Results 1 to 6 of 6
Thread: Edision primo ip s2 h.265 hevc multistream
    Thumbs up Edision primo ip s2 h.265 hevc multistream
    EDISION PRIMO IP S2 H.265 HEVC MULTISTREAM
    The Edision primo IP S2 with H.265 / HEVC support is the new member of the Edision Linux family.
    It combines DVB-S2 satellite reception with H.265 / HEVC support with IPTV functions.
    The excellent Multistream T2MI tuner offers you fast blind scan function.
    Further highlights are the diverse applications such as:
    - Web interface with FTP support,
    - YouTube,
    - Stalker TV,
    - Xtream IPTV,
    - DNLA,
    - Weather forecast,
    - Internet radio and much more.
    Product features
    Type: DVB-S2 Digital Satellite Receiver
    1x tuner DVB-S2 with blind scan support
    Full HD H.265 / HEVC support
    Multistream T2MI support
    Linux based operating system
    600MHz processor
    128MB RAM & Flash Memory
    Video resolution: 1080p60Hz, 1080p50Hz, 1080i60Hz, 1080i50Hz, 720p60Hz, 720p50Hz, 576p50Hz, 576i50Hz, 480i60Hz
    Multimedia Player: MP3 / JPEG / BMP / AVI / DivX / VOB / MKV & Xvid support
    DLNA player support
    Web Interface & FTP support
    E2 channel list support
    6000 storage places TV & Radio programs
    Program editor and favorites lists
    Program switching in less than 1 second
    Multilingual menu system
    EDIVISION electronic program guide
    DiSEqC 1.0, 1.1, 1.2, USALS and Unicable support
    10/100 Mbps Ethernet connection
    Power consumption of less than 0.5 watts, in low-power standby mode.
    Connections: LNB IN, SPDIF, LAN, HD OUT, SCART, 2x USB, IR Eye, RS232, DC 12V
    Display Keys: Power, Channel - / +
    LED display
    USB WiFi support (optional via WLAN stick)
    Smart Card Reader
    Software update via USB & HTTP
    Dimensions: (W x H x D): 145 x 35 x 120 (mm)
    applications
    YouTube
    Stalker TV
    Xtream IPTV
    Weather Forecast
    DLNA
    Internet radio
    front
    Display: LED (standby, recording)
    Smart Card Reader
    Laterally:
    2x USB 2.0
    1x jack to RS232
    1x jack to IR
    back
    Sat-IF input: 1x F-type
    TV connections: 1x HDMI, 1x Scart
    Video output (digital): 1x HDMI
    Video output (analog): 1x Scart
    Audio Output (digital): Optical (S / PDIF)
    1x network connection RJ45
    1x DC connection (for external power supply)
    delivery
    Edision primo IP S2
    Edision Universal 1 remote control
    2x ??? batteries
    External 12V power supply
    External infrared receiver
    Start Guide EN / DE / GR
    price : 59,90 €
    https://www.idealo.de/preisvergleich...378400029.html
    price : 41,00
    hxxps://www.dvbmarket.com/satellite-receivers/edision-primo-ip-s2-linux
    http://p.coldline.hu/2018/03/06/2782...306-jYpgz0.jpg
    http://p.coldline.hu/2018/03/06/2782...306-SksHOs.jpg
    reda sunetetul pe canalele franceze de pe satelitul 5°W
    Dolby: 1
    got chip name 6611-DNNC
    get hw dolby flag
    poze cu placa de baza al receptorului Edision primo IP S2
    http://p.coldline.hu/2018/03/09/2784...309-c38Ov4.jpg
    04 Feb 2018
    mda, este identic Amiko Mini HD265. Stii cumva cum instalez aplicatii apk pe el?
    Sent from my K10 using Tapatalk
    Thumbs up Edision Primo IP S2 - Firmware Recovery/Clean Firmware Flash
    If for whatever reason you manged to brick your box or want to do a clean re-install/upgrade (Normal update does not do a clean install and factory reset does not clear everything)
    Warning! this will remove any settings you have changed! Including all channels/transponders you have saved.
    Do the following steps:
    1: Download the firmware you wish to install, unzip it and put it on the root directory of a USB stick (Ideally make sure its formatted first)
    2: Put the USB stick in to one of the USB ports on the receiver.
    2: Unplug power lead from the receiver.
    3: Ensure the HDMI lead is connected and your TV is on and the correct input is selected.
    4: Plug the power cable in, as soon as you see the word "boot" displayed on the front of the receiver press the power button until this changes to "upg".
    5: You will see the boot logo displayed, then wait patiently and a "Firmware Update" menu is displayed.
    From here press the red key on the remote, it will then pop up with the firmware file on the USB drive, select this file and press "OK" on the remote, it will then ask "Do you want to update firmware" select yes and press "OK"
    Your receivers firmware will update and it will reboot.
    thanks to :@RustySpoons
    23 May 2007
    Buna ziua!As dori sa stiu daca pe acest receiver se pot instala imagini de genul Openatv sau OpenPli?Si daca cineva il detine,cum este multumit de aparat?
    EDISION PRIMO IP S2 HEVC Multistream receiver OSD review
    https://www.youtube.com/watch?v=pIiRVg3x04E
    software:
    hxxp://sat-soft.net/index.php/115-primo-ip-s2/116-software
    this box is a linux box (not opensource off course), and uses an opensource emulator (oscam-emu) .
    as i know,there are upgrades (newest versions) of oscam and everything that it contains
    the other boxes,are totaly closed,so a new software is needed for emulation upgrades...
    i said it is linux,but closed source and not enigma2 receiver...
    thanks to:georgeflu
