilator simplu doar cu 2 fire
    Ii adauga un regulator de turatie si si-au rezolvat toleranţă
    In schimb daca se doreste turatie variabila in functie de temperatura , atunci fără PWM nu faceti nimic
    De ce oare , coolerul de la Intel are 4 pini si mai sunt si alte modele dedicate racirii procesoarelor cu 4 pini ?
    La aceste modele , le reglati voi manual turatia sau isi modifica ele automat turatia in functie de temperatura procesorului ?
    Puteti face diferenţa între cele două situaţi , bine , NU ........e prb fiecaruia ce si cum intelege
  13. #223
    @gelu_dh
    După vreo 20 de minute pe PEARL TV 4K am ajuns la 56 grade, iar conectorul este pe rândul de pini dinspre panoul frontal. Sunt 3.3V între pinul 3 şi 5, iar la tensiunea asta nici nu se aude băzâitul. Nu ştiu valoarea turaţiei dar daca este alimentat la conectorul de sub HDD la 12V, evident că turaţia este maximă şi zgomotul mai puternic.
    La acel conector găsim 3.3V şi 12V, dar nu ştiu ce au avut proiectanţii în cap de l-au amplasat acolo.
    Oops !!!!!! soluţia nu este bună, atunci cănd dai power off şi apoi power on, display-ul nu lucrează iar aparatul nu boot-ează!
    La început m-am speriat şi am crezut că s-a cam dus naibii dm-ul dar după ce am deconectat ventilatorul, totul a revenit la normal.
  14. #224
    16 Sep 2007
    In sfarsit dupa ce am probat 13 coolere ...cel cumparat de la evomag nu-i in poze caci l-am aruncat ...ma declar suuper multumit.Am probat si cu 4 pini si cu 3 pini si cu 2 fire....cel mai bine care este acum in dm 920 si cu asta raman deocamdata caci la asta se ridica temperatura la programele pe 4k -maxim 38 grade iar pe celelalte ce nu sunt 4k se ridica la 36 grade.Este un cooler de pe PC-uri de pe procesor Intel Dual Core cu 3 pini....un pin a ramas neconectat cel de la DM si anume pinul de culoare albastru . Daca gasesc tot un cooler din asta nou poate o sa-l cumpar.Am facut o mica cheltuiala pe coolere cam cca 300 lei cu tot cu manopera dar sunt oarecum multumit.Coolerul asta pe 3 pini are turatia minima am instalat si fancontrol 2 am setat 3 pini dar nu lucreaza...dealfel acest plugin nu lucreaza bine nici la 4 pini.
  15. #225
    După doua zile de întirziere am ridicat ventilatorul Noctua NF.
    Este asamblat in China pentru firma austriacă Noctua
    Ambalajul de calitate, l-am desfăcut cu mare grijă pe ideea de a-l returna în caz de decepţie.
    După primele teste cred că ideea de a-l returna va ieşi din discuţie.
    Perfect funcţional şi controlabil prin fancontrol 2, silenţios şi elegant.
    Nu l-am fixat definitiv, am să-l fixez sub capacul superior, prin fantele originale, folosind cele patru distanţiere suficient de lungi cu care vine la pachet.
    Mai conţine şi un cablu de extensie, un cablu Y pentru a conecta doua ventilatoare şi un cablu low-noise adapter.
    Funcţionează atât pe 4-pini, cât şi pe 3-pini dar în ultimul caz doar la turaţie maximă.
    Temperatura de la 49 grade a scăzut la 37 grade în circa 20 minute.
    Deci, după prima impresia cred că totul este în ordine, mai puţin problema de design a celor de la DM, prin plasarea ilogică a conectorului.
